manofsteele08
[..\..\Src\pp\\PPixHandleUtilities.cpp-114] Error
Apr 28, 2012 9:01 AM
Im sorry if this is the wrong place to post this but I dont know what else to do. When i use AME or Export as Movie Im getting the ugly [..\..\Src\pp\\PPixHandleUtilities.cpp-114] error! Afterwards i get an unable to compile error. i have scoured the internet looking for answers. I have tried a few of the solutions but nothing seems to work. I have a project for my college class im working on and i need to figure this out. To start over would be a hefty process that does not sound like something i want to do. Any advice on what i can do or where i should to look for answers would be great! Thanks!
So far i have tried zooming all the way in on my tracks and looking for blank spots, i have tried adding a transparent video on the top layer spanning the entire sequence, i have tried uninstalling and reinstalling, importing my project into another project, using different project setting, different export settings, and so far nothing has seemed to work.
I know its ancient but im running CS3 and my machine is running AMD Quad-Core Processor with 8GB ram.
    Apr 28, 2012 10:08 AM   in reply to manofsteele08
    Some general reading... and then some questions
    Run as Administrator http://forums.adobe.com/thread/771202
    -Set to always "run as" via icon http://forums.adobe.com/thread/969395
    Odd Errors http://forums.adobe.com/thread/670174
    Long File Names or odd characters cause problems
    Read http://forums.adobe.com/thread/588273
    And #4 http://forums.adobe.com/thread/666558
    And This Message Thread http://forums.adobe.com/thread/665641
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen
    shot works well to SHOW people what you are doing
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainspector.massanti.com/
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-
    bars.html
    If you have a red line over the timeline after importing a video and before adding any
    effects... your project is wrong for your video... read above about codecs
    Once you know exactly what it is you are editing, report back with that information...
    and your project setting, and if there is a red line above the video in the timeline,
    which indicates a mismatch between video and project
    Apr 29, 2012 7:54 AM   in reply to manofsteele08
    Hmm... I switched to CS5 from CS3 May 2010, and I only worked with DV, not HD, when I had CS3... so I'm not sure just what capability CS3 has for "native" HD editing
    But I do know that trying "random" project settings is not a good idea, you need a project to match your video
    If none of the CS3 choices match your video... so you have an initital timeline with no red line, you may need to think about converting to something that will work in CS3
    Convert AVCHD to HDV http://forums.adobe.com/thread/390605
    or use Cineform Neo Scene http://www.cineform.com/neoscene/
    Apr 29, 2012 8:45 AM   in reply to manofsteele08
    1- I have no idea, but you DO need a project that allows you to import video and then NOT have an immediate red line over the timeline... which MAY not be possible with CS3 and your files
    2- Read the links I posted in my last message
    Sep 28, 2013 5:07 AM   in reply to manofsteele08
    Hi john so you could fix the problem ? i have the same problem ... same ERROR . How do you get the solution  ? i didn t understand .Thanks
