[Ann] HTML/CHM for CS6 Javascript
Apr 27, 2012 4:39 PM
Tags: #javascript #extendscript #cs6 #automation
I don't think I've ever been so fast before:
http://www.jongware.com/idjshelp.html is updated, it now also contains my Friendly Help for CS6, as both HTML (separate files) and CHM (one compiled file for use with a Windows Help viewer).
By way of experiment I added a "Full Index" to the HTML version. This is a single huge file, 2.7MB, but it contains links to all properties and methods in the entire set of files. So if you can't use the live one in the compiled CHM, you can still use this one to get a good overview of What to find Where.
... Enjoy!
    Apr 27, 2012 4:48 PM   in reply to [Jongware]
    Jognware,
    Thanks for that. Would it be possible for you to do a difference list, that is, to do a list with "what's new in CS6"? New properties, methods, and enumerations? I did a few of those in the past but it has become a bit of a hassle in recent years.
    Peter
  • John Hawkinson
    Jun 25, 2009
    Apr 27, 2012 9:45 PM   in reply to [Jongware]
    Yeah, it's been on my list before. I believe what you want to do is just produce a file with the suite and class for all properties. You know:
    Basics     Application     activeBook
    Basics     Application     activeDocument
    and then sort them and compare with diff. Similarly for the methods and enumerations and whatnot.
    And I guess we could skip the suite, since it's not as easy in the XSLT since you'd have to look it up in the <map/> rather than just noting the parent properties in the <package/>.
    Maybe I'll be enthused to try this before my idea of when Jongware wakes up :-)
  • John Hawkinson
    Jun 25, 2009
    Apr 27, 2012 10:54 PM   in reply to John Hawkinson
    Right. So, here's some XSLT:
    <?xml version="1.0" encoding="UTF-8"?>
    <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
      <xsl:output method="text"/>
      <xsl:template match="text()|@*"/> <!-- Suppress default text output -->
      <xsl:template match="property|method">
        <xsl:call-template name="list-name-and-grandparent-name-with-tabs"/>
      </xsl:template>
      <xsl:template name="list-name-and-grandparent-name-with-tabs">
        <xsl:value-of select="name()"/>
        <xsl:if test="../../@enumeration">(enum)</xsl:if>
        <xsl:text>&#9;</xsl:text>
        <xsl:value-of select="name()"/><xsl:text>&#9;</xsl:text>
        <xsl:value-of select="../../@name"/><xsl:text>&#9;</xsl:text>
        <xsl:value-of select="@name"/><xsl:text>&#9;</xsl:text>
        <xsl:text>&#10;</xsl:text>
      </xsl:template>
    </xsl:stylesheet>
    Hopefully it's self-explanatory. I even added the "(enum)" to distinguish enums from regular properties. Just for you, Peter K!
    Then we just run it on the omv cachefiles, sort the output, and do some comparisons with "comm."
    That is:
    xsltproc omv.xsl omv\$indesign-7.5\$7.5.xml | sort > 7575.txt
    xsltproc omv.xsl omv\$indesign-8.0\$8.0.xml | sort > 8080.txt
    I hope it's not a dumb idea to put this all in one long post...
    For instance, the following 29 items were removed from CS5.5 to CS6 (comm -23 7575.txt 8080.txt):
    propertyButtonvisibilityInPdf
    propertyDocumentPreferencemasterTextFrame
    propertyDocumentPresetmasterTextFrame
    propertyEPubExportPreferencecssExportOption
    propertyEPubExportPreferenceexternalCSSPath
    propertyEPubExportPreferenceformat
    propertyEPubExportPreferencemarginUnit
    propertyEPubExportPreferencespaceUnit
    propertyEPubExportPreferenceuseTocStyle
    propertyHTMLExportPreferencebottomMargin
    propertyHTMLExportPreferenceexternalCSSPath
    propertyHTMLExportPreferencejavascriptURL
    propertyHTMLExportPreferenceleftMargin
    propertyHTMLExportPreferencelinkToJavascript
    propertyHTMLExportPreferencemarginUnit
    propertyHTMLExportPreferencerightMargin
    propertyHTMLExportPreferencespaceUnit
    propertyHTMLExportPreferencetopMargin
    propertyObjectExportOptioncustomImageAlignment
    propertyObjectExportOptionspaceUnit
    propertyPagesPanelverticalView
    property(enum)SpaceUnitTypeCSS_EM
    property(enum)SpaceUnitTypeCSS_PIXEL
    property(enum)StyleSheetExportOptionEXTERNAL_CSS
    property(enum)StyleSheetExportOptionSTYLE_NAME_ONLY
    property(enum)VisibilityInPdfHIDDEN_BUT_PRINTABLE_IN_PDF
    property(enum)VisibilityInPdfHIDDEN_IN_PDF
    property(enum)VisibilityInPdfVISIBLE_BUT_DOES_NOT_PRINT_IN_PDF
    property(enum)VisibilityInPdfVISIBLE_IN_PDF
    And the following 1,984 were added in CS6 (comm -13 7575.txt 8080.txt):
    methodButtoncontentPlace
    methodCellStyleMappingaddEventListener
    methodCellStyleMappinggetElements
    methodCellStyleMappingremove
    methodCellStyleMappingremoveEventListener
    methodCellStyleMappingtoSource
    methodCellStyleMappingtoSpecifier
    methodCellStyleMappings[]
    methodCellStyleMappingsadd
    methodCellStyleMappingsanyItem
    methodCellStyleMappingscount
    methodCellStyleMappingseveryItem
    methodCellStyleMappingsfirstItem
    methodCellStyleMappingsitem
    methodCellStyleMappingsitemByRange
    methodCellStyleMappingslastItem
    methodCellStyleMappingsmiddleItem
    methodCellStyleMappingsnextItem
    methodCellStyleMappingspreviousItem
    methodCellStyleMappingstoSource
    methodCharStyleMappingaddEventListener
    methodCharStyleMappinggetElements
    methodCharStyleMappingremove
    methodCharStyleMappingremoveEventListener
    methodCharStyleMappingtoSource
    methodCharStyleMappingtoSpecifier
    methodCharStyleMappings[]
    methodCharStyleMappingsadd
    methodCharStyleMappingsanyItem
    methodCharStyleMappingscount
    methodCharStyleMappingseveryItem
    methodCharStyleMappingsfirstItem
    methodCharStyleMappingsitem
    methodCharStyleMappingsitemByRange
    methodCharStyleMappingslastItem
    methodCharStyleMappingsmiddleItem
    methodCharStyleMappingsnextItem
    methodCharStyleMappingspreviousItem
    methodCharStyleMappingstoSource
    methodCheckBoxaddEventListener
    methodCheckBoxapplyObjectStyle
    methodCheckBoxasynchronousExportFile
    methodCheckBoxautoTag
    methodCheckBoxbringForward
    methodCheckBoxbringToFront
    methodCheckBoxchangeObject
    methodCheckBoxclearObjectStyleOverrides
    methodCheckBoxclearTransformations
    methodCheckBoxcontentPlace
    methodCheckBoxconvertShape
    methodCheckBoxconvertToObject
    methodCheckBoxdetach
    methodCheckBoxduplicate
    methodCheckBoxexportFile
    methodCheckBoxextractLabel
    methodCheckBoxfindObject
    methodCheckBoxfit
    methodCheckBoxflipItem
    methodCheckBoxgetElements
    methodCheckBoxinsertLabel
    methodCheckBoxmarkup
    methodCheckBoxmove
    methodCheckBoxoverride
    methodCheckBoxplaceXML
    methodCheckBoxredefineScaling
    methodCheckBoxreframe
    methodCheckBoxremove
    methodCheckBoxremoveEventListener
    methodCheckBoxremoveOverride
    methodCheckBoxresize
    methodCheckBoxresolve
    methodCheckBoxselect
    methodCheckBoxsendBackward
    methodCheckBoxsendToBack
    methodCheckBoxstore
    methodCheckBoxtoSource
    methodCheckBoxtoSpecifier
    methodCheckBoxtransform
    methodCheckBoxtransformAgain
    methodCheckBoxtransformAgainIndividually
    methodCheckBoxtransformSequenceAgain
    methodCheckBoxtransformSequenceAgainIndividually
    methodCheckBoxtransformValuesOf
    methodCheckBoxes[]
    methodCheckBoxesadd
    methodCheckBoxesanyItem
    methodCheckBoxescount
    methodCheckBoxeseveryItem
    methodCheckBoxesfirstItem
    methodCheckBoxesitem
    methodCheckBoxesitemByID
    methodCheckBoxesitemByName
    methodCheckBoxesitemByRange
    methodCheckBoxeslastItem
    methodCheckBoxesmiddleItem
    methodCheckBoxesnextItem
    methodCheckBoxespreviousItem
    methodCheckBoxestoSource
    methodClearFormBehavioraddEventListener
    methodClearFormBehaviorextractLabel
    methodClearFormBehaviorgetElements
    methodClearFormBehaviorinsertLabel
    methodClearFormBehaviorremove
    methodClearFormBehaviorremoveEventListener
    methodClearFormBehaviortoSource
    methodClearFormBehaviortoSpecifier
    methodClearFormBehaviors[]
    methodClearFormBehaviorsadd
    methodClearFormBehaviorsanyItem
    methodClearFormBehaviorscount
    methodClearFormBehaviorseveryItem
    methodClearFormBehaviorsfirstItem
    methodClearFormBehaviorsitem
    methodClearFormBehaviorsitemByID
    methodClearFormBehaviorsitemByName
    methodClearFormBehaviorsitemByRange
    methodClearFormBehaviorslastItem
    methodClearFormBehaviorsmiddleItem
    methodClearFormBehaviorsnextItem
    methodClearFormBehaviorspreviousItem
    methodClearFormBehaviorstoSource
    methodComboBoxaddEventListener
    methodComboBoxapplyObjectStyle
    methodComboBoxasynchronousExportFile
    methodComboBoxautoTag
    methodComboBoxbringForward
    methodComboBoxbringToFront
    methodComboBoxchangeObject
    methodComboBoxclearObjectStyleOverrides
    methodComboBoxclearTransformations
    methodComboBoxcontentPlace
    methodComboBoxconvertShape
    methodComboBoxconvertToObject
    methodComboBoxdetach
    methodComboBoxduplicate
    methodComboBoxexportFile
    methodComboBoxextractLabel
    methodComboBoxfindObject
    methodComboBoxfit
    methodComboBoxflipItem
    methodComboBoxgetElements
    methodComboBoxinsertLabel
    methodComboBoxmarkup
    methodComboBoxmove
    methodComboBoxoverride
    methodComboBoxplaceXML
    methodComboBoxredefineScaling
    methodComboBoxreframe
    methodComboBoxremove
    methodComboBoxremoveEventListener
    methodComboBoxremoveOverride
    methodComboBoxresize
    methodComboBoxresolve
    methodComboBoxselect
    methodComboBoxsendBackward
    methodComboBoxsendToBack
    methodComboBoxstore
    methodComboBoxtoSource
    methodComboBoxtoSpecifier
    methodComboBoxtransform
    methodComboBoxtransformAgain
    methodComboBoxtransformAgainIndividually
    methodComboBoxtransformSequenceAgain
    methodComboBoxtransformSequenceAgainIndividually
    methodComboBoxtransformValuesOf
    methodComboBoxes[]
    methodComboBoxesadd
    methodComboBoxesanyItem
    methodComboBoxescount
    methodComboBoxeseveryItem
    methodComboBoxesfirstItem
    methodComboBoxesitem
    methodComboBoxesitemByID
    methodComboBoxesitemByName
    methodComboBoxesitemByRange
    methodComboBoxeslastItem
    methodComboBoxesmiddleItem
    methodComboBoxesnextItem
