just an example: I am using lots of arrays in my code, and so repeat the stanza
somearray[somearray.length-1]
all over the place.
Now, I could do something like
public dynamic class MyArray extends Array
{ public function get last():*
{ return this[this.length-1];
and replace all instances of new Array() by new MyArray().
This would allow to use
somearray.last
However, this would lose the shortcut [], and the "last" accessor would not be available on arrays set up by system code (say as part of data
collections)
There are similar examples for static functions that I would like to add to some classes. I could, of course, collect them into a class MathUtil or 'GeomUtil,
but I would prefer to relate them to, say Point or Vector3D
I have seen "prototype chain" etc mentioned, would that help?
>>However, this would lose the shortcut [], and the "last" accessor would not be available on arrays set up by system code (say as part of data collections)
I would say not an issue to both of those. When do you really use []? I never use it... and who cares about arrays set up by system code? This solves your issue... but while I don't see your first solution as a problem, I would use kglads way - and do actually. I have an array utilities class and make use of it exactly like that: A.last(myarray) and I do think it makes the code more readable as well. Just my .02
well, I really prefer [] over new Array() and {} over new Object() ....
I have one class that is declared
public dynamic class something extends Array
For the moment I have added
public function get lastsomething():*
to it. I found that telling plain arrays and this special construct apart (in code just a few weeks old) was not that easy, so I will probably use distinctive member names more often
