I have seen this question here but have not seen a solution. I recently (grudgingly) upgraded to Lion 10.7
Now all my CS4 applications won't opne and give me this error that the license is no longer working! I have gone through all the fixes that Adobe recommends and nothing works. The only thing I have not done is uninstall everything and reinstall - I am really afraid to do that.
Has anyone found a solution to this? I am really upset and depend on Dreamweaver and Photoshop for my work!
Did you use the Licensing Repair Tool?
Download here:
http://www.adobe.com/support/contact/licensing_download_eula.html
Yes, two problems here:
First the application launch that they tell you to drag into the terminal has a line through it that means it is not compatibel with Lion
Second, I did it anyway - followed their exact instructions in the terminal and got error messages that the syntax was wrong - when I tried removing the space after sudo python that Adobe said you needed, it still didbn't work. I am going crazy with this. I hate adobe!!!
Did you try going through the other steps as well?
http://helpx.adobe.com/x-productkb/global/error-licensing-stopped-mac- os.html
Then you will have to try the final step and contact Adobe support. The installation support is free and you can upload log files to help them determine what is not working on your end: http://www.adobe.com/support/crm_portal/ssi/ftpinfo.html
Unforunately, we can only help so far and if the steps are not working this is your only option outside of re-installation (and possibly re-activation if you cannot get into an app to de-activate).
YOu know I thought about that. Good idea and then I can see how it works. I assume it is good with Lion? Adobe is no longer selling CS5.5 thought because 6 is about to come out - but I think the trial is still there. I have been unting. Also amazon has 5.5 but they say it is only good through Leopard - is it fine with Lion?
CS5.5 is still there for trial and purchase (CS6 is only pre-order at the moment).
http://www.adobe.com/cfusion/tdrc/index.cfm?product=dreamweaver
The only Dreamweaver issues with OSX Lion listed on Adobe's website relate to CS4
http://helpx.adobe.com/x-productkb/global/known-issues-mac-os-10.html
CS5.5 works fine with Lion (though not officially listed as being suppported).
CS6 offically supports Lion
Looks like Web Premium CS5.5 has been withdrawn already.
Web Premium is no longer available in CS6.
It's been merged with Design Premium and is now called Design & Web Premium
http://www.adobe.com/products/creativesuite/design-web-premium.html
And they don't give a price...
Also have a look at the Creative Cloud (new in CS6) subscription offering.
Small upfront outlay (US$50 monthly payments) gives you access to a boatload of products and services.
http://www.adobe.com/products/creativecloud.html?promoid=JQPEQ
If you're in its target market, it's worth serious consideration when you compare TCO for Cloud vs Perpetual Licenses over 2 or 3 or more years.
Hey Marty,
had the same problem here with PSE 8 after system recovery from time machine backup. I also updated to Lion couple of month ago. I also tried all of the listed solutions on the adobe support pages but none of them worked. The folder FLEXNet_Publisher in the systems hard drives folder Preferences, which it says to be deleted does not exist and was only found in the application support folder. I also tried all of the other solutions listed on this page: http://helpx.adobe.com/x-productkb/global/error-licensing-stopped-mac- os.html and had more or less the same problems, it did not work.
I found the following solution myself by doing this:
go to the folder [hard drive]/Library/Application Support/FlexNet Publisher and make a copy of this folder
then go to the folder [hard drive]/Library/Preferences and paste this copied folder there.
Then try again to start your application and now it should show you the licenceregistry window. Type in your serial number and confirm. Then the application starts and runs properly. So it was on my system.
Interesting approach. I finally got on the phone with Adobe tech support and after many tries of various things, we finally got it working. He had to get on my computer remotely to figure it out - took installing as a different user and so forth. It seems OK now except for Bridge which runs slow as molasses - like useless.
THX @ Lsan61, but remember, my solution to copy and paste the named folders always works one time. I finally deleted PSE8 and reinstaled it again and it runs properly now. There was no problem with system difficulties, because of the 32 bit system PSE8 originally was made for and and the 64 bit systems (OS XLion) I have running now. I somewhere red, that this might cause installing problems.
My issue was with my MacBook I bought it last November and it crashed, so Genius Bar reinstalled my HD and I used Time Machine to retreive my last state of normalcy. All of my other programs work fine except Adobe Creative Suite had the 150:30 error message. It is working now thanks to your solution so I am least able to complete my project. However if I have future problems I will call Adobe during their business hours, since I own the software legally they should (hopefully) be able to help me. Thanks again!