    methodComboBoxespreviousItem
    methodComboBoxestoSource
    methodContentPlacerObjectaddEventListener
    methodContentPlacerObjectgetElements
    methodContentPlacerObjectload
    methodContentPlacerObjectremoveEventListener
    methodContentPlacerObjecttoSource
    methodContentPlacerObjecttoSpecifier
    methodDocumentcreateAlternateLayout
    methodDocumentdeleteAlternateLayout
    methodEPScontentPlace
    methodEPSTextcontentPlace
    methodFontLockingPreferenceaddEventListener
    methodFontLockingPreferencegetElements
    methodFontLockingPreferenceremoveEventListener
    methodFontLockingPreferencetoSource
    methodFontLockingPreferencetoSpecifier
    methodFormFieldcontentPlace
    methodGraphiccontentPlace
    methodGraphicLinecontentPlace
    methodGroupcontentPlace
    methodGuideresolve
    methodGuidetransformValuesOf
    methodHtmlItemaddEventListener
    methodHtmlItemapplyObjectStyle
    methodHtmlItemasynchronousExportFile
    methodHtmlItemautoTag
    methodHtmlItemchangeObject
    methodHtmlItemclearObjectStyleOverrides
    methodHtmlItemclearTransformations
    methodHtmlItemcontentPlace
    methodHtmlItemconvertShape
    methodHtmlItemdetach
    methodHtmlItemduplicate
    methodHtmlItemexportFile
    methodHtmlItemextractLabel
    methodHtmlItemfindObject
    methodHtmlItemfit
    methodHtmlItemflipItem
    methodHtmlItemgetElements
    methodHtmlIteminsertLabel
    methodHtmlItemmarkup
    methodHtmlItemmove
    methodHtmlItemoverride
    methodHtmlItemplace
    methodHtmlItemplaceXML
    methodHtmlItemredefineScaling
    methodHtmlItemreframe
    methodHtmlItemremove
    methodHtmlItemremoveEventListener
    methodHtmlItemremoveOverride
    methodHtmlItemresize
    methodHtmlItemresolve
    methodHtmlItemselect
    methodHtmlItemstore
    methodHtmlItemtoSource
    methodHtmlItemtoSpecifier
    methodHtmlItemtransform
    methodHtmlItemtransformAgain
    methodHtmlItemtransformAgainIndividually
    methodHtmlItemtransformSequenceAgain
    methodHtmlItemtransformSequenceAgainIndividually
    methodHtmlItemtransformValuesOf
    methodHtmlItems[]
    methodHtmlItemsadd
    methodHtmlItemsanyItem
    methodHtmlItemscount
    methodHtmlItemseveryItem
    methodHtmlItemsfirstItem
    methodHtmlItemsitem
    methodHtmlItemsitemByID
    methodHtmlItemsitemByName
    methodHtmlItemsitemByRange
    methodHtmlItemslastItem
    methodHtmlItemsmiddleItem
    methodHtmlItemsnextItem
    methodHtmlItemspreviousItem
    methodHtmlItemstoSource
    methodImagecontentPlace
    methodImportedPagecontentPlace
    methodLinkgoToSource
    methodLinkedPageItemOptionaddEventListener
    methodLinkedPageItemOptiongetElements
    methodLinkedPageItemOptionremoveEventListener
    methodLinkedPageItemOptiontoSource
    methodLinkedPageItemOptiontoSpecifier
    methodListBoxaddEventListener
    methodListBoxapplyObjectStyle
    methodListBoxasynchronousExportFile
    methodListBoxautoTag
    methodListBoxbringForward
    methodListBoxbringToFront
    methodListBoxchangeObject
    methodListBoxclearObjectStyleOverrides
    methodListBoxclearTransformations
    methodListBoxcontentPlace
    methodListBoxconvertShape
    methodListBoxconvertToObject
    methodListBoxdetach
    methodListBoxduplicate
    methodListBoxexportFile
    methodListBoxextractLabel
    methodListBoxfindObject
    methodListBoxfit
    methodListBoxflipItem
    methodListBoxgetElements
    methodListBoxinsertLabel
    methodListBoxmarkup
    methodListBoxmove
    methodListBoxoverride
    methodListBoxplaceXML
    methodListBoxredefineScaling
    methodListBoxreframe
    methodListBoxremove
    methodListBoxremoveEventListener
    methodListBoxremoveOverride
    methodListBoxresize
    methodListBoxresolve
    methodListBoxselect
    methodListBoxsendBackward
    methodListBoxsendToBack
    methodListBoxstore
    methodListBoxtoSource
    methodListBoxtoSpecifier
    methodListBoxtransform
    methodListBoxtransformAgain
    methodListBoxtransformAgainIndividually
    methodListBoxtransformSequenceAgain
    methodListBoxtransformSequenceAgainIndividually
    methodListBoxtransformValuesOf
    methodListBoxes[]
    methodListBoxesadd
    methodListBoxesanyItem
    methodListBoxescount
    methodListBoxeseveryItem
    methodListBoxesfirstItem
    methodListBoxesitem
    methodListBoxesitemByID
    methodListBoxesitemByName
    methodListBoxesitemByRange
    methodListBoxeslastItem
    methodListBoxesmiddleItem
    methodListBoxesnextItem
    methodListBoxespreviousItem
    methodListBoxestoSource
    methodMasterSpreadcontentPlace
    methodMediaItemcontentPlace
    methodMoviecontentPlace
    methodMultiStateObjectcontentPlace
    methodOvalcontentPlace
    methodPDFcontentPlace
    methodPICTcontentPlace
    methodPNGExportPreferenceaddEventListener
    methodPNGExportPreferencegetElements
    methodPNGExportPreferenceremoveEventListener
    methodPNGExportPreferencetoSource
    methodPNGExportPreferencetoSpecifier
    methodPagecontentPlace
    methodPagedeleteAllLayoutSnapshots
    methodPagedeleteLayoutSnapshot
    methodPagesnapshotCurrentLayout
    methodPageItemcontentPlace
    methodParaStyleMappingaddEventListener
    methodParaStyleMappinggetElements
    methodParaStyleMappingremove
    methodParaStyleMappingremoveEventListener
    methodParaStyleMappingtoSource
    methodParaStyleMappingtoSpecifier
    methodParaStyleMappings[]
    methodParaStyleMappingsadd
    methodParaStyleMappingsanyItem
    methodParaStyleMappingscount
    methodParaStyleMappingseveryItem
    methodParaStyleMappingsfirstItem
    methodParaStyleMappingsitem
    methodParaStyleMappingsitemByRange
    methodParaStyleMappingslastItem
    methodParaStyleMappingsmiddleItem
    methodParaStyleMappingsnextItem
    methodParaStyleMappingspreviousItem
    methodParaStyleMappingstoSource
    methodPolygoncontentPlace
    methodPrintFormBehavioraddEventListener
    methodPrintFormBehaviorextractLabel
    methodPrintFormBehaviorgetElements
    methodPrintFormBehaviorinsertLabel
    methodPrintFormBehaviorremove
    methodPrintFormBehaviorremoveEventListener
    methodPrintFormBehaviortoSource
    methodPrintFormBehaviortoSpecifier
    methodPrintFormBehaviors[]
    methodPrintFormBehaviorsadd
    methodPrintFormBehaviorsanyItem
    methodPrintFormBehaviorscount
    methodPrintFormBehaviorseveryItem
    methodPrintFormBehaviorsfirstItem
    methodPrintFormBehaviorsitem
    methodPrintFormBehaviorsitemByID
    methodPrintFormBehaviorsitemByName
    methodPrintFormBehaviorsitemByRange
    methodPrintFormBehaviorslastItem
    methodPrintFormBehaviorsmiddleItem
    methodPrintFormBehaviorsnextItem
    methodPrintFormBehaviorspreviousItem
    methodPrintFormBehaviorstoSource
    methodRadioButtonaddEventListener
    methodRadioButtonapplyObjectStyle
    methodRadioButtonasynchronousExportFile
    methodRadioButtonautoTag
    methodRadioButtonbringForward
    methodRadioButtonbringToFront
    methodRadioButtonchangeObject
    methodRadioButtonclearObjectStyleOverrides
    methodRadioButtonclearTransformations
    methodRadioButtoncontentPlace
    methodRadioButtonconvertShape
    methodRadioButtonconvertToObject
    methodRadioButtondetach
    methodRadioButtonduplicate
    methodRadioButtonexportFile
    methodRadioButtonextractLabel
    methodRadioButtonfindObject
    methodRadioButtonfit
    methodRadioButtonflipItem
    methodRadioButtongetElements
    methodRadioButtoninsertLabel
    methodRadioButtonmarkup
    methodRadioButtonmove
    methodRadioButtonoverride
    methodRadioButtonplaceXML
    methodRadioButtonredefineScaling
    methodRadioButtonreframe
    methodRadioButtonremove
    methodRadioButtonremoveEventListener
    methodRadioButtonremoveOverride
    methodRadioButtonresize
    methodRadioButtonresolve
    methodRadioButtonselect
    methodRadioButtonsendBackward
    methodRadioButtonsendToBack
    methodRadioButtonstore
    methodRadioButtontoSource
    methodRadioButtontoSpecifier
    methodRadioButtontransform
    methodRadioButtontransformAgain
    methodRadioButtontransformAgainIndividually
    methodRadioButtontransformSequenceAgain
    methodRadioButtontransformSequenceAgainIndividually
    methodRadioButtontransformValuesOf
    methodRadioButtons[]
    methodRadioButtonsadd
    methodRadioButtonsanyItem
    methodRadioButtonscount
    methodRadioButtonseveryItem
    methodRadioButtonsfirstItem
    methodRadioButtonsitem
    methodRadioButtonsitemByID
    methodRadioButtonsitemByName
    methodRadioButtonsitemByRange
    methodRadioButtonslastItem
    methodRadioButtonsmiddleItem
    methodRadioButtonsnextItem
    methodRadioButtonspreviousItem
    methodRadioButtonstoSource
    methodRectanglecontentPlace
    methodSignatureFieldaddEventListener
    methodSignatureFieldapplyObjectStyle
    methodSignatureFieldasynchronousExportFile
    methodSignatureFieldautoTag
    methodSignatureFieldbringForward
    methodSignatureFieldbringToFront
    methodSignatureFieldchangeObject
    methodSignatureFieldclearObjectStyleOverrides
    methodSignatureFieldclearTransformations
    methodSignatureFieldcontentPlace
    methodSignatureFieldconvertShape
    methodSignatureFieldconvertToObject
    methodSignatureFielddetach
    methodSignatureFieldduplicate
    methodSignatureFieldexportFile
    methodSignatureFieldextractLabel
    methodSignatureFieldfindObject
    methodSignatureFieldfit
    methodSignatureFieldflipItem
    methodSignatureFieldgetElements
    methodSignatureFieldinsertLabel
    methodSignatureFieldmarkup
    methodSignatureFieldmove
    methodSignatureFieldoverride
    methodSignatureFieldplaceXML
    methodSignatureFieldredefineScaling
    methodSignatureFieldreframe
    methodSignatureFieldremove
    methodSignatureFieldremoveEventListener
    methodSignatureFieldremoveOverride
    methodSignatureFieldresize
    methodSignatureFieldresolve
    methodSignatureFieldselect
    methodSignatureFieldsendBackward
    methodSignatureFieldsendToBack
    methodSignatureFieldstore
    methodSignatureFieldtoSource
    methodSignatureFieldtoSpecifier
    methodSignatureFieldtransform
    methodSignatureFieldtransformAgain
    methodSignatureFieldtransformAgainIndividually
    methodSignatureFieldtransformSequenceAgain
    methodSignatureFieldtransformSequenceAgainIndividually
    methodSignatureFieldtransformValuesOf
    methodSignatureFields[]
