Cs 5.5 render problem, severe loss in quality.
Apr 30, 2012 9:26 AM
I film on a Canon 60D in full HD quality. The footage right out of the camera is excellent. However, when I edit it and render it through Adobe Premiere it looses a large amount of quality. It gets what appears to be a layer of white noise on top of it. Here are some screenshots to help illustrate:
Uten navn.jpg This one shows the original footage in Windows Media Player and the rendered footage in VLC.
Uten navn 2.jpg This one shows the original footage in VLC and the rendered footage in Windows Media Player. Not as big a difference but still too big a difference for me to ignore.
you.jpg This one shows the original footage on the left and the rendered footage on the right in 1080p on youtube. Still a large difference in quality which shouldn't be there.
The following are my complete render settings.
What is wrong?
    Apr 30, 2012 10:31 AM   in reply to DanielFilming
    What is wrong?
    Your testing methodology.  You can't trust software players, computer monitors and especially Youtube uploads to judge the quality of media.  For that, you need a properly calibrated external TV.
    Apr 30, 2012 11:50 AM   in reply to DanielFilming
    Does not the Canon shoot in 1920x1080?
    Your sequence settings are 1440x1080 1,33 aspect.
    Why the audio bitrate so high?
    Apr 30, 2012 12:56 PM   in reply to DanielFilming
    Start with using the format your camera uses. XDCAM HD is wrong. If you don't know what codec your camera uses, forget about a sequence preset and just import a clip from the Media Browser and right click on the clip in the project panel and select New Sequence from Clip.
    'Every autodidact had an idiot as a teacher'
    Apr 30, 2012 1:08 PM   in reply to DanielFilming
    If you have no idea what you are doing stick to the default settings/presets, they are usually the best.
    Make a new sequence and copy everything from the old into the new one.
    This looks more appropriate for your camera.
    For learning Premiere you can start here:
    http://forums.adobe.com/message/3804423#3804423
    Apr 30, 2012 1:24 PM   in reply to DanielFilming
    What is final destination of your footage?
    Apr 30, 2012 1:34 PM   in reply to DanielFilming
    Try using the H264 - Youtube preset after getting uyour sequence and camera settings matched..
    BTW - Higher video bitrates are what provide better quality
    Apr 30, 2012 1:40 PM   in reply to DanielFilming
    Use the HDTV 1080p 24 high quality preset.
    You only need to change the framerate to 23.976 and check Render Use Maximum Render Quality; don't touch the rest.
    Try again with the new sequence setting.
    Apr 30, 2012 2:10 PM   in reply to DanielFilming
    I said dont touch anything other then i told you to change.
    You will always suffer a slight quality loss.
    Did you upload to YT?
    May 2, 2012 9:25 PM   in reply to DanielFilming
    Ann gave you a good link, but here it is again...
    Start here to learn Premiere Pro: http://adobe.ly/psbYc4
