Hi. Refiine edge is on and off unresponsive in reflecting changes I make in values in the dialog box. Mostly this is with smooth and feather functions. Also some of the views are only availible if I cycle through them with the "f" cycle comand and are unavalible by clicking.
I suppose the first thing we need to check is your video card and driver.
see this link for video cards that have veen tested: What features use the GPU and how do I troubleshoot GPU issues?
Then, go to the vendor of your card and ensure you have the latest driver.
Next, open Photoshop and go to help>system info and cut and paste your system info here and we'll take a look.
Let us know how it goes with the driver. If that is all well, we'll need to have a list of what you were doing when it became unresponsive...like the sequence of events if it is reproducable.
Pattie
This is my computer info and PS6 info below that. I use an external monitor for my tools/panels and images. thanks for you timely and helpful response! aloha, Uhane
Model Name: MacBook Pro
Model Identifier: MacBookPro7,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP71.0039.B0E
SMC Version (system): 1.62f6
Serial Number (system): XXXXX......etc
Hardware UUID: 38D20E76-F11B-5635-AEF4-DD8B9DAF1C66
Sudden Motion Sensor:
State: Enabled
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Mac OS 10.7.3
System architecture: Intel CPU Family:6, Model:23, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
Physical processor count: 2
Processor speed: 2400 MHz
Built-in memory: 4096 MB
Free memory: 2290 MB
Memory available to Photoshop: 3566 MB
Memory used by Photoshop: 70 %
Image tile size: 128K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 NVIDIA-7.18.11
OpenCL Unavailable
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: NVIDIA GeForce 320M OpenGL Engine
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 800, right: 1280
Video Renderer ID: 16918042
Video Card Memory: 238 MB
Video Rect Texture Size: 8192
Serial number: Tryout Version
Application folder: uhane's machine:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 232.1G, 140.5G free
Required Plug-ins folder: uhane's machine:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: uhane's machine:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 5.0.11.0 1.256674
AdobeACE.framework AdobeACE 2.19.18.19243 66.492997
AdobeAGM.framework AdobeAGM 4.26.17.19243 66.492997
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.19243 66.492997
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.492997
AdobeCoolType.framework AdobeCoolType 5.10.31.19243 66.492997
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120201
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 4.0.93 66.496052
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 6.0.0.1642
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.0.5.19287 145486
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1640
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Required plug-ins:
3D Studio 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 13.0 20120305.m.415 2012/03/05:21:00:00 ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 13.0 20120305.m.415 2012/03/05:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 13.0 20120305.m.415 2012/03/05:21:00:00 ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 13.0 20120305.m.415 2012/03/05:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Entropy 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 13.0 20120305.m.415 2012/03/05:21:00:00 ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 13.0 20120305.m.415 2012/03/05:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 13.0 20120305.m.415 2012/03/05:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 13.0 20120305.m.415 2012/03/05:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 13.0 20120305.m.415 2012/03/05:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 13.0 20120305.m.415 2012/03/05:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 13.0 20120305.m.415 2012/03/05:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 13.0 20120305.m.415 2012/03/05:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 13.0 20120305.m.415 2012/03/05:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
Mini Bridge
Kuler
Installed TWAIN devices: NONE
Hi Pattie, I just tried to use PS6 in the main window of my mac book. I did not test a lot of features but so far it's smooth and no probs although I did not try 3d yet. Will do that later. I went to the preferences to change some of the settings mentioned in the link below and found some of the options greyed out. see attached.Not sure what that implies. Hope this helps. aloha , U
Just adding list of Uhanepono's issues that are likely caused by the same culprit with video or other for our reference:
bug - dialog boxes extremely dark
opt/click buggy with layer mask
I did not see that you tried the GPU troubleshooting guide yet, please also try this and check all the above issue to see if it resolves any of them:
Pattie
Hi Pattie et al, Here I am trying again to send the screen shot of the greyed out advanced settings from inside yahoo mail itself. And I will try too from the forum. see if this time it gets through. This is the screen shot showing the greyed out options in the advanced settings. Perhaps CS6 may just be aggravating into manifestation an already present problem that CS5.1 skirted? Please tell me from my computer specs, there in the thread, If I should be able to use CS6 with advanced settings to use all the CS6 features and if there were no hardware problems and if these problem have not been reported by others with a similar setup. If I should be able to - then - I will call it a hardware problem and get me to a tech-erie forthwith (diagnostics @ mac store)!