    methodSignatureFieldsadd
    methodSignatureFieldsanyItem
    methodSignatureFieldscount
    methodSignatureFieldseveryItem
    methodSignatureFieldsfirstItem
    methodSignatureFieldsitem
    methodSignatureFieldsitemByID
    methodSignatureFieldsitemByName
    methodSignatureFieldsitemByRange
    methodSignatureFieldslastItem
    methodSignatureFieldsmiddleItem
    methodSignatureFieldsnextItem
    methodSignatureFieldspreviousItem
    methodSignatureFieldstoSource
    methodSoundcontentPlace
    methodSplineItemcontentPlace
    methodSpreadcontentPlace
    methodSubmitFormBehavioraddEventListener
    methodSubmitFormBehaviorextractLabel
    methodSubmitFormBehaviorgetElements
    methodSubmitFormBehaviorinsertLabel
    methodSubmitFormBehaviorremove
    methodSubmitFormBehaviorremoveEventListener
    methodSubmitFormBehaviortoSource
    methodSubmitFormBehaviortoSpecifier
    methodSubmitFormBehaviors[]
    methodSubmitFormBehaviorsadd
    methodSubmitFormBehaviorsanyItem
    methodSubmitFormBehaviorscount
    methodSubmitFormBehaviorseveryItem
    methodSubmitFormBehaviorsfirstItem
    methodSubmitFormBehaviorsitem
    methodSubmitFormBehaviorsitemByID
    methodSubmitFormBehaviorsitemByName
    methodSubmitFormBehaviorsitemByRange
    methodSubmitFormBehaviorslastItem
    methodSubmitFormBehaviorsmiddleItem
    methodSubmitFormBehaviorsnextItem
    methodSubmitFormBehaviorspreviousItem
    methodSubmitFormBehaviorstoSource
    methodTableStyleMappingaddEventListener
    methodTableStyleMappinggetElements
    methodTableStyleMappingremove
    methodTableStyleMappingremoveEventListener
    methodTableStyleMappingtoSource
    methodTableStyleMappingtoSpecifier
    methodTableStyleMappings[]
    methodTableStyleMappingsadd
    methodTableStyleMappingsanyItem
    methodTableStyleMappingscount
    methodTableStyleMappingseveryItem
    methodTableStyleMappingsfirstItem
    methodTableStyleMappingsitem
    methodTableStyleMappingsitemByRange
    methodTableStyleMappingslastItem
    methodTableStyleMappingsmiddleItem
    methodTableStyleMappingsnextItem
    methodTableStyleMappingspreviousItem
    methodTableStyleMappingstoSource
    methodTextBoxaddEventListener
    methodTextBoxapplyObjectStyle
    methodTextBoxasynchronousExportFile
    methodTextBoxautoTag
    methodTextBoxbringForward
    methodTextBoxbringToFront
    methodTextBoxchangeObject
    methodTextBoxclearObjectStyleOverrides
    methodTextBoxclearTransformations
    methodTextBoxcontentPlace
    methodTextBoxconvertShape
    methodTextBoxconvertToObject
    methodTextBoxdetach
    methodTextBoxduplicate
    methodTextBoxexportFile
    methodTextBoxextractLabel
    methodTextBoxfindObject
    methodTextBoxfit
    methodTextBoxflipItem
    methodTextBoxgetElements
    methodTextBoxinsertLabel
    methodTextBoxmarkup
    methodTextBoxmove
    methodTextBoxoverride
    methodTextBoxplaceXML
    methodTextBoxredefineScaling
    methodTextBoxreframe
    methodTextBoxremove
    methodTextBoxremoveEventListener
    methodTextBoxremoveOverride
    methodTextBoxresize
    methodTextBoxresolve
    methodTextBoxselect
    methodTextBoxsendBackward
    methodTextBoxsendToBack
    methodTextBoxstore
    methodTextBoxtoSource
    methodTextBoxtoSpecifier
    methodTextBoxtransform
    methodTextBoxtransformAgain
    methodTextBoxtransformAgainIndividually
    methodTextBoxtransformSequenceAgain
    methodTextBoxtransformSequenceAgainIndividually
    methodTextBoxtransformValuesOf
    methodTextBoxes[]
    methodTextBoxesadd
    methodTextBoxesanyItem
    methodTextBoxescount
    methodTextBoxeseveryItem
    methodTextBoxesfirstItem
    methodTextBoxesitem
    methodTextBoxesitemByID
    methodTextBoxesitemByName
    methodTextBoxesitemByRange
    methodTextBoxeslastItem
    methodTextBoxesmiddleItem
    methodTextBoxesnextItem
    methodTextBoxespreviousItem
    methodTextBoxestoSource
    methodTextFramecontentPlace
    methodWMFcontentPlace
    propertyApplicationcellStyleMappings
    propertyApplicationcharStyleMappings
    propertyApplicationcontentPlacer
    propertyApplicationfontLockingPreferences
    propertyApplicationlinkedPageItemOptions
    propertyApplicationparaStyleMappings
    propertyApplicationpngExportPreferences
    propertyApplicationselectionKeyObject
    propertyApplicationtableStyleMappings
    propertyButtonclearFormBehaviors
    propertyButtonhiddenUntilTriggered
    propertyButtonhorizontalLayoutConstraints
    propertyButtonlinkedPageItemOptions
    propertyButtonprintFormBehaviors
    propertyButtonprintableInPdf
    propertyButtonsubmitFormBehaviors
    propertyButtonverticalLayoutConstraints
    propertyCellcheckBoxes
    propertyCellcomboBoxes
    propertyCelllistBoxes
    propertyCellradioButtons
    propertyCellsignatureFields
    propertyCelltextBoxes
    propertyCellStyleMappingdestinationStyleName
    propertyCellStyleMappingeventListeners
    propertyCellStyleMappingevents
    propertyCellStyleMappingindex
    propertyCellStyleMappingisValid
    propertyCellStyleMappingmappingRuleType
    propertyCellStyleMappingparent
    propertyCellStyleMappingproperties
    propertyCellStyleMappingsourceStyleName
    propertyCellStyleMappingslength
    propertyChangeGrepPreferenceparagraphKashidaWidth
    propertyChangeObjectPreferenceautoSizingReferencePoint
    propertyChangeObjectPreferenceautoSizingType
    propertyChangeObjectPreferenceminimumHeightForAutoSizing
    propertyChangeObjectPreferenceminimumWidthForAutoSizing
    propertyChangeObjectPreferenceuseMinimumHeightForAutoSizing
    propertyChangeObjectPreferenceuseMinimumWidthForAutoSizing
    propertyChangeObjectPreferenceuseNoLineBreaksForAutoSizing
    propertyChangeTextPreferenceparagraphKashidaWidth
    propertyCharStyleMappingdestinationStyleName
    propertyCharStyleMappingeventListeners
    propertyCharStyleMappingevents
    propertyCharStyleMappingindex
    propertyCharStyleMappingisValid
    propertyCharStyleMappingmappingRuleType
    propertyCharStyleMappingparent
    propertyCharStyleMappingproperties
    propertyCharStyleMappingsourceStyleName
    propertyCharStyleMappingslength
    propertyCharactercheckBoxes
    propertyCharactercomboBoxes
    propertyCharacterlistBoxes
    propertyCharacterparagraphKashidaWidth
    propertyCharacterradioButtons
    propertyCharactersignatureFields
    propertyCharactertextBoxes
    propertyCheckBoxAFTER_PLACE
    propertyCheckBoxBEFORE_PLACE
    propertyCheckBoxabsoluteFlip
    propertyCheckBoxabsoluteHorizontalScale
    propertyCheckBoxabsoluteRotationAngle
    propertyCheckBoxabsoluteShearAngle
    propertyCheckBoxabsoluteVerticalScale
    propertyCheckBoxactiveStateIndex
    propertyCheckBoxallArticles
    propertyCheckBoxallGraphics
    propertyCheckBoxallPageItems
    propertyCheckBoxallowOverrides
    propertyCheckBoxanchoredObjectSettings
    propertyCheckBoxanimationSettings
    propertyCheckBoxappliedObjectStyle
    propertyCheckBoxassociatedXMLElement
    propertyCheckBoxbehaviors
    propertyCheckBoxbottomLeftCornerOption
    propertyCheckBoxbottomLeftCornerRadius
    propertyCheckBoxbottomRightCornerOption
    propertyCheckBoxbottomRightCornerRadius
    propertyCheckBoxcheckedByDefault
    propertyCheckBoxclearFormBehaviors
    propertyCheckBoxcontentTransparencySettings
    propertyCheckBoxdescription
    propertyCheckBoxendCap
    propertyCheckBoxendJoin
    propertyCheckBoxepss
    propertyCheckBoxepstexts
    propertyCheckBoxeventListeners
    propertyCheckBoxevents
    propertyCheckBoxexportValue
    propertyCheckBoxfillColor
    propertyCheckBoxfillTint
    propertyCheckBoxfillTransparencySettings
    propertyCheckBoxflip
    propertyCheckBoxgapColor
    propertyCheckBoxgapTint
    propertyCheckBoxgeometricBounds
    propertyCheckBoxgotoAnchorBehaviors
    propertyCheckBoxgotoFirstPageBehaviors
    propertyCheckBoxgotoLastPageBehaviors
    propertyCheckBoxgotoNextPageBehaviors
    propertyCheckBoxgotoNextViewBehaviors
    propertyCheckBoxgotoPreviousPageBehaviors
    propertyCheckBoxgotoPreviousViewBehaviors
    propertyCheckBoxgotoURLBehaviors
    propertyCheckBoxgradientFillAngle
    propertyCheckBoxgradientFillLength
    propertyCheckBoxgradientFillStart
    propertyCheckBoxgradientStrokeAngle
    propertyCheckBoxgradientStrokeLength
    propertyCheckBoxgradientStrokeStart
    propertyCheckBoxgraphicLines
    propertyCheckBoxgraphics
    propertyCheckBoxgroups
    propertyCheckBoxhiddenUntilTriggered
    propertyCheckBoxhorizontalLayoutConstraints
    propertyCheckBoxhorizontalScale
    propertyCheckBoxid
    propertyCheckBoximages
    propertyCheckBoxindex
    propertyCheckBoxisValid
    propertyCheckBoxitemLayer
    propertyCheckBoxlabel
    propertyCheckBoxleftLineEnd
    propertyCheckBoxlinkedPageItemOptions
    propertyCheckBoxlocalDisplaySetting
    propertyCheckBoxlocked
    propertyCheckBoxmiterLimit
    propertyCheckBoxmovieBehaviors
    propertyCheckBoxname
    propertyCheckBoxnonprinting
    propertyCheckBoxopenFileBehaviors
    propertyCheckBoxovals
    propertyCheckBoxoverprintFill
    propertyCheckBoxoverprintGap
    propertyCheckBoxoverprintStroke
    propertyCheckBoxoverridden
    propertyCheckBoxoverriddenMasterPageItem
    propertyCheckBoxpageItems
    propertyCheckBoxparent
    propertyCheckBoxparentPage
    propertyCheckBoxpdfs
    propertyCheckBoxpicts
    propertyCheckBoxpolygons
    propertyCheckBoxpreferences
    propertyCheckBoxprintFormBehaviors
    propertyCheckBoxprintableInPdf
    propertyCheckBoxproperties
    propertyCheckBoxreadOnly
    propertyCheckBoxrectangles
    propertyCheckBoxrequired
    propertyCheckBoxrightLineEnd
    propertyCheckBoxrotationAngle
    propertyCheckBoxshearAngle
    propertyCheckBoxshowHideFieldsBehaviors
    propertyCheckBoxsoundBehaviors
    propertyCheckBoxsplineItems
    propertyCheckBoxstates
    propertyCheckBoxstrokeAlignment
    propertyCheckBoxstrokeColor
    propertyCheckBoxstrokeCornerAdjustment
    propertyCheckBoxstrokeDashAndGap
    propertyCheckBoxstrokeTint
    propertyCheckBoxstrokeTransparencySettings
    propertyCheckBoxstrokeType
    propertyCheckBoxstrokeWeight
    propertyCheckBoxsubmitFormBehaviors
    propertyCheckBoxtextFrames
    propertyCheckBoxtextWrapPreferences
    propertyCheckBoxtimingSettings
    propertyCheckBoxtopLeftCornerOption
    propertyCheckBoxtopLeftCornerRadius
    propertyCheckBoxtopRightCornerOption
