Help with InDesign and using MacBook Pro with 2.4 GHz Intel Core 2 Duo with 2GB
Apr 27, 2012 7:55 PM
Tags: #mac #cs5.5 #indesign #printing
Have a Mac Book Pro running 2.4 GHz Intel Core 2 Duo with 2GB RAM is there anyway to use InDesign and if so what version would run on this machine and would I still be able to interface with a printer to produce a magazine?  Or is it possible to upgrade/gut this machine for a new processor and RAM, if that is even possible, and could I then run a CS program say 5.5?
  • John Hawkinson
    Jun 25, 2009
    Apr 27, 2012 9:52 PM   in reply to jenahilton
    What's your concern? That's a perfectly reasonable machine. It can run any version of InDesign from CS3 through CS6; of course today you should use CS5.5, which is current. CS6 comes out next month.
    InDesign doesn't tend to use a lot of RAM, usually under 1 GB, so I wouldn't worry too much about upgrading until you try it.
    Apr 28, 2012 2:37 AM   in reply to jenahilton
    If you purchase CS5.5 now, you'll get CS6 for free. http://www.adobe.com/products/discount-software-coupons.html?PID=21599 97
    Apr 28, 2012 5:32 AM   in reply to jenahilton
    My MacBook has a 2Ghz Core2Duo with 4 gigs of RAM. Screamer? No. Perfectly adequate for I do with it? Absolutely, including CS6.
    I would certainly recommend a RAM upgrade if you plan on running more than just InDesign but other than that you should be fine.
    BTW, Amazon appears to be cutting prices a bit on CS5.5 upgrades. Buying there will still get you a free upgrade to CS6. http://amzn.to/JsMDAI
    Bob
  • John Hawkinson
    Jun 25, 2009
    Apr 30, 2012 6:05 AM   in reply to jenahilton
    Thanks for all the help - it is confusing though. I tried to download the trial version of CS5.5 to explore before buying the student version and the program download froze. I have deleted the doadload assistant and spoke with Adobe who told me my machine would not be compatible unless I upgraded - maybe the RAM to 4GB.
    You got bad (wrong) advice.
    If the download didn't work, it has nothing to do with the performance characteristics of your machine. You could download CS5.5 on a low-end PC from 10 years ago, it doesn't take much.
    Unfortunately Adobe's download manager is a bit flakey. Best advice is to use Firefox and try the download again.
    It doesn't have anything to do with the power of your computer, be it speed, processor type, or RAM.
    Make sure you're using FIrefox (if not, download and install it first), and then try the download again.
    Also, the download manager depends on Java. Make sure you have Java installed (but I think you must, because otherwise the download would not have started?).
    If it still doesn't work, give us some more detail. Error message? Screenshot?
