Hey Folks,
How do I create an editable field in a template so that I can add <Title> and meta descriptions to individual pages? Many Thanks for the help, I'm not the most skilled coder!
john
The field "Page Title" is used in the <title> tag. In V2 there there was an option to add a meta description but I don't see it in V3. Not ideal but you should be able to add it in the html view of the page content and BC will move it to the head for you on the live site.
Brian - BCGurus.com - http://bcgurus.com/Business-Catalyst-Templates for only $7
Yes and no, be very careful.
- Using that will add head and body html to your page content even if you use a template. Check out the html. Not good.
- If you add a description, remove it and add it again or edit it you get empty description tags inserted into the head above the current description meta.
- If you/client has used the Old interface meta stuff then use that it will add to your meta not change it.
- Page Title for pages, products etc is not synced with that inline on a page/product name/web app name and so changing that will either double up again or not update the title depending on what your in be it a page or product.
^ That is just a few of the more obvious issues with that.
So keep that in mind ![]()