    propertyCheckBoxtopRightCornerRadius
    propertyCheckBoxtransparencySettings
    propertyCheckBoxverticalLayoutConstraints
    propertyCheckBoxverticalScale
    propertyCheckBoxviewZoomBehaviors
    propertyCheckBoxvisible
    propertyCheckBoxvisibleBounds
    propertyCheckBoxwmfs
    propertyCheckBoxeslength
    propertyClearFormBehaviorbehaviorEvent
    propertyClearFormBehaviorenableBehavior
    propertyClearFormBehavioreventListeners
    propertyClearFormBehaviorevents
    propertyClearFormBehaviorid
    propertyClearFormBehaviorindex
    propertyClearFormBehaviorisValid
    propertyClearFormBehaviorlabel
    propertyClearFormBehaviorname
    propertyClearFormBehaviorparent
    propertyClearFormBehaviorproperties
    propertyClearFormBehaviorslength
    propertyComboBoxAFTER_PLACE
    propertyComboBoxBEFORE_PLACE
    propertyComboBoxabsoluteFlip
    propertyComboBoxabsoluteHorizontalScale
    propertyComboBoxabsoluteRotationAngle
    propertyComboBoxabsoluteShearAngle
    propertyComboBoxabsoluteVerticalScale
    propertyComboBoxactiveStateIndex
    propertyComboBoxallArticles
    propertyComboBoxallGraphics
    propertyComboBoxallPageItems
    propertyComboBoxallowOverrides
    propertyComboBoxanchoredObjectSettings
    propertyComboBoxanimationSettings
    propertyComboBoxappliedObjectStyle
    propertyComboBoxassociatedXMLElement
    propertyComboBoxbehaviors
    propertyComboBoxbottomLeftCornerOption
    propertyComboBoxbottomLeftCornerRadius
    propertyComboBoxbottomRightCornerOption
    propertyComboBoxbottomRightCornerRadius
    propertyComboBoxchoiceList
    propertyComboBoxclearFormBehaviors
    propertyComboBoxcontentTransparencySettings
    propertyComboBoxdescription
    propertyComboBoxendCap
    propertyComboBoxendJoin
    propertyComboBoxepss
    propertyComboBoxepstexts
    propertyComboBoxeventListeners
    propertyComboBoxevents
    propertyComboBoxfillColor
    propertyComboBoxfillTint
    propertyComboBoxfillTransparencySettings
    propertyComboBoxflip
    propertyComboBoxfontSize
    propertyComboBoxgapColor
    propertyComboBoxgapTint
    propertyComboBoxgeometricBounds
    propertyComboBoxgotoAnchorBehaviors
    propertyComboBoxgotoFirstPageBehaviors
    propertyComboBoxgotoLastPageBehaviors
    propertyComboBoxgotoNextPageBehaviors
    propertyComboBoxgotoNextViewBehaviors
    propertyComboBoxgotoPreviousPageBehaviors
    propertyComboBoxgotoPreviousViewBehaviors
    propertyComboBoxgotoURLBehaviors
    propertyComboBoxgradientFillAngle
    propertyComboBoxgradientFillLength
    propertyComboBoxgradientFillStart
    propertyComboBoxgradientStrokeAngle
    propertyComboBoxgradientStrokeLength
    propertyComboBoxgradientStrokeStart
    propertyComboBoxgraphicLines
    propertyComboBoxgraphics
    propertyComboBoxgroups
    propertyComboBoxhiddenUntilTriggered
    propertyComboBoxhorizontalLayoutConstraints
    propertyComboBoxhorizontalScale
    propertyComboBoxid
    propertyComboBoximages
    propertyComboBoxindex
    propertyComboBoxisValid
    propertyComboBoxitemLayer
    propertyComboBoxlabel
    propertyComboBoxleftLineEnd
    propertyComboBoxlinkedPageItemOptions
    propertyComboBoxlocalDisplaySetting
    propertyComboBoxlocked
    propertyComboBoxmiterLimit
    propertyComboBoxmovieBehaviors
    propertyComboBoxname
    propertyComboBoxnonprinting
    propertyComboBoxopenFileBehaviors
    propertyComboBoxovals
    propertyComboBoxoverprintFill
    propertyComboBoxoverprintGap
    propertyComboBoxoverprintStroke
    propertyComboBoxoverridden
    propertyComboBoxoverriddenMasterPageItem
    propertyComboBoxpageItems
    propertyComboBoxparent
    propertyComboBoxparentPage
    propertyComboBoxpdfs
    propertyComboBoxpicts
    propertyComboBoxpolygons
    propertyComboBoxpreferences
    propertyComboBoxprintFormBehaviors
    propertyComboBoxprintableInPdf
    propertyComboBoxproperties
    propertyComboBoxreadOnly
    propertyComboBoxrectangles
    propertyComboBoxrequired
    propertyComboBoxrightLineEnd
    propertyComboBoxrightToLeftField
    propertyComboBoxrotationAngle
    propertyComboBoxshearAngle
    propertyComboBoxshowHideFieldsBehaviors
    propertyComboBoxsortChoices
    propertyComboBoxsoundBehaviors
    propertyComboBoxsplineItems
    propertyComboBoxstrokeAlignment
    propertyComboBoxstrokeColor
    propertyComboBoxstrokeCornerAdjustment
    propertyComboBoxstrokeDashAndGap
    propertyComboBoxstrokeTint
    propertyComboBoxstrokeTransparencySettings
    propertyComboBoxstrokeType
    propertyComboBoxstrokeWeight
    propertyComboBoxsubmitFormBehaviors
    propertyComboBoxtextFrames
    propertyComboBoxtextWrapPreferences
    propertyComboBoxtimingSettings
    propertyComboBoxtopLeftCornerOption
    propertyComboBoxtopLeftCornerRadius
    propertyComboBoxtopRightCornerOption
    propertyComboBoxtopRightCornerRadius
    propertyComboBoxtransparencySettings
    propertyComboBoxverticalLayoutConstraints
    propertyComboBoxverticalScale
    propertyComboBoxviewZoomBehaviors
    propertyComboBoxvisible
    propertyComboBoxvisibleBounds
    propertyComboBoxwmfs
    propertyComboBoxeslength
    propertyContentPlacerObjecteventListeners
    propertyContentPlacerObjectevents
    propertyContentPlacerObjectisValid
    propertyContentPlacerObjectloaded
    propertyContentPlacerObjectparent
    propertyContentPlacerObjectproperties
    propertyDocumentcellStyleMappings
    propertyDocumentcharStyleMappings
    propertyDocumentcheckBoxes
    propertyDocumentcomboBoxes
    propertyDocumentlinkedPageItemOptions
    propertyDocumentlistBoxes
    propertyDocumentparaStyleMappings
    propertyDocumentradioButtons
    propertyDocumentselectionKeyObject
    propertyDocumentsignatureFields
    propertyDocumenttableStyleMappings
    propertyDocumenttextBoxes
    propertyDocumentPreferencecreatePrimaryTextFrame
    propertyDocumentPresetcreatePrimaryTextFrame
    propertyEPShorizontalLayoutConstraints
    propertyEPSlinkedPageItemOptions
    propertyEPSverticalLayoutConstraints
    propertyEPSTexthorizontalLayoutConstraints
    propertyEPSTextlinkedPageItemOptions
    propertyEPSTextverticalLayoutConstraints
    propertyEPubExportPreferenceexternalStyleSheets
    propertyEPubExportPreferencejavascripts
    propertyEPubExportPreferenceversion
    propertyFindGrepPreferenceparagraphKashidaWidth
    propertyFindObjectPreferenceautoSizingReferencePoint
    propertyFindObjectPreferenceautoSizingType
    propertyFindObjectPreferenceminimumHeightForAutoSizing
    propertyFindObjectPreferenceminimumWidthForAutoSizing
    propertyFindObjectPreferenceuseMinimumHeightForAutoSizing
    propertyFindObjectPreferenceuseMinimumWidthForAutoSizing
    propertyFindObjectPreferenceuseNoLineBreaksForAutoSizing
    propertyFindTextPreferenceparagraphKashidaWidth
    propertyFontLockingPreferenceeventListeners
    propertyFontLockingPreferenceevents
    propertyFontLockingPreferencefontChangeLocking
    propertyFontLockingPreferencefontInputLocking
    propertyFontLockingPreferenceisValid
    propertyFontLockingPreferenceparent
    propertyFontLockingPreferenceproperties
    propertyFormFieldhorizontalLayoutConstraints
    propertyFormFieldlinkedPageItemOptions
    propertyFormFieldverticalLayoutConstraints
    propertyGeneralPreferencecreateLinksOnContentPlace
    propertyGeneralPreferencecustomMonitorPpi
    propertyGeneralPreferencegreekVectorGraphicsOnDrag
    propertyGeneralPreferencemainMonitorPpi
    propertyGeneralPreferencemapStylesOnContentPlace
    propertyGeneralPreferencepreviewPages
    propertyGeneralPreferenceshowConveyor
    propertyGeneralPreferenceuseCustomMonitorResolution
    propertyGraphichorizontalLayoutConstraints
    propertyGraphiclinkedPageItemOptions
    propertyGraphicverticalLayoutConstraints
    propertyGraphicLinecheckBoxes
    propertyGraphicLinecomboBoxes
    propertyGraphicLinehorizontalLayoutConstraints
    propertyGraphicLinehtmlItems
    propertyGraphicLinelinkedPageItemOptions
    propertyGraphicLinelistBoxes
    propertyGraphicLineradioButtons
    propertyGraphicLinesignatureFields
    propertyGraphicLinetextBoxes
    propertyGraphicLineverticalLayoutConstraints
    propertyGroupcheckBoxes
    propertyGroupcomboBoxes
    propertyGrouphorizontalLayoutConstraints
    propertyGrouplinkedPageItemOptions
    propertyGrouplistBoxes
    propertyGroupradioButtons
    propertyGroupsignatureFields
    propertyGrouptextBoxes
    propertyGroupverticalLayoutConstraints
    propertyGuideguideType
    propertyGuideguideZone
    propertyHTMLExportPreferenceexternalStyleSheets
    propertyHTMLExportPreferencejavascripts
    propertyHtmlItemAFTER_PLACE
    propertyHtmlItemBEFORE_PLACE
    propertyHtmlItemabsoluteFlip
    propertyHtmlItemabsoluteHorizontalScale
    propertyHtmlItemabsoluteRotationAngle
    propertyHtmlItemabsoluteShearAngle
    propertyHtmlItemabsoluteVerticalScale
    propertyHtmlItemallArticles
    propertyHtmlItemallGraphics
    propertyHtmlItemallPageItems
    propertyHtmlItemallowOverrides
    propertyHtmlItemanimationSettings
    propertyHtmlItemappliedObjectStyle
    propertyHtmlItemassociatedXMLElement
    propertyHtmlItembottomLeftCornerOption
    propertyHtmlItembottomLeftCornerRadius
    propertyHtmlItembottomRightCornerOption
    propertyHtmlItembottomRightCornerRadius
    propertyHtmlItemcontentTransparencySettings
    propertyHtmlItemendCap
    propertyHtmlItemendJoin
    propertyHtmlItemeventListeners
    propertyHtmlItemevents
    propertyHtmlItemfillColor
    propertyHtmlItemfillTint
    propertyHtmlItemfillTransparencySettings
    propertyHtmlItemfixedDimensions
    propertyHtmlItemflip
    propertyHtmlItemgapColor
    propertyHtmlItemgapTint
    propertyHtmlItemgeometricBounds
    propertyHtmlItemgradientFillAngle
    propertyHtmlItemgradientFillLength
    propertyHtmlItemgradientFillStart
    propertyHtmlItemgradientStrokeAngle
    propertyHtmlItemgradientStrokeLength
    propertyHtmlItemgradientStrokeStart
    propertyHtmlItemhorizontalLayoutConstraints
    propertyHtmlItemhorizontalScale
    propertyHtmlItemhtmlContent
    propertyHtmlItemid
    propertyHtmlItemindex
    propertyHtmlItemisValid
    propertyHtmlItemitemLayer
    propertyHtmlItemlabel
    propertyHtmlItemleftLineEnd
    propertyHtmlItemlinkedPageItemOptions
    propertyHtmlItemlocalDisplaySetting
    propertyHtmlItemlocked
    propertyHtmlItemmiterLimit
    propertyHtmlItemname
