Executing Remote Stored Procedures
Apr 23, 2012 10:30 AM
Tags: #cfquery #coldfusion #sql #coldfusion9 #stored_procedure #cfstoredproc #sql_server
I am trying to execute a stored procedure through ColdFusion.  The stored procedure being executed attempts to insert local data into a remote server table through a linked server.
Attempting the stored procedure call from ColdFusion results in an error:
[Macromedia][SQLServer JDBC Driver]The DBMS returned an unspecified error.  The command code was 253.
However, if the stored procedure is exected within SQL Server Management Studio, the call works correctly, no error.
I am using the same credentials within Management Studio as within ColdFusion (via Datasources).
    Apr 23, 2012 11:10 AM   in reply to HiTopp
    Are you able to run any Stored Procs from that database using ColdFusion?
