son007dp
Problem with catalog back up upon exit
Apr 28, 2012 1:19 PM
Hello,
since about 2 weeks, my LR4 mac version refuses to back up the catalog upon exiting (it did it successfully for the last 3 months, last successful backup was on April 12, 2012.
The backup location is on a NAS.
The message I get is:
Lightroom was unable to back up the catalog named “Son_Images-LR4”.
Please check your folder permissions, and make sure that you have available space on your backup drive and main catalog's drive.
Try Again - Quit - Choose different backup folder...
I have tried to choose different backup folder locations on local hard disk, to no avail, so I end up quitting without doing the backup.
Thanks for the help.
Regards
____________________________________
Some data about my config
Lightroom version: 4.0 [814577]
Version: 10.7 [3]
Application architecture: x64
Physical processor count: 4
Processor speed: 2.7 GHz
Built-in memory: 12288.0 MB
Real memory available to Lightroom: 12288.0 MB
Real memory used by Lightroom: 581.8 MB (4.7%)
Virtual memory used by Lightroom: 2596.2 MB
Memory cache size: 389.0 MB
Displays: 1) 2560x1440
Application folder: /Applications
Library Path: /Volumes/Photos (La Cie 1TB)/Son_Lightroom_Catalogs/Son_Images-LR4.lrcat
Settings Folder: /Users/sondophan/Library/Application Support/Adobe/Lightroom
    Apr 28, 2012 1:31 PM   in reply to son007dp
    So did you check your folder permissions? Did you check available space on the backup drive? Did you check available space on the main catalog's drive?
    Apr 28, 2012 10:21 PM   in reply to son007dp
    Same here. Since update from LR 4.1 RC1 to RC2 backup doesn't work. This is not related to folder permissions. Nothing has changed in between. It does not work on a remote share, nor does it work on the local drive - looks like totaly broken. Btw. I'm using OS X Lion.
    Apr 29, 2012 1:03 PM   in reply to son007dp
    Apparently, I have now read three people complaining about this exact problem. You should file a bug report.
    Apr 30, 2012 12:28 PM   in reply to son007dp
    The link is right there on the main page of the Forum, it says Feature Request/Bug Reporting