    propertyHtmlItemnonprinting
    propertyHtmlItemoverprintFill
    propertyHtmlItemoverprintGap
    propertyHtmlItemoverprintStroke
    propertyHtmlItemoverridden
    propertyHtmlItemoverriddenMasterPageItem
    propertyHtmlItemparent
    propertyHtmlItemparentPage
    propertyHtmlItempreferences
    propertyHtmlItemproperties
    propertyHtmlItemrightLineEnd
    propertyHtmlItemrotationAngle
    propertyHtmlItemshearAngle
    propertyHtmlItemstrokeAlignment
    propertyHtmlItemstrokeColor
    propertyHtmlItemstrokeCornerAdjustment
    propertyHtmlItemstrokeDashAndGap
    propertyHtmlItemstrokeTint
    propertyHtmlItemstrokeTransparencySettings
    propertyHtmlItemstrokeType
    propertyHtmlItemstrokeWeight
    propertyHtmlItemtextWrapPreferences
    propertyHtmlItemtimingSettings
    propertyHtmlItemtopLeftCornerOption
    propertyHtmlItemtopLeftCornerRadius
    propertyHtmlItemtopRightCornerOption
    propertyHtmlItemtopRightCornerRadius
    propertyHtmlItemtransparencySettings
    propertyHtmlItemverticalLayoutConstraints
    propertyHtmlItemverticalScale
    propertyHtmlItemvisible
    propertyHtmlItemvisibleBounds
    propertyHtmlItemslength
    propertyIMEPreferenceuseNativeDigits
    propertyImagehorizontalLayoutConstraints
    propertyImagelinkedPageItemOptions
    propertyImageverticalLayoutConstraints
    propertyImportedPagehorizontalLayoutConstraints
    propertyImportedPagelinkedPageItemOptions
    propertyImportedPageverticalLayoutConstraints
    propertyInsertionPointcheckBoxes
    propertyInsertionPointcomboBoxes
    propertyInsertionPointlistBoxes
    propertyInsertionPointparagraphKashidaWidth
    propertyInsertionPointradioButtons
    propertyInsertionPointsignatureFields
    propertyInsertionPointtextBoxes
    propertyInteractivePDFExportPreferenceusePDFStructureForTabOrder
    propertyLayercheckBoxes
    propertyLayercomboBoxes
    propertyLayerlistBoxes
    propertyLayerradioButtons
    propertyLayersignatureFields
    propertyLayertextBoxes
    propertyLayoutWindowselectionKeyObject
    propertyLinecheckBoxes
    propertyLinecomboBoxes
    propertyLinelistBoxes
    propertyLineparagraphKashidaWidth
    propertyLineradioButtons
    propertyLinesignatureFields
    propertyLinetextBoxes
    propertyLinkedPageItemOptioneventListeners
    propertyLinkedPageItemOptionevents
    propertyLinkedPageItemOptionisValid
    propertyLinkedPageItemOptionparent
    propertyLinkedPageItemOptionpreserveAppearance
    propertyLinkedPageItemOptionpreserveFrameContent
    propertyLinkedPageItemOptionpreserveInteractivity
    propertyLinkedPageItemOptionpreserveOthers
    propertyLinkedPageItemOptionpreserveSizeAndShape
    propertyLinkedPageItemOptionproperties
    propertyLinkedPageItemOptionupdateLinkWhileSaving
    propertyLinkedPageItemOptionwarnOnUpdateOfEditedPageItem
    propertyLinkedStoryOptionapplyStyleMappings
    propertyListBoxAFTER_PLACE
    propertyListBoxBEFORE_PLACE
    propertyListBoxabsoluteFlip
    propertyListBoxabsoluteHorizontalScale
    propertyListBoxabsoluteRotationAngle
    propertyListBoxabsoluteShearAngle
    propertyListBoxabsoluteVerticalScale
    propertyListBoxactiveStateIndex
    propertyListBoxallArticles
    propertyListBoxallGraphics
    propertyListBoxallPageItems
    propertyListBoxallowOverrides
    propertyListBoxanchoredObjectSettings
    propertyListBoxanimationSettings
    propertyListBoxappliedObjectStyle
    propertyListBoxassociatedXMLElement
    propertyListBoxbehaviors
    propertyListBoxbottomLeftCornerOption
    propertyListBoxbottomLeftCornerRadius
    propertyListBoxbottomRightCornerOption
    propertyListBoxbottomRightCornerRadius
    propertyListBoxchoiceList
    propertyListBoxclearFormBehaviors
    propertyListBoxcontentTransparencySettings
    propertyListBoxdescription
    propertyListBoxendCap
    propertyListBoxendJoin
    propertyListBoxepss
    propertyListBoxepstexts
    propertyListBoxeventListeners
    propertyListBoxevents
    propertyListBoxfillColor
    propertyListBoxfillTint
    propertyListBoxfillTransparencySettings
    propertyListBoxflip
    propertyListBoxfontSize
    propertyListBoxgapColor
    propertyListBoxgapTint
    propertyListBoxgeometricBounds
    propertyListBoxgotoAnchorBehaviors
    propertyListBoxgotoFirstPageBehaviors
    propertyListBoxgotoLastPageBehaviors
    propertyListBoxgotoNextPageBehaviors
    propertyListBoxgotoNextViewBehaviors
    propertyListBoxgotoPreviousPageBehaviors
    propertyListBoxgotoPreviousViewBehaviors
    propertyListBoxgotoURLBehaviors
    propertyListBoxgradientFillAngle
    propertyListBoxgradientFillLength
    propertyListBoxgradientFillStart
    propertyListBoxgradientStrokeAngle
    propertyListBoxgradientStrokeLength
    propertyListBoxgradientStrokeStart
    propertyListBoxgraphicLines
    propertyListBoxgraphics
    propertyListBoxgroups
    propertyListBoxhiddenUntilTriggered
    propertyListBoxhorizontalLayoutConstraints
    propertyListBoxhorizontalScale
    propertyListBoxid
    propertyListBoximages
    propertyListBoxindex
    propertyListBoxisValid
    propertyListBoxitemLayer
    propertyListBoxlabel
    propertyListBoxleftLineEnd
    propertyListBoxlinkedPageItemOptions
    propertyListBoxlocalDisplaySetting
    propertyListBoxlocked
    propertyListBoxmiterLimit
    propertyListBoxmovieBehaviors
    propertyListBoxmultipleSelection
    propertyListBoxname
    propertyListBoxnonprinting
    propertyListBoxopenFileBehaviors
    propertyListBoxovals
    propertyListBoxoverprintFill
    propertyListBoxoverprintGap
    propertyListBoxoverprintStroke
    propertyListBoxoverridden
    propertyListBoxoverriddenMasterPageItem
    propertyListBoxpageItems
    propertyListBoxparent
    propertyListBoxparentPage
    propertyListBoxpdfs
    propertyListBoxpicts
    propertyListBoxpolygons
    propertyListBoxpreferences
    propertyListBoxprintFormBehaviors
    propertyListBoxprintableInPdf
    propertyListBoxproperties
    propertyListBoxreadOnly
    propertyListBoxrectangles
    propertyListBoxrequired
    propertyListBoxrightLineEnd
    propertyListBoxrightToLeftField
    propertyListBoxrotationAngle
    propertyListBoxshearAngle
    propertyListBoxshowHideFieldsBehaviors
    propertyListBoxsortChoices
    propertyListBoxsoundBehaviors
    propertyListBoxsplineItems
    propertyListBoxstrokeAlignment
    propertyListBoxstrokeColor
    propertyListBoxstrokeCornerAdjustment
    propertyListBoxstrokeDashAndGap
    propertyListBoxstrokeTint
    propertyListBoxstrokeTransparencySettings
    propertyListBoxstrokeType
    propertyListBoxstrokeWeight
    propertyListBoxsubmitFormBehaviors
    propertyListBoxtextFrames
    propertyListBoxtextWrapPreferences
    propertyListBoxtimingSettings
    propertyListBoxtopLeftCornerOption
    propertyListBoxtopLeftCornerRadius
    propertyListBoxtopRightCornerOption
    propertyListBoxtopRightCornerRadius
    propertyListBoxtransparencySettings
    propertyListBoxverticalLayoutConstraints
    propertyListBoxverticalScale
    propertyListBoxviewZoomBehaviors
    propertyListBoxvisible
    propertyListBoxvisibleBounds
    propertyListBoxwmfs
    propertyListBoxeslength
    propertyMasterSpreadcheckBoxes
    propertyMasterSpreadcomboBoxes
    propertyMasterSpreadlistBoxes
    propertyMasterSpreadprimaryTextFrame
    propertyMasterSpreadradioButtons
    propertyMasterSpreadsignatureFields
    propertyMasterSpreadtextBoxes
    propertyMediaItemhorizontalLayoutConstraints
    propertyMediaItemlinkedPageItemOptions
    propertyMediaItemverticalLayoutConstraints
    propertyMoviehorizontalLayoutConstraints
    propertyMovielinkedPageItemOptions
    propertyMovieverticalLayoutConstraints
    propertyMultiStateObjecthorizontalLayoutConstraints
    propertyMultiStateObjectlinkedPageItemOptions
    propertyMultiStateObjectverticalLayoutConstraints
    propertyObjectExportOptioncustomLayout
    propertyObjectExportOptioncustomLayoutType
    propertyObjectStyleenableTextFrameAutoSizingOptions
    propertyOvalcheckBoxes
    propertyOvalcomboBoxes
    propertyOvalhorizontalLayoutConstraints
    propertyOvalhtmlItems
    propertyOvallinkedPageItemOptions
    propertyOvallistBoxes
    propertyOvalradioButtons
    propertyOvalsignatureFields
    propertyOvaltextBoxes
    propertyOvalverticalLayoutConstraints
    propertyPDFhorizontalLayoutConstraints
    propertyPDFlinkedPageItemOptions
    propertyPDFverticalLayoutConstraints
    propertyPICThorizontalLayoutConstraints
    propertyPICTlinkedPageItemOptions
    propertyPICTverticalLayoutConstraints
    propertyPNGExportPreferenceantiAlias
    propertyPNGExportPreferenceeventListeners
    propertyPNGExportPreferenceevents
    propertyPNGExportPreferenceexportResolution
    propertyPNGExportPreferenceexportingSpread
    propertyPNGExportPreferenceisValid
    propertyPNGExportPreferencepageString
    propertyPNGExportPreferenceparent
    propertyPNGExportPreferencepngColorSpace
    propertyPNGExportPreferencepngExportRange
    propertyPNGExportPreferencepngQuality
    propertyPNGExportPreferenceproperties
    propertyPNGExportPreferencesimulateOverprint
    propertyPNGExportPreferencetransparentBackground
    propertyPNGExportPreferenceuseDocumentBleeds
    propertyPageappliedAlternateLayout
    propertyPagecheckBoxes
    propertyPagecomboBoxes
    propertyPagelayoutRule
    propertyPagelistBoxes
    propertyPageoptionalPage
    propertyPageradioButtons
    propertyPagesignatureFields
    propertyPagesnapshotBlendingMode
    propertyPagetextBoxes
    propertyPageItemhorizontalLayoutConstraints
    propertyPageItemlinkedPageItemOptions
    propertyPageItemverticalLayoutConstraints
    propertyParaStyleMappingdestinationStyleName
    propertyParaStyleMappingeventListeners
    propertyParaStyleMappingevents
    propertyParaStyleMappingindex
    propertyParaStyleMappingisValid
    propertyParaStyleMappingmappingRuleType
    propertyParaStyleMappingparent
    propertyParaStyleMappingproperties
    propertyParaStyleMappingsourceStyleName
    propertyParaStyleMappingslength
    propertyParagraphcheckBoxes
    propertyParagraphcomboBoxes
    propertyParagraphlistBoxes
    propertyParagraphparagraphKashidaWidth
    propertyParagraphradioButtons
    propertyParagraphsignatureFields
    propertyParagraphtextBoxes
    propertyParagraphStyleparagraphKashidaWidth
    propertyPlaceGuncheckBoxes
    propertyPlaceGuncomboBoxes
