rickaz1
copy and past image into another box same size and location
Jun 14, 2011 1:58 PM
Indesign CS5 Mac
Have a lage document with portraits - 1 of the portraits needs to come out and need to shift them over. In Quark you could copy and past image into another image box and get same scale and X&Y location. I have tried the direct selection tool copied the image and paste into the empty box next to it but the scale is off.
Is there a work around this in Indesign.
    Jun 14, 2011 2:00 PM   in reply to rickaz1
    Not a workaround, but a tool: use Edit -> Paste in Place
    Jun 14, 2011 2:47 PM   in reply to rickaz1
    Oh, I misunderstood entirely. Nevermind! I try to avoid scaling raster images in ID, so I have no idea whatsoever how you'd do this, or if it's even possible.
    Jun 14, 2011 2:53 PM   in reply to rickaz1
    I'm confused. Why not just move the image in the existing frame? You don't have to move the frame to move the content inside it.
    Jun 14, 2011 3:24 PM   in reply to rickaz1
    I'm not able to get the scale to change when I paste into, but I haven't tried really hard. You'd have to do something atypical for scale to change, or do something after you paste. When you paste into another frame, the content should be centered.
    But I will ask again. WHY do you need to paste into a new frame? It sounds to me as if you need to either crop the image or shift it in the existing frame.
    Jun 14, 2011 3:53 PM   in reply to rickaz1
    InDesign, thankfully, is not Quark. If you would explain clearly what you want to accomplish, we could tell you the best way to do it in ID. And tell us which version you are using.
    Jun 14, 2011 4:09 PM   in reply to Peter Spier
    Perhaps our intrepid original poster is unfamiliar with InDesign's handy Fit Content to Frame and Fit Frame to Content tools...
    Jun 17, 2011 1:22 PM   in reply to rickaz1
    Edit>Paste Into
    Jul 16, 2011 1:40 PM   in reply to rickaz1
    Our intrepid original poster is being very patient and polite yet nobody is helping. It is very true that Quark will easily handle moving imported graphics around by allowing them to be cut from one frame and pasted into another without losing track of the original image directory. This saves a the work of re-importing and "fitting to frame" which isn't necessarily how the image has been sized anyway! I would love to learn if InDesign can handle this because it would simplify the job considerably if a situation occurs such
    as the orignal poster described.
    Jul 16, 2011 3:46 PM   in reply to CindyShields
    I don't believe there is anything new to say...
    Jul 17, 2011 2:21 AM   in reply to rickaz1
    What Joel says is explained:
    http://indesignsecrets.com/how-frame-fitting-options-affect-paste-into .php
    Using the eyedropper tool on the frame of the source picture can fix it.
    I have been struggling with this issue as well.
    As proposed using the selection tool and "paste into" seems to do the job.
    However it paste the entire frame into the new frame, which is not always what you want.
    A clever person made a script (I cannot find his name) which do the job (behind the scene it pastes into and removes the original frame):
    ___
    tell application "Adobe InDesign CS5"
        activate
        set mydoc to active document
        set myFrame to selection
        --make sure there is a selection
        if myFrame is {} then
            display dialog "Select a frame and try again"
            return
        end if
        --make sure the frame has been copied
        try
            paste into
        on error
            display dialog "Clipboard is empty, copy a frame with an image and try again"
            return
        end try
        --the pasted item
        set myItems to all page items of item 1 of myFrame
        --test for a frame with an image 1 means an image or an empty frame
        if (count of myItems) is 1 then
            delete item 1 of myItems
            display dialog "Copy a frame with an image and try again"
            return
        end if
        --item 2 is the image
        select item 2 of myItems
        copy
        --delete the image's frame
        --select the original frame
        select myFrame
        paste into
    end tell
    ___
    Jul 25, 2011 4:29 AM   in reply to rickaz1
    I know what you are asking. I am a long time user of Quark and this cut and paste of content of a picture box is very useful but doesn't quite work the same in InDesign.
    In Quark you simply have to cut and paste the content from one box into another - the paste replaces the original content immediately.
    I have discovered that in InDesign you can cut as usual the content from your first picture box, but after selecting the target picture box you need to firstly delete the file that is there and then use 'Paste into…' which is ALT & CMD & V.
  • Rob Day
    Oct 16, 2007
    Jul 25, 2011 9:19 AM   in reply to emmett_h
    In CS1 you could do it but in newer versions you need a script. If you try to copy an image from frame 1 to frame 2, and frame 2 is inside the copied image's bounds, pasting into positions the image to the original bounds:
    The script puts the image at the same bounds relative to the target box, which might be preferable:
    If the target frame is outside of the original's bounds then the image gets centered, which might force you to reposition the image:
    Apr 29, 2012 1:54 AM   in reply to Rob Day
    Hi Rob,
    Do you still have your earlier version of the script available for CS4?
    The above works great in CS5 but for IDCS4 it comes up with the dialog "Copy a frame with an image and try again"
    Much Appreciated,
    GreenRookie
  • Rob Day
    Oct 16, 2007
    Apr 29, 2012 8:29 AM   in reply to greenrookie
    Try this for CS3 or CS4. With CS5 images are page items, but in CS3 they were in a seperate graphics class, which is why the CS5 script breaks.
    This version works the same way, with the black Selection tool you need to select the source frame, select the destination frame and run the script
    tell application "Adobe InDesign CS3"
        activate
        set myDoc to active document
            return
        end if
        --make sure the source frame has been copied
        try
            paste into
        on error
            return
        end try
        -- check for page items inside of the pasted item
        set myPasted to all page items of item 1 of myFrame
        --if there are none it's an image so delete and show message (this changes in CS5 where a page item can be an image)
        if (count of myPasted) is 0 then
            delete item 1 of myFrame
            return
        end if
        --the selection is now the the frame we pasted into, so select the inside frame
        select item 1 of all page items of item 1 of item 1 of selection
        cut
        --paste in place gets the correct position
        paste in place
        --get the temporary paste which we need to delete
        set temp to selection
        --in CS3 to select an image it's item 1 of all graphics and not page items
        set selection to item 1 of all graphics of item 1 of temp
        --cut the image, delete the temp and paste into
        cut
        delete temp
        select myFrame
        paste into
    end tell
    Apr 30, 2012 3:40 AM   in reply to Rob Day
    This works great for me and I hope it will help others using CS3 or CS4.
    Thank you so much Rob!
    GR