If it helps at all - I have the steps from the last freeze out.
Launched CS6. Tried to follow along with Deke with the fotolia image library file with a gazillion layers of the baby and mom. In layers panel changed the search criteria kind/mode/select all/. It took a long time to write PSD doc then reverted with F12. It took an even longer time to revert. After I let it run for a time without touching anything. I opened one of Deke's extruded text docs. Things were slowing down at this point. I opened the properties panel and lost cursor response, then keystroke response and then the beach ball of death was upon me. Force quit CS6. It froze in place and then the rest of the computer followed suit. Opt/com/esc became unresponsive. I forced computer to shut down and have decided perhaps something beyond CS6 is to blame. The external monitor was not an issue this time so it's not that. So I do need to determine if my computer specs are up to snuff for the demands of this app. You can see them there in the thread
and can let me know, yes? If you tell me it should be able to take the load - then - I will get me to a tech-erie forthwith! If you tell me they are not I will...deal with it. I will not launch CS6 beta again till I hear from you'all. I thank you all very much, aloha, Uhane
Thank you for the screen shot. You must be on the forum to post those as you have seen. So you now see the place to change your setting. One thing I asked you to try above was to change this advanced setting to basic, close Photoshop, and see if any of the problems go away.IF they do go away, then try setting it to normal and exit and restart Photoshop and see if problems stay away.IF so, use this setting, if not, use basic setting. If neither help, please let me know.
I also asked you to try resetting your preferenes. To do this, press and hold Ctrl+Alt+Shift (Windows) or Option+Command+
Shift (Mac OS) immediately after you start Photoshop. See if this helps your issues. After any of these Photoshop changes, please exit and and restart Photoshop before testing.
Let me know what happens, whether any of your issues listed in the earlier post get better.
Pattie
<quote>
Re: bug - refine edge Which options were greyed out?...a likely clue...
Pattie
<endquote>
Hi Pattie, Sorry, I failed to mention having taken those steps in the previous post. As the settings are, for some time now, I am down to "basic" setting. I saw my GPU listed as having been tested
( NVIDIA GeForce 320M 256 MB) in the list. (Is 256mb Fast enough?)
I did these things the first time you posted the instructions for me. ISome of them twice. As you can see in the Advanced setting tab screen shot there are 2 items greyed out as inactive. They should be active, no? These were items you said might give a clue. Hope this helps. I browsed through the forum and now see others are reporting similar issues to mine. I hope the brakdown of what I was doing when CS6 froze helps too. thanks, aloha, Uhane
Hi Pattie I have added more screen shots and more info on my system on the thread
Hi Pattie et al, I Just ran diagnostics on the external monitor and it came up clean, uninstalled the CS6 (had to go iinto library to fetch stray files). and restared computer and opened CS5.1. It's running flawlessly and very fast as it did before. Graphics in playback on other apps (like VLC and FCPX) are a bit more smooth since the CS6 unistall too. I will still be going in for the mac video card diagnostics on Monday but wanted to let you now. Also I have info on my external monitor that may help. It is aSamsung syncmaster 204B, model code (?) # LS20BRDBBV/XAA. I went to the samsing site to see what up with that but there were no problem posted. I know it's a bit old but not SO old as to not work. It's done me proud so far. If it's too old for CS6 and it's time for an ungrade I can face that too. I have plenty of windowsXP junkie friends who would love it.
HI Pattie, Chris et al, I just got my macbook pro back from the mac store after leaving it there to run full diagnostic, in particular, the GPU. It came back with a clean bill of health. I wanted to eliminate that as a culprit. I have had CS6 Uninstalled for a few days and the system is back to normal. These problems in CS6 I had been explaing are only present in CS6. So.. I will wait for release date get that. I have to stop the beta testing as it's causing too many problems for CS5.1.