    propertyPlaceGunlistBoxes
    propertyPlaceGunradioButtons
    propertyPlaceGunsignatureFields
    propertyPlaceGuntextBoxes
    propertyPolygoncheckBoxes
    propertyPolygoncomboBoxes
    propertyPolygonhorizontalLayoutConstraints
    propertyPolygonhtmlItems
    propertyPolygonlinkedPageItemOptions
    propertyPolygonlistBoxes
    propertyPolygonradioButtons
    propertyPolygonsignatureFields
    propertyPolygontextBoxes
    propertyPolygonverticalLayoutConstraints
    propertyPrintFormBehaviorbehaviorEvent
    propertyPrintFormBehaviorenableBehavior
    propertyPrintFormBehavioreventListeners
    propertyPrintFormBehaviorevents
    propertyPrintFormBehaviorid
    propertyPrintFormBehaviorindex
    propertyPrintFormBehaviorisValid
    propertyPrintFormBehaviorlabel
    propertyPrintFormBehaviorname
    propertyPrintFormBehaviorparent
    propertyPrintFormBehaviorproperties
    propertyPrintFormBehaviorslength
    propertyRadioButtonAFTER_PLACE
    propertyRadioButtonBEFORE_PLACE
    propertyRadioButtonabsoluteFlip
    propertyRadioButtonabsoluteHorizontalScale
    propertyRadioButtonabsoluteRotationAngle
    propertyRadioButtonabsoluteShearAngle
    propertyRadioButtonabsoluteVerticalScale
    propertyRadioButtonactiveStateIndex
    propertyRadioButtonallArticles
    propertyRadioButtonallGraphics
    propertyRadioButtonallPageItems
    propertyRadioButtonallowOverrides
    propertyRadioButtonanchoredObjectSettings
    propertyRadioButtonanimationSettings
    propertyRadioButtonappliedObjectStyle
    propertyRadioButtonassociatedXMLElement
    propertyRadioButtonbehaviors
    propertyRadioButtonbottomLeftCornerOption
    propertyRadioButtonbottomLeftCornerRadius
    propertyRadioButtonbottomRightCornerOption
    propertyRadioButtonbottomRightCornerRadius
    propertyRadioButtoncheckedByDefault
    propertyRadioButtonclearFormBehaviors
    propertyRadioButtoncontentTransparencySettings
    propertyRadioButtondescription
    propertyRadioButtonendCap
    propertyRadioButtonendJoin
    propertyRadioButtonepss
    propertyRadioButtonepstexts
    propertyRadioButtoneventListeners
    propertyRadioButtonevents
    propertyRadioButtonexportValue
    propertyRadioButtonfillColor
    propertyRadioButtonfillTint
    propertyRadioButtonfillTransparencySettings
    propertyRadioButtonflip
    propertyRadioButtongapColor
    propertyRadioButtongapTint
    propertyRadioButtongeometricBounds
    propertyRadioButtongotoAnchorBehaviors
    propertyRadioButtongotoFirstPageBehaviors
    propertyRadioButtongotoLastPageBehaviors
    propertyRadioButtongotoNextPageBehaviors
    propertyRadioButtongotoNextViewBehaviors
    propertyRadioButtongotoPreviousPageBehaviors
    propertyRadioButtongotoPreviousViewBehaviors
    propertyRadioButtongotoURLBehaviors
    propertyRadioButtongradientFillAngle
    propertyRadioButtongradientFillLength
    propertyRadioButtongradientFillStart
    propertyRadioButtongradientStrokeAngle
    propertyRadioButtongradientStrokeLength
    propertyRadioButtongradientStrokeStart
    propertyRadioButtongraphicLines
    propertyRadioButtongraphics
    propertyRadioButtongroups
    propertyRadioButtonhiddenUntilTriggered
    propertyRadioButtonhorizontalLayoutConstraints
    propertyRadioButtonhorizontalScale
    propertyRadioButtonid
    propertyRadioButtonimages
    propertyRadioButtonindex
    propertyRadioButtonisValid
    propertyRadioButtonitemLayer
    propertyRadioButtonlabel
    propertyRadioButtonleftLineEnd
    propertyRadioButtonlinkedPageItemOptions
    propertyRadioButtonlocalDisplaySetting
    propertyRadioButtonlocked
    propertyRadioButtonmiterLimit
    propertyRadioButtonmovieBehaviors
    propertyRadioButtonname
    propertyRadioButtonnonprinting
    propertyRadioButtonopenFileBehaviors
    propertyRadioButtonovals
    propertyRadioButtonoverprintFill
    propertyRadioButtonoverprintGap
    propertyRadioButtonoverprintStroke
    propertyRadioButtonoverridden
    propertyRadioButtonoverriddenMasterPageItem
    propertyRadioButtonpageItems
    propertyRadioButtonparent
    propertyRadioButtonparentPage
    propertyRadioButtonpdfs
    propertyRadioButtonpicts
    propertyRadioButtonpolygons
    propertyRadioButtonpreferences
    propertyRadioButtonprintFormBehaviors
    propertyRadioButtonprintableInPdf
    propertyRadioButtonproperties
    propertyRadioButtonreadOnly
    propertyRadioButtonrectangles
    propertyRadioButtonrequired
    propertyRadioButtonrightLineEnd
    propertyRadioButtonrotationAngle
    propertyRadioButtonshearAngle
    propertyRadioButtonshowHideFieldsBehaviors
    propertyRadioButtonsoundBehaviors
    propertyRadioButtonsplineItems
    propertyRadioButtonstates
    propertyRadioButtonstrokeAlignment
    propertyRadioButtonstrokeColor
    propertyRadioButtonstrokeCornerAdjustment
    propertyRadioButtonstrokeDashAndGap
    propertyRadioButtonstrokeTint
    propertyRadioButtonstrokeTransparencySettings
    propertyRadioButtonstrokeType
    propertyRadioButtonstrokeWeight
    propertyRadioButtonsubmitFormBehaviors
    propertyRadioButtontextFrames
    propertyRadioButtontextWrapPreferences
    propertyRadioButtontimingSettings
    propertyRadioButtontopLeftCornerOption
    propertyRadioButtontopLeftCornerRadius
    propertyRadioButtontopRightCornerOption
    propertyRadioButtontopRightCornerRadius
    propertyRadioButtontransparencySettings
    propertyRadioButtonverticalLayoutConstraints
    propertyRadioButtonverticalScale
    propertyRadioButtonviewZoomBehaviors
    propertyRadioButtonvisible
    propertyRadioButtonvisibleBounds
    propertyRadioButtonwmfs
    propertyRadioButtonslength
    propertyRectanglecheckBoxes
    propertyRectanglecomboBoxes
    propertyRectanglehorizontalLayoutConstraints
    propertyRectanglehtmlItems
    propertyRectanglelinkedPageItemOptions
    propertyRectanglelistBoxes
    propertyRectangleradioButtons
    propertyRectanglesignatureFields
    propertyRectangletextBoxes
    propertyRectangleverticalLayoutConstraints
    propertySectionalternateLayout
    propertySectionalternateLayoutLength
    propertySectionpagination
    propertySectionpaginationMaster
    propertySignatureFieldAFTER_PLACE
    propertySignatureFieldBEFORE_PLACE
    propertySignatureFieldabsoluteFlip
    propertySignatureFieldabsoluteHorizontalScale
    propertySignatureFieldabsoluteRotationAngle
    propertySignatureFieldabsoluteShearAngle
    propertySignatureFieldabsoluteVerticalScale
    propertySignatureFieldactiveStateIndex
    propertySignatureFieldallArticles
    propertySignatureFieldallGraphics
    propertySignatureFieldallPageItems
    propertySignatureFieldallowOverrides
    propertySignatureFieldanchoredObjectSettings
    propertySignatureFieldanimationSettings
    propertySignatureFieldappliedObjectStyle
    propertySignatureFieldassociatedXMLElement
    propertySignatureFieldbehaviors
    propertySignatureFieldbottomLeftCornerOption
    propertySignatureFieldbottomLeftCornerRadius
    propertySignatureFieldbottomRightCornerOption
    propertySignatureFieldbottomRightCornerRadius
    propertySignatureFieldclearFormBehaviors
    propertySignatureFieldcontentTransparencySettings
    propertySignatureFielddescription
    propertySignatureFieldendCap
    propertySignatureFieldendJoin
    propertySignatureFieldepss
    propertySignatureFieldepstexts
    propertySignatureFieldeventListeners
    propertySignatureFieldevents
    propertySignatureFieldfillColor
    propertySignatureFieldfillTint
    propertySignatureFieldfillTransparencySettings
    propertySignatureFieldflip
    propertySignatureFieldgapColor
    propertySignatureFieldgapTint
    propertySignatureFieldgeometricBounds
    propertySignatureFieldgotoAnchorBehaviors
    propertySignatureFieldgotoFirstPageBehaviors
    propertySignatureFieldgotoLastPageBehaviors
    propertySignatureFieldgotoNextPageBehaviors
    propertySignatureFieldgotoNextViewBehaviors
    propertySignatureFieldgotoPreviousPageBehaviors
    propertySignatureFieldgotoPreviousViewBehaviors
    propertySignatureFieldgotoURLBehaviors
    propertySignatureFieldgradientFillAngle
    propertySignatureFieldgradientFillLength
    propertySignatureFieldgradientFillStart
    propertySignatureFieldgradientStrokeAngle
    propertySignatureFieldgradientStrokeLength
    propertySignatureFieldgradientStrokeStart
    propertySignatureFieldgraphicLines
    propertySignatureFieldgraphics
    propertySignatureFieldgroups
    propertySignatureFieldhiddenUntilTriggered
    propertySignatureFieldhorizontalLayoutConstraints
    propertySignatureFieldhorizontalScale
    propertySignatureFieldid
    propertySignatureFieldimages
    propertySignatureFieldindex
    propertySignatureFieldisValid
    propertySignatureFielditemLayer
    propertySignatureFieldlabel
    propertySignatureFieldleftLineEnd
    propertySignatureFieldlinkedPageItemOptions
    propertySignatureFieldlocalDisplaySetting
    propertySignatureFieldlocked
    propertySignatureFieldmiterLimit
    propertySignatureFieldmovieBehaviors
    propertySignatureFieldname
    propertySignatureFieldnonprinting
    propertySignatureFieldopenFileBehaviors
    propertySignatureFieldovals
    propertySignatureFieldoverprintFill
    propertySignatureFieldoverprintGap
    propertySignatureFieldoverprintStroke
    propertySignatureFieldoverridden
    propertySignatureFieldoverriddenMasterPageItem
    propertySignatureFieldpageItems
    propertySignatureFieldparent
    propertySignatureFieldparentPage
    propertySignatureFieldpdfs
    propertySignatureFieldpicts
    propertySignatureFieldpolygons
    propertySignatureFieldpreferences
    propertySignatureFieldprintFormBehaviors
    propertySignatureFieldprintableInPdf
    propertySignatureFieldproperties
    propertySignatureFieldreadOnly
    propertySignatureFieldrectangles
    propertySignatureFieldrequired
    propertySignatureFieldrightLineEnd
    propertySignatureFieldrotationAngle
    propertySignatureFieldshearAngle
    propertySignatureFieldshowHideFieldsBehaviors
    propertySignatureFieldsoundBehaviors
    propertySignatureFieldsplineItems
    propertySignatureFieldstrokeAlignment
    propertySignatureFieldstrokeColor
    propertySignatureFieldstrokeCornerAdjustment
    propertySignatureFieldstrokeDashAndGap
    propertySignatureFieldstrokeTint
    propertySignatureFieldstrokeTransparencySettings
    propertySignatureFieldstrokeType
