Shood123
PDF color off
Apr 30, 2012 10:16 AM
I have a pdf file with color slides and when I go to print it, the first page slides print in black instead of the blue it should print. How can I fix this? I need it for a manual.
    Apr 30, 2012 2:57 PM   in reply to Shood123
    Was the pdf exported from InDesign?
    Does it appear correct in InDesign with Overprint Preview enabled? (View Overprint Preview)
    What are the cmyk values in Acrobat?
    Apr 30, 2012 2:58 PM   in reply to Daniel Flavin
    Sorry, I thought I was in the Indesign forum
    May 1, 2012 5:39 AM   in reply to Shood123
    I'm guessing your PDF is using a spot color blue and your printer is not able to properly render it. Go to Tools> Print Production> output preview (Acrobat 10), Do you see a spot color separation? If yes, go to Tools> Preflight> PDF fixups> Convert to CMYK, Save. If you have the option, convert the spot color to CMYK before saving (or exporting) to PDF. It's also possible you have a mix of RGB and CMYK in your PDF, if so, one of the PDF fixups might help.
