ededman1
inDesign 5.5 crashing for all PDFs and SWFs
Apr 30, 2012 7:17 AM
Hello -
My inDesign 5.5 is crashing when making - low rez PDFs - PDFX-1 AND SWF. I can't export anything
I have updated all Adobe products
Run a utlity check---
Do i need 7.01 for CS 5.5
    Apr 30, 2012 12:02 PM   in reply to ededman1
    No, you need 7.5.2. Install that and see if the problem goes away.
    If not., what is your OS? Sounds like OS X. If so you should have a crash report. You can upload that to Pastebin.com (NOT HERE) and put a link to the report here.
    Apr 30, 2012 2:14 PM   in reply to ededman1
    John is much better at interpreting crash reports than I am, and yours is unusual-- the crash is in thread 31 -- but it does look graphics related to me.
    You should replace any files that are using OPI.
    Apr 30, 2012 3:09 PM   in reply to ededman1
    Can you turn off or quit suitcase fusion and then check?
    Also Can you follow the belwo mentioned KB:-
    PDF export background task hangs | InDesign CS5, CS5.5
    Apr 30, 2012 3:12 PM   in reply to ededman1
    John checks in regularly.
    You can define a prefilight profile for Live Preflight that will flag OPI links.
  • John Hawkinson
    Jun 25, 2009
    Apr 30, 2012 10:24 PM   in reply to ededman1
    I think, perhaps, I check in irregularly, but still frequently :-).
    The crash is in a atypical thread (not thread 0) because it is in the [background] PDF export, which takes place in a different thread.
    Unfortunately it's not very enlightening.
    It's in the guts of AdobeBIB, about which I have recently been advised: "Bravo Interface Binder is a low level framework developed by coretech group that handles first, low level mechanics of function calls between components and second, patterns that one component should employ when using services from another component."
    Have you tried exporting to IDML and trashing your preferences?
    If so, then I think the next step is Divide and Conquer.
    Working with a copy of your document, delete half the pages, and see if hte problem follows. Repeat until you find the source.
    Could you share a copy of your file with me?