    propertySignatureFieldstrokeWeight
    propertySignatureFieldsubmitFormBehaviors
    propertySignatureFieldtextFrames
    propertySignatureFieldtextWrapPreferences
    propertySignatureFieldtimingSettings
    propertySignatureFieldtopLeftCornerOption
    propertySignatureFieldtopLeftCornerRadius
    propertySignatureFieldtopRightCornerOption
    propertySignatureFieldtopRightCornerRadius
    propertySignatureFieldtransparencySettings
    propertySignatureFieldverticalLayoutConstraints
    propertySignatureFieldverticalScale
    propertySignatureFieldviewZoomBehaviors
    propertySignatureFieldvisible
    propertySignatureFieldvisibleBounds
    propertySignatureFieldwmfs
    propertySignatureFieldslength
    propertySnippetcheckBoxes
    propertySnippetcomboBoxes
    propertySnippetlistBoxes
    propertySnippetradioButtons
    propertySnippetsignatureFields
    propertySnippettextBoxes
    propertySoundhorizontalLayoutConstraints
    propertySoundlinkedPageItemOptions
    propertySoundverticalLayoutConstraints
    propertySplineItemcheckBoxes
    propertySplineItemcomboBoxes
    propertySplineItemhorizontalLayoutConstraints
    propertySplineItemhtmlItems
    propertySplineItemlinkedPageItemOptions
    propertySplineItemlistBoxes
    propertySplineItemradioButtons
    propertySplineItemsignatureFields
    propertySplineItemtextBoxes
    propertySplineItemverticalLayoutConstraints
    propertySpreadcheckBoxes
    propertySpreadcomboBoxes
    propertySpreadlistBoxes
    propertySpreadradioButtons
    propertySpreadsignatureFields
    propertySpreadtextBoxes
    propertyStaticTextstaticAlignment
    propertyStorycellStyleMappings
    propertyStorycharStyleMappings
    propertyStorycheckBoxes
    propertyStorycomboBoxes
    propertyStorylistBoxes
    propertyStoryparaStyleMappings
    propertyStoryparagraphKashidaWidth
    propertyStoryradioButtons
    propertyStorysignatureFields
    propertyStorytableStyleMappings
    propertyStorytextBoxes
    propertyStoryWindowselectionKeyObject
    propertyStyleExportTagMapsplitDocument
    propertySubmitFormBehaviorbehaviorEvent
    propertySubmitFormBehaviorenableBehavior
    propertySubmitFormBehavioreventListeners
    propertySubmitFormBehaviorevents
    propertySubmitFormBehaviorid
    propertySubmitFormBehaviorindex
    propertySubmitFormBehaviorisValid
    propertySubmitFormBehaviorlabel
    propertySubmitFormBehaviorname
    propertySubmitFormBehaviorparent
    propertySubmitFormBehaviorproperties
    propertySubmitFormBehaviorurl
    propertySubmitFormBehaviorslength
    propertyTablecheckBoxes
    propertyTablecomboBoxes
    propertyTablelistBoxes
    propertyTableradioButtons
    propertyTablesignatureFields
    propertyTabletextBoxes
    propertyTableStyleMappingdestinationStyleName
    propertyTableStyleMappingeventListeners
    propertyTableStyleMappingevents
    propertyTableStyleMappingindex
    propertyTableStyleMappingisValid
    propertyTableStyleMappingmappingRuleType
    propertyTableStyleMappingparent
    propertyTableStyleMappingproperties
    propertyTableStyleMappingsourceStyleName
    propertyTableStyleMappingslength
    propertyTextcheckBoxes
    propertyTextcomboBoxes
    propertyTextlistBoxes
    propertyTextparagraphKashidaWidth
    propertyTextradioButtons
    propertyTextsignatureFields
    propertyTexttextBoxes
    propertyTextBoxAFTER_PLACE
    propertyTextBoxBEFORE_PLACE
    propertyTextBoxabsoluteFlip
    propertyTextBoxabsoluteHorizontalScale
    propertyTextBoxabsoluteRotationAngle
    propertyTextBoxabsoluteShearAngle
    propertyTextBoxabsoluteVerticalScale
    propertyTextBoxactiveStateIndex
    propertyTextBoxallArticles
    propertyTextBoxallGraphics
    propertyTextBoxallPageItems
    propertyTextBoxallowOverrides
    propertyTextBoxanchoredObjectSettings
    propertyTextBoxanimationSettings
    propertyTextBoxappliedObjectStyle
    propertyTextBoxassociatedXMLElement
    propertyTextBoxbehaviors
    propertyTextBoxbottomLeftCornerOption
    propertyTextBoxbottomLeftCornerRadius
    propertyTextBoxbottomRightCornerOption
    propertyTextBoxbottomRightCornerRadius
    propertyTextBoxclearFormBehaviors
    propertyTextBoxcontentTransparencySettings
    propertyTextBoxdescription
    propertyTextBoxendCap
    propertyTextBoxendJoin
    propertyTextBoxepss
    propertyTextBoxepstexts
    propertyTextBoxeventListeners
    propertyTextBoxevents
    propertyTextBoxfillColor
    propertyTextBoxfillTint
    propertyTextBoxfillTransparencySettings
    propertyTextBoxflip
    propertyTextBoxfontSize
    propertyTextBoxgapColor
    propertyTextBoxgapTint
    propertyTextBoxgeometricBounds
    propertyTextBoxgotoAnchorBehaviors
    propertyTextBoxgotoFirstPageBehaviors
    propertyTextBoxgotoLastPageBehaviors
    propertyTextBoxgotoNextPageBehaviors
    propertyTextBoxgotoNextViewBehaviors
    propertyTextBoxgotoPreviousPageBehaviors
    propertyTextBoxgotoPreviousViewBehaviors
    propertyTextBoxgotoURLBehaviors
    propertyTextBoxgradientFillAngle
    propertyTextBoxgradientFillLength
    propertyTextBoxgradientFillStart
    propertyTextBoxgradientStrokeAngle
    propertyTextBoxgradientStrokeLength
    propertyTextBoxgradientStrokeStart
    propertyTextBoxgraphicLines
    propertyTextBoxgraphics
    propertyTextBoxgroups
    propertyTextBoxhiddenUntilTriggered
    propertyTextBoxhorizontalLayoutConstraints
    propertyTextBoxhorizontalScale
    propertyTextBoxid
    propertyTextBoximages
    propertyTextBoxindex
    propertyTextBoxisValid
    propertyTextBoxitemLayer
    propertyTextBoxlabel
    propertyTextBoxleftLineEnd
    propertyTextBoxlinkedPageItemOptions
    propertyTextBoxlocalDisplaySetting
    propertyTextBoxlocked
    propertyTextBoxmiterLimit
    propertyTextBoxmovieBehaviors
    propertyTextBoxmultiline
    propertyTextBoxname
    propertyTextBoxnonprinting
    propertyTextBoxopenFileBehaviors
    propertyTextBoxovals
    propertyTextBoxoverprintFill
    propertyTextBoxoverprintGap
    propertyTextBoxoverprintStroke
    propertyTextBoxoverridden
    propertyTextBoxoverriddenMasterPageItem
    propertyTextBoxpageItems
    propertyTextBoxparent
    propertyTextBoxparentPage
    propertyTextBoxpassword
    propertyTextBoxpdfs
    propertyTextBoxpicts
    propertyTextBoxpolygons
    propertyTextBoxpreferences
    propertyTextBoxprintFormBehaviors
    propertyTextBoxprintableInPdf
    propertyTextBoxproperties
    propertyTextBoxreadOnly
    propertyTextBoxrectangles
    propertyTextBoxrequired
    propertyTextBoxrightLineEnd
    propertyTextBoxrightToLeftField
    propertyTextBoxrotationAngle
    propertyTextBoxscrollable
    propertyTextBoxshearAngle
    propertyTextBoxshowHideFieldsBehaviors
    propertyTextBoxsoundBehaviors
    propertyTextBoxsplineItems
    propertyTextBoxstrokeAlignment
    propertyTextBoxstrokeColor
    propertyTextBoxstrokeCornerAdjustment
    propertyTextBoxstrokeDashAndGap
    propertyTextBoxstrokeTint
    propertyTextBoxstrokeTransparencySettings
    propertyTextBoxstrokeType
    propertyTextBoxstrokeWeight
    propertyTextBoxsubmitFormBehaviors
    propertyTextBoxtextFrames
    propertyTextBoxtextWrapPreferences
    propertyTextBoxtimingSettings
    propertyTextBoxtopLeftCornerOption
    propertyTextBoxtopLeftCornerRadius
    propertyTextBoxtopRightCornerOption
    propertyTextBoxtopRightCornerRadius
    propertyTextBoxtransparencySettings
    propertyTextBoxverticalLayoutConstraints
    propertyTextBoxverticalScale
    propertyTextBoxviewZoomBehaviors
    propertyTextBoxvisible
    propertyTextBoxvisibleBounds
    propertyTextBoxwmfs
    propertyTextBoxeslength
    propertyTextColumncheckBoxes
    propertyTextColumncomboBoxes
    propertyTextColumnlistBoxes
    propertyTextColumnparagraphKashidaWidth
    propertyTextColumnradioButtons
    propertyTextColumnsignatureFields
    propertyTextColumntextBoxes
    propertyTextDefaultparagraphKashidaWidth
    propertyTextFramecheckBoxes
    propertyTextFramecomboBoxes
    propertyTextFramehorizontalLayoutConstraints
    propertyTextFramelinkedPageItemOptions
    propertyTextFramelistBoxes
    propertyTextFrameobjectExportOptions
    propertyTextFrameradioButtons
    propertyTextFramesignatureFields
    propertyTextFrametextBoxes
    propertyTextFrameverticalLayoutConstraints
    propertyTextFramePreferenceautoSizingReferencePoint
    propertyTextFramePreferenceautoSizingType
    propertyTextFramePreferenceminimumHeightForAutoSizing
    propertyTextFramePreferenceminimumWidthForAutoSizing
    propertyTextFramePreferencetextColumnMaxWidth
    propertyTextFramePreferenceuseFlexibleColumnWidth
    propertyTextFramePreferenceuseMinimumHeightForAutoSizing
    propertyTextFramePreferenceuseMinimumWidthForAutoSizing
    propertyTextFramePreferenceuseNoLineBreaksForAutoSizing
    propertyTextPreferencequoteCharactersRotatedInVertical
    propertyTextStyleRangecheckBoxes
    propertyTextStyleRangecomboBoxes
    propertyTextStyleRangelistBoxes
    propertyTextStyleRangeparagraphKashidaWidth
    propertyTextStyleRangeradioButtons
    propertyTextStyleRangesignatureFields
    propertyTextStyleRangetextBoxes
    propertyWMFhorizontalLayoutConstraints
    propertyWMFlinkedPageItemOptions
    propertyWMFverticalLayoutConstraints
    propertyWindowselectionKeyObject
    propertyWordcheckBoxes
    propertyWordcomboBoxes
    propertyWordlistBoxes
    propertyWordparagraphKashidaWidth
    propertyWordradioButtons
    propertyWordsignatureFields
    propertyWordtextBoxes
    propertyXmlStorycellStyleMappings
    propertyXmlStorycharStyleMappings
    propertyXmlStorycheckBoxes
    propertyXmlStorycomboBoxes
    propertyXmlStorylistBoxes
    propertyXmlStoryparaStyleMappings
    propertyXmlStoryparagraphKashidaWidth
    propertyXmlStoryradioButtons
    propertyXmlStorysignatureFields
    propertyXmlStorytableStyleMappings
    propertyXmlStorytextBoxes
    property(enum)AlignDistributeBoundsKEY_OBJECT
    property(enum)AutoSizingReferenceEnumBOTTOM_CENTER_POINT
    property(enum)AutoSizingReferenceEnumBOTTOM_LEFT_POINT
    property(enum)AutoSizingReferenceEnumBOTTOM_RIGHT_POINT
    property(enum)AutoSizingReferenceEnumCENTER_POINT
    property(enum)AutoSizingReferenceEnumLEFT_CENTER_POINT
    property(enum)AutoSizingReferenceEnumRIGHT_CENTER_POINT
    property(enum)AutoSizingReferenceEnumTOP_CENTER_POINT
    property(enum)AutoSizingReferenceEnumTOP_LEFT_POINT
    property(enum)AutoSizingReferenceEnumTOP_RIGHT_POINT
