Narration won't show in timeline with PREL 8.0
Apr 29, 2012 10:41 PM
Tags: #recording #narration
I've tried two different microphones and can record a narration in my video.   Once I stop recording, it usually places the narration down in the timeline.   For some reason it won't add the narration to my narration line.  I've test the mics on my computer so I know they both work.  When I "Add narration" and push record, I can see that it is recording and moving along in my video.
Any thoughts?
Rob
    Apr 30, 2012 4:57 AM   in reply to smetlogik2
    Have you ensured that no other audio clips are on the Narration audio track on your timeline?
    Also, I'm confused when you say: "It usually places the narration down in the timeline.  For some reason it won't add the narration to my narration line. "
    Is it adding narration clips to your timeline or not?
    Apr 30, 2012 10:45 AM   in reply to smetlogik2
    Can you post a screen capture of your timeline so we can see what it looks like after you've recorded narration?
    May 1, 2012 4:48 AM   in reply to smetlogik2
    Thanks for the screen caps.
    I can't tell from the captures, however, if your timeline includes more audio and/or video tracks than are currently seen. Is there a scroll bar on the right end of the timeline? If so, scroll up to see if there are tracks above Audio 1 and Video 1 where your narration might be appearing.
    Otherwise, I can't say.
    May 1, 2012 11:16 AM   in reply to smetlogik2
    Very good troubleshooting!
    That bar is called a Work Area Bar. It designates a segment of your timeline. You can output as a video, for instance, only the Work Area Bar. When you render your timeline, only the portion under the Work Area Bar will render. And, as youv'e seen, some things (like narration) won't apply outside the Work Area.
    By default, the Work Area Bar should expand and contract to cover your entire project as you work. Version 8 has a bug in it though: If you manually set the Work Area Bar, it remains as you've set it and will no longer cover your entire project's timeline. Unfortunately, you were a victim of that bug.
    Glad you got it figured out though!
    To reset the Work Area Bar so that it covers your entire project, press the \ key (above the Enter key) to display your entire project timeline, then double-click on the Work Area Bar.
    May 5, 2012 9:30 AM   in reply to smetlogik2
    For more info on the WAB (Work Area Bar), see this ARTICLE.
    Good luck,
    Hunt
