Hello,
On my fresh system (MacOS X fresh installed, LR 4.0 installed for a week), the "export with Previous" just does not work.
You can see o nthe screenshot. I exported the first picture using my preset "Web Extreme 2000px". Then the second pic using "export with previous". Unfortunatly, did not use my last preset but something like "Web medium".
Speaking with others LR users, they also noticed the same issue (on 3.x).
Could this be fix ?
In LR 4.1 rc1 it still does not work:
Loo at the grab. I exported once "_MG_5261.jpg" and then "export as previous" to another directory. Two differents presets were used. I think that LR only take in account the previous preset when you go trough the export Dialog box.
Is it so hard to fix ?
Please :-)
Hello,
Could you please try the following:
1: select a picture
2: right click, context menu: export -> Export... and select JPEG in the export dialog box
3: right click, context menu: export -> export TIFF (preset not in dialog box)
4: you get your file exported as 1 tiff and 1 jpeg.
5: delete every exported files
6: right click, context menu: export -> export wit previous
Which file do you get ?
From Lightroom Help:
You can export photos using the same settings from the most recent export session that was set manually, including modified presets. Otherwise, the Export With Previous command does not work with export presets.
Looks like it's the intended behaviour.
Nicolas Franck DET wrote:
Hello,
1: select a picture
1. Selected an image and chose to export it to my desktop as a JPEG.
2. Selected the same image and exported it to my desktop as a TIFF.
3. Using the same image, right-clicked and exported with previous after deleting both images from my desktop. Result was a TIFF image, as expected.
Works for me, not sure what you might be doing wrong or misunderstanding.I have never had a problem with "Export with previous." It is always used the settings that I last configured using the full export dialog. I have been using Lightroom since version 2, am currently using version 4.1.
You are exporting using the Export dialog window, right ? This way it works. But using the Menu it does not work.
"It is intended to export using exactly the same settings that were used previously, no changes." Exactly. Unfortunatly, it does not work this way. It only use the same settings when using the dialog window, not the menu. As a result, this function is buggy.