    property(enum)AutoSizingTypeEnumHEIGHT_AND_WIDTH
    property(enum)AutoSizingTypeEnumHEIGHT_AND_WIDTH_PROPORTIONALLY
    property(enum)AutoSizingTypeEnumHEIGHT_ONLY
    property(enum)AutoSizingTypeEnumOFF
    property(enum)AutoSizingTypeEnumWIDTH_ONLY
    property(enum)CoordinateSpacesPAGE_COORDINATES
    property(enum)CustomLayoutTypeEnumALIGNMENT_AND_SPACING
    property(enum)CustomLayoutTypeEnumFLOAT_LEFT
    property(enum)CustomLayoutTypeEnumFLOAT_RIGHT
    property(enum)DiacriticPositionOptionsOPENTYPE_POSITION_FROM_BASELINE
    property(enum)DimensionsConstraintsFIXED_DIMENSION
    property(enum)DimensionsConstraintsFLEXIBLE_DIMENSION
    property(enum)DocumentIntentOptionsDPS_INTENT
    property(enum)EpubVersionEPUB2
    property(enum)EpubVersionEPUB3
    property(enum)EpubVersionEPUB3_WITH_LAYOUT
    property(enum)FindChangeTransliterateCharacterTypesARABIC_INDIC_DIGITS
    property(enum)FindChangeTransliterateCharacterTypesFARSI_DIGITS
    property(enum)FindChangeTransliterateCharacterTypesWESTERN_ARABIC_DIGITS
    property(enum)GuideTypeOptionsLIQUID
    property(enum)GuideTypeOptionsRULER
    property(enum)LanguageAndRegionINDIC
    property(enum)LayoutRuleOptionsGUIDE_BASED
    property(enum)LayoutRuleOptionsOBJECT_BASED
    property(enum)LayoutRuleOptionsOFF
    property(enum)LayoutRuleOptionsPRESERVE_EXISTING
    property(enum)LayoutRuleOptionsRECENTER
    property(enum)LayoutRuleOptionsSCALE
    property(enum)LayoutRuleOptionsUSE_MASTER
    property(enum)MapTypeGROUP_MAPPING_RULE
    property(enum)MapTypeGROUP_TO_STYLE_MAPPING_RULE
    property(enum)MapTypeSTYLE_MAPPING_RULE
    property(enum)MapTypeSTYLE_TO_GROUP_MAPPING_RULE
    property(enum)PDFColorSpaceGRAY
    property(enum)PNGColorSpaceEnumGRAY
    property(enum)PNGColorSpaceEnumRGB
    property(enum)PNGExportRangeEnumEXPORT_ALL
    property(enum)PNGExportRangeEnumEXPORT_RANGE
    property(enum)PNGQualityEnumHIGH
    property(enum)PNGQualityEnumLOW
    property(enum)PNGQualityEnumMAXIMUM
    property(enum)PNGQualityEnumMEDIUM
    property(enum)PageViewOptionsBY_ALTERNATE_LAYOUT
    property(enum)PageViewOptionsHORIZONTALLY
    property(enum)PageViewOptionsVERTICALLY
    property(enum)PaginationOptionAUTO_PAGINATE
    property(enum)PaginationOptionFROM_LAST_PAGE
    property(enum)ParagraphJustificationOptionsNASKH_KASHIDA_JUSTIFICATION
    property(enum)ParagraphJustificationOptionsNASKH_KASHIDA_JUSTIFICATION_FRAC
    property(enum)ParagraphJustificationOptionsNASKH_TATWEEL_JUSTIFICATION
    property(enum)ParagraphJustificationOptionsNASKH_TATWEEL_JUSTIFICATION_FRAC
    property(enum)PreviewPagesOptionsALL_PAGES
    property(enum)PreviewPagesOptionsFIRST_10_PAGES
    property(enum)PreviewPagesOptionsFIRST_2_PAGES
    property(enum)PreviewPagesOptionsFIRST_5_PAGES
    property(enum)PreviewPagesOptionsFIRST_PAGE
    property(enum)SelectionOptionsSET_KEY
    property(enum)SnapshotBlendingModesFULL_SNAPSHOT_BLENDING
    property(enum)SnapshotBlendingModesIGNORE_LAYOUT_SNAPSHOTS
    property(enum)SnapshotBlendingModesLIMITED_SNAPSHOT_BLENDING
    property(enum)SnapshotBlendingModesUSE_NEAREST_SNAPSHOT
    property(enum)StateTypesDOWN_OFF
    property(enum)StateTypesDOWN_ON
    property(enum)StateTypesROLLOVER_OFF
    property(enum)StateTypesROLLOVER_ON
    property(enum)StateTypesUP_OFF
    property(enum)StateTypesUP_ON
    property(enum)StaticAlignmentOptionsCENTER_ALIGN
    property(enum)StaticAlignmentOptionsLEFT_ALIGN
    property(enum)StaticAlignmentOptionsRIGHT_ALIGN
    property(enum)TagTextExportCharacterSetCENTRALEUROPEAN_ISO
    property(enum)TagTextExportCharacterSetCYRILLIC_ISO
    property(enum)TagTextExportCharacterSetGREEK_ISO
    property(enum)TagTextExportCharacterSetWINDOWS_ARABIC
    property(enum)TagTextExportCharacterSetWINDOWS_HEBREW
    property(enum)TextFrameContentsPLACEHOLDER_TEXT_ARABIC
    property(enum)TextFrameContentsPLACEHOLDER_TEXT_CYRILLIC
    property(enum)TextFrameContentsPLACEHOLDER_TEXT_GREEK
    property(enum)TextFrameContentsPLACEHOLDER_TEXT_HEBREW
    property(enum)TextImportCharacterSetARABIC_ASMO
    property(enum)TextImportCharacterSetARABIC_ASMO_TRANSPARENT
    property(enum)TextImportCharacterSetMACINTOSH_ARABIC
    property(enum)TextImportCharacterSetMACINTOSH_GREEK_SHARED_CAPS
    property(enum)TextImportCharacterSetMACINTOSH_HEBREW
    property(enum)TextImportCharacterSetWINDOWS_ARABIC
    property(enum)TextImportCharacterSetWINDOWS_HEBREW
    Everybody happy?
    Apr 27, 2012 11:08 PM   in reply to John Hawkinson
    @Jongware & John – Great ! Great ! Great !!
    Thank you very much!
    Uwe
    Apr 28, 2012 12:12 AM   in reply to [Jongware]
    @Jongware – Could you also do a chm version for InDesign CS5.5?
    I know there is the online documentation. I wonder how much trouble it is to transform that into a chm file.
    Or are there tools to do it myself?
    And another thing with the online documentation of CS5.5:
    Did you by any chance have the Adobe Digitial Publishing Suite installed when you created the online version of InDesign CS5.5?
    I noticed that there is the "getAllOverlays" method listed for "application":
    http://jongware.mit.edu/idcsjs5.5/pc_Application.html#getAllOverlays
    That method is missing in the above lists by John. That is no omission since there seems no DPS involved on his side. And in your case, no wonder, it is missing in the CS6 documentation too, since DPS v20 for InDesign CS6 is not available yet and the current v19 does not work with InDesign CS6.
    On the other hand the "app.getDigpubVersion()" method is missing in your online documentation of InDesign CS5.5 which, so I believe, belongs totally to DPS and is only available if you have a installed DPS (like me). But maybe this method came with v19 of DPS and you had v17 or v18 installed the day you did the online documentation.
    Thank you again for your efforts!
    Uwe
    Apr 28, 2012 1:03 AM   in reply to John Hawkinson
    Thanks very much!
    Peter
  • John Hawkinson
    Jun 25, 2009
    Apr 28, 2012 4:59 PM   in reply to [Jongware]
    For example, who could ever have a grudge against PagesPanel.verticalView!? Surely that's not no longer an option in CS6?
    Whoops. The position of the UI control for this changed, and I figured it just moved around in the scripting DOM, but that doesn't appear to be the case. Sounds like an oversight. Bug #3177903: PagesPanel.verticalView property disappeared (CS6 regression). If you find any others, it would be good to find them prior to Monday.
    On the bright side, you can just set app.scriptPreferences.version=7.5 and it still works.
    Any others?
    *Kicks self* for not running this report earlier and not really paying attention...
    Apr 29, 2012 1:13 AM   in reply to [Jongware]
    So now, when I see a plural reference and there also is a singular class, this is shown besides the plural.
    @Jongware – and you did an update for this in the  CS4 files as well. Cool.
    Uwe
    Apr 29, 2012 4:05 AM   in reply to Laubender
    See here: http://jongware.mit.edu/idcs6js/pe_PageViewOptions.html <g>
    The odd choice was to move it in the Panel Options dialog.
    Peter
  • John Hawkinson
    Jun 25, 2009
    Apr 29, 2012 6:06 AM   in reply to Peter Kahrel
    Yes, but what variable uses this enumerator?
    Apr 29, 2012 6:14 AM   in reply to John Hawkinson
    Dunno. I've been looking under all kinds of preferences and settings, but haven't found it. To make finding what parent(s) a property or a method belongs to, I was going to ask if it's possible to change the xslt in such a way that the output list includes full path names, so to speak.
    Peter
  • John Hawkinson
    Jun 25, 2009
    Apr 29, 2012 6:24 AM   in reply to Peter Kahrel
    I had found the PageViewOptions enumerator before I concluded that there was no way to do this, but it didn't get me anywhere...but I'd be happy to be shown to be wrong!
    Unfortunately that's not how the XML is structured. Take a look at the OMV cache file, it looks like this:
    <dictionary engine="">
      <map name="8.0" ...>
        <topicref navtitle="Assignment Suite">
          <topicref navtitle="Assignment" href="#/Assignment"/>
        </topicref>
      </map>
      <package>
        <classdef name="Assignment" dynamic="true">
          <shortdesc>An assignment.</shortdesc>
          <elements type="instance">
            <property name="documentPath" rwaccess="readonly">
              <shortdesc>The path to the document that the hyperlink ...</shortdesc>
              <datatype>
                <type>File</type>
              </datatype>
            </property>
            <method name="update">
              <shortdesc>Updates the assignment file.</shortdesc>
              <parameters>
                <parameter name="versionComments">
                  <shortdesc>The comment for this version. (Optional)</shortdesc>
                  <datatype>
                    <type>string</type>
                  </datatype>
                </parameter>
              </parameters>
            </method>
          </elements>
        </classdef>
      </package>
    </dictionary>
    That is, for each proprerty (including eums), we only know the associated Class. And the Class belongs to a Suite.
    Sometimes the descriptions include (unstructured) references to an enumerator, but there are no decriptions that reference this enumerator.
    And nothing has a <datatype/> tag that lists this enumerator.
    So, it's certainly possible to change the XSLT to look up the Suite of a class in the <map/> section, but I didn't bother because it's a little more code and doesn't get us anything real. The PageViewOptions class belongs to the Enumeration suite, and that's all we can say.
    Or did I misunderstand?
    Apr 29, 2012 11:10 AM   in reply to John Hawkinson
    Ok, thanks, I see now that the xml won't let you get the full path. Thanks.
  • John Hawkinson
    Jun 25, 2009
    May 3, 2012 10:02 PM   in reply to John Hawkinson
    Well, that was exciting.
    Bug was marked Withdrawn/Closed/As Designed on Monday, I guess because QE thought that there was some way to use PageViewOptions.
    I lodged an inquiry then and today it was confirmed that it is indeed a bug (after "lengthy investigation") and it's been reopened and moved to CSnext.
    Gotta fight for your bugs!
