Hello everyone!
Here is a situation:
var MAIN_OBJ:Object = new Object();
MAIN_OBJ.array_1 = new Array(1, 2, 3);
MAIN_OBJ.array_2 = new Array(A, B, C, D, E, [f,g,h,i,j]);
MAIN_OBJ.array_3 = new Array([k,l,m,n,o,p], Q, R, S, T);
ActionScript2:
function someFunction(prop, oldVal, newVal, limit) { trace("prop is about to change"); return newVal;}
MAIN_OBJ.watch("array_1", someFunction);
ActionScript3:
Use accessor properties (get/set functions) or the flash.utils.Proxy class for similar functionality.
Here is the task:
Watch some property of object to change, and do smth. Watch not the whole object, only one property.
I know that ExternalInterface.addCallback provides smth like that, but for the whole object.
I've never used get/set functions or override smth, please explain what should exactly be written to achieve the same effect as in AS2. The simplier it would be - the better.
Sorry fo my English.
// in watching class:
watchedClass.addEventListener("propertyChangedE",propertyChangedF);
private function propertyChangedF(e:Event):void{
// do whatever
// in watched class, dispatch event whenever changed from inside the class and from outside:
public function set someProperty(someValue:ValueType):void{
_someProperty=someValue;
dispatchEvent(new Event("propertyChangedE"));
I suppose that to change someProperty, I should use
setProperty ( target, someProperty , value);
I'd better add more details to the question:
MAIN_OBJ.array_1.push(4);
MAIN_OBJ.array_1.splice(1,1);
I think, in this case it is not possible to use setProperty
To tell the truth, bold words did not explain anything. I can read, may be I loose some meaning of sentence. Ok, here is the package, it has a mistake, because I don't understand what should be written there.
package {
public class Main {
import flash.events.*;
public function Main()
this.addEventListener("propertyChangedE",propertyChangedF);
trace("smth changed");
public function set MAIN_OBJ.array_1(someValue):void //???
MAIN_OBJ.array_1 = someValue;
public var MAIN_OBJ:Object = new Object();
it looks like you don't really understand how to use class files. there are numerous problems with those few lines of code.
i think you would be better off learning how to crawl before trying to run. i would recommend studying some of the basics of oop and class file structure.
so, i'm not sure how much this will help you, but you should use:
package {
import flash.events.EventDispatcher;
public class Main {
//the line below belongs elsewhere in the class where you want to detect a change
// this.addEventListener("propertyChangedE",propertyChangedF);
// dispatch event whenever changed from inside the class:
public function set AddArray_1(someValue):void
MAIN_OBJ.array_1.push(someValue);
//dispatch event whenever changed from outside:
I've learnt much of that AS3, and don't still understand, why simple things in one line on AS2 turned out to be a scope of user defined functions on AS3.
Let's go by steps:
1) I've created new Object, added some properties there.
3) I added a function, which EventListener would call each time the property changed
4) I added some new values to our property (.push(4)), so in AS2 it would make EventListener run its function.
That makes sense, isn't it ?
And still there are questions:
1) If I do smth with object's property, I should always call dispatchEvent after that?
2) //the line below belongs elsewhere in the class where you want to detect a change
I want to detect a change after setting basic properties. Can't I write it before .push(4) ?
3) I suppose we should mention MAIN_OBJ somewhere, because How EventListener would understand that MAIN_OBJ has changed?
There is no event that will fire off "automagically" when you change a property of an object.
Read what I said above a few times.
People here are telling you to make a function to change a property of the object. The reason why is because you can dispatch an event in the same function when you change that property.
That is the only way you will know when the property changes.
I'll say it again. Read line 1. There is no event that fires "automagically" when you change a property of an event.
That is programming 101. You create a "getter" and a "setter" function for the objects properties then you do whatever you want in those functions. For your needs, you want to dispatch an event. So do it, like has been mentioned.
Leave anything you ever learned in AS2 in the grave, where it belongs.
sinious, Thank you for the clear explanation.
You've said, I should create a "getter" and a "setter" function for the objects properties, so there is no way to do this
without writing "getter" and "setter" functions, and still catch this event? I think they just can't do the same. I suppose, you'll answer "just always write dispatch after that".
It seems like people never used that in AS2, never wanted to catch such events automatically, and AS3 just removed watch() for no need... that's strange.
