Please help. I have Dreamweaver CS5.
I put a Spry Vertical Menu Bar on http://www.dianaoboe.com/index.html It looks and behaves the way I want. Then I copied/pasted it to http://dianaoboe.com/contact.html and it is not looking the same.
I have not yet tried putting it on other pages until I've got both of these working.
What's happening??
Laurie
Here's the css for the Vertical Spry Menu:
@charset "UTF-8";
/* SpryMenuBarVertical.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
ul.MenuBarVertical
margin: 0;
padding: 0;
list-style-type: none;
font-size: 95%;
cursor: default;
width: 8em;
font-family: Tahoma, Geneva, sans-serif;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are same fixed width as parent */
ul.MenuBarVertical li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: start;
cursor: pointer;
width: 8em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarVertical ul
margin: -5% 0 0 95%;
padding: 0;
font-size: 100%;
position: absolute;
z-index: 1020;
cursor: default;
width: 8.2em;
left: -1000em;
top: 0;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarVertical ul.MenuBarSubmenuVisible
left: 0;
font-size: 90%;
width: 9em;
/* Menu item containers are same fixed width as parent */
ul.MenuBarVertical ul li
width: 9em;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Outermost menu container has borders on all sides */
ul.MenuBarVertical
border: 2px solid #ccc;
/* Submenu containers have borders on all sides */
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarVertical a
display: block;
cursor: pointer;
background-color: #bacbdb;
padding: .5em 0.75em;
color: #036;
text-decoration: none;
/* [disabled]background-image: url(../images/casesm.jpg); */
/* Menu items that have mouse over or focus have a blue background and white text*/ ***************
ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
background-color: #c5b6a1;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
background-color: #89641E;
color: #CCC;
/* [disabled]background-image: url(none); */
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarRight.gif);
background-repeat: no-repeat;
background-position: 95% 50%;
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarVertical iframe
position: absolute;
z-index: 1010;
filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarVertical li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
___________________________
Where I put the ********* is the command that seems to be showing on the contact page. Help please.
You have not included the code that initialises the menubar (constructor) in the offending document. Place the following near the bottom of the page as per the document that does work.
var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
Gramps
