Hiding a load clip.
Apr 27, 2012 7:36 AM
Tags: #problem #script #button #action_script_3 #actionscript3 #function
Hi to everyone, i'm working in a flash proyect using this action for each button/city (it's a map).
btn_monteria.addEventListener(MouseEvent.CLICK, montpress)
function montpress(Event:MouseEvent){
    //Crear una variable cargador para mostar el swf
    newMedia = new Loader;
    //Crear una variable para un clip vacio (anteriormente host)
    cont = new Sprite;
    //ruta para cargar la pelicula
    newMedia.load(new URLRequest("mapa_monteria.swf"));
    //mostar el boton cerrar
    btn_cerrar.visible = true;
    //Posicion x que va a tener el host
    cont.x = 10;
    cont.y = 120;
    stage.addChild(cont);
    stage.addChild(btn_cerrar);
    cont.addChild(newMedia);
and in the top of the actions have this code to load the swf
stop();
btn_cerrar.visible = false;
//Listener para cada una de las variables
//Creacion de la variable cargador
var newMedia:Loader;
var cont:Sprite;
//Listener y funciones para boton cerrar, asi como la visibilidad
btn_cerrar.addEventListener(MouseEvent.CLICK, cerrar)
function cerrar(Event:MouseEvent){
    cont.removeChild(newMedia);
    newMedia.unload();
    newMedia = null;
As you can see works fine, but there is a little problem, if you press one city and then other city (with out pressing the close button) it doesn't hide the first city.
It is a way for each time that press a button the other ones keep hiding????
You can see it here
Thanks ...
    Apr 27, 2012 7:49 AM   in reply to Jose Diego Diaz Cuellar
        cerrar();
        newMedia = new Loader();
        cont = new Sprite();
        cont.x = 10;
        cont.y = 120;
    stop();
    var cont:Sprite;
    function cerrar(event:MouseEvent = null){
         if (cont.contains(newMedia))
         if (newMedia != null)
             newMedia.unload();
        newMedia = null;
    Apr 27, 2012 8:38 AM   in reply to Jose Diego Diaz Cuellar
    you need to call cerrar() at the start of all your press functions i.e.
    montpress
    cucpress
    stapress
    villpress
    ctgpress
    bogpress
    calipress
    bllpress
    mllpress
    dqpress
    ibgpress and
    tunjapress
