i have made a truncate using the code i will shown by bregent, however i want to extend this to make sure the full word is shown rather than cutting off
code here
$query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, LEFT(tk_job_desc, 80) as truncated_job_desc FROM think_jobsearch ORDER BY think_jobsearch.tk_job_title";
$query_limit_Recordset1 = sprintf("%s LIMIT %d, %d", $query_Recordset1, $startRow_Recordset1, $maxRows_Recordset1);
$Recordset1 = mysql_query($query_limit_Recordset1, $hostprop) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
and the result of the truncate is
<?php echo $row_Recordset1['truncated_job_desc']; ?>
what do i do to make sre a word is complete?
thanks in advance
At the moment, how many letters is it showing by default after you run your truncate function? 80?
If it is showing 80 characters, change the highlited string in the following code. This will display 150 characters.
$query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, LEFT(tk_job_desc, 150) as truncated_job_desc FROM
Also, if you'd like to truncate to the nearest word, you should visit string position - strpos function. You can read about it here:
http://www.ambrosite.com/blog/truncate-long-titles-to-the-nearest-whol e-word-using-php-strrpos
ok so i should change the
LEFT(tk_job_desc, 150) as truncated_job_desc FROM in the sql statement and use the example you used to truncate the text then specify the length
echo substr( $title, 0, strrpos( substr( $title, 0, 35), ' ' ) );
<?php
echo substr $row_Recordset1['tk_job_desc'], 0 , strrpos( $row_Recordset1['tk_job_desc'], 0, 80), ' ' ) );
would that work?
the sql statement is currently
mysql_select_db($database_hostprop, $hostprop);
the output
the changed version is
$query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, job_desc FROM think_jobsearch ORDER BY think_jobsearch.tk_job_title";
<?php echo substr ( $row_Recordset1['tk_job_desc'], 0 , strrpos( substr( $row_Recordset1['tk_job_desc'], 0, 80), ' ' ) ); ?>
if you need anymore code let me know
Can you define a variable in PHP to call your data from the job_desc table?
Once you read the data from your desired column, assign it to a variable something like
$jobdesc = "your-definition-of-the-variable-from-db;
Then, you could use a function to truncate the called text.
function truncateDesc($input, $numwords, $padding=""){
$output = strtok($input, " \n"); while(--$numwords > 0) $output .= " " . strtok(" \n"); if ($output != $input) $output .= $padding; return $output;
Your next variable would be to truncate the data that is read using the previous function defined above:
$truncated = truncateDesc($jobdesc, 10, "...");
Then finally, once $truncate variable is defined, you could echo it in your HTML:
echo "<p>$truncated</p>";
A static example of this code will be as follows:
<?PHP
$longtext = "This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description. This is some test description.";
function truncateLong($input, $numwords, $padding="")
{ $output = strtok($input, " \n"); while(--$numwords > 0) $output .= " " . strtok(" \n"); if($output != $input) $output .= $padding; return $output; }
$truncated = truncateLong($longtext, 10, "...");
This should ideally work.
Undo the previous strpos function that you've defined earlier before trying this.
Something like this:
Your SQL code:
mysql_select_db($database_testconnection, $testconnection);
$query_Recordset1 = "SELECT job_desc FROM think_jobsearch";
$Recordset1 = mysql_query($query_Recordset1, $testconnection) or die(mysql_error());
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
In your main HTML body, if you give this:
<?php echo $row_Recordset1['job_desc']; ?>
You'll get all data in all rows from your table
Now that we're able to echo the result in the page, we need to truncate it to achieve our objective. For this, look at the code below:
<?PHP
$description = $row_Recordset1['job_desc'];
function truncateWords($input, $numwords, $padding="")
$truncated = truncateWords($description, 10, "...");
This will cut it to 10 words and add ellipsis (...) to the text beyond 10 words.
I guess you could figure out to explode the results from your recordset column into different rows and order them as per the Job_ID or something.
Hope this helps.
php
<?php require_once('Connections/hostprop.php'); ?>
<?PHP
$description = $row_Recordset1['tk_job_desc'];
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
<?php
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['userid'])) {
$loginUsername=$_POST['userid'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "signup/signup-complete.php";
$MM_redirectLoginFailed = "failed.php";
$MM_redirecttoReferrer = false;
$LoginRS__query=sprintf("SELECT userid, password FROM think_signup WHERE userid=%s AND password=%s",
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $hostprop) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && false) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
<?php
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_Recordset1 = 9;
$pageNum_Recordset1 = 0;
if (isset($_GET['pageNum_Recordset1'])) {
$pageNum_Recordset1 = $_GET['pageNum_Recordset1'];
$startRow_Recordset1 = $pageNum_Recordset1 * $maxRows_Recordset1;
$query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, tk_job_desc FROM think_jobsearch ORDER BY think_jobsearch.tk_job_title";
if (isset($_GET['totalRows_Recordset1'])) {
$totalRows_Recordset1 = $_GET['totalRows_Recordset1'];
} else {
$all_Recordset1 = mysql_query($query_Recordset1);
$totalRows_Recordset1 = mysql_num_rows($all_Recordset1);
$query_Recordset1 = "SELECT tk_job_title, tk_job_location, tk_job_salary, tk_job_desc FROM think_jobsearch ORDER BY tk_job_ID DESC";
$Recordset1 = mysql_query($query_Recordset1, $hostprop) or die(mysql_error());
$maxRows_Recordset2 = 3;
$pageNum_Recordset2 = 0;
if (isset($_GET['pageNum_Recordset2'])) {
$pageNum_Recordset2 = $_GET['pageNum_Recordset2'];
$startRow_Recordset2 = $pageNum_Recordset2 * $maxRows_Recordset2;
$query_Recordset2 = "SELECT ID, FirstName, Surname, PositionReq, SalaryReq, skills_offered, location, LEFT(CanAdminInfo, 100) as truncated_CanAdminInfo FROM think_signup ORDER BY ID DESC";
$query_limit_Recordset2 = sprintf("%s LIMIT %d, %d", $query_Recordset2, $startRow_Recordset2, $maxRows_Recordset2);
$Recordset2 = mysql_query($query_limit_Recordset2, $hostprop) or die(mysql_error());
$row_Recordset2 = mysql_fetch_assoc($Recordset2);
if (isset($_GET['totalRows_Recordset2'])) {
$totalRows_Recordset2 = $_GET['totalRows_Recordset2'];
} else {
$all_Recordset2 = mysql_query($query_Recordset2);
$totalRows_Recordset2 = mysql_num_rows($all_Recordset2);
$totalPages_Recordset2 = ceil($totalRows_Recordset2/$maxRows_Recordset2)-1;
$query_Recordset3 = "SELECT * FROM think_wwd";
$Recordset3 = mysql_query($query_Recordset3, $hostprop) or die(mysql_error());
$row_Recordset3 = mysql_fetch_assoc($Recordset3);
$totalRows_Recordset3 = mysql_num_rows($Recordset3);
results <?php echo $row_Recordset1['job_desc']; ?>
The last line of your code has
this is why it's displaying all data. Actually your truncate code is not doing its job.
Try removing the last line and replace it with
<?PHP
See if it works
this is what i already have in the code which looks the same as above?
<?PHP
so remove this <?php echo $row_Recordset1['job_desc']; ?>
and replace with this
<?PHP
got an error
Fatal error: Cannot redeclare truncatewords() (previously declared in /usr/users1/jonfort/public_html/think/beta/what-we-do.php:5) in /usr/users1/jonfort/public_html/think/beta/what-we-do.php on line 424
that line of code shows
