Flash Player doesn't play smoothly and out of sync in full screen
Apr 28, 2012 9:04 PM
Hello! Everyone
The flash player (11.2.202.235) does not play smoothly and in full screen audio and vidoe is out of sync.  I didn't use to have any problem at all, it only started about two weeks ago and since then despite trying various things (i.e. disabling hardware excelration, uninstalling & reinstalling, trying various browsers etc.) has not resolved the issue.  I don't know why it has suddenly stopped playing smoothly as I have not installed any software recently which might have cuased this.
I am using Windows XP (service pack3) and have dual partion with dual operating system (both XP).  There is the same problem on both operarting system and flash player won't run smoothly on either of them.  Although my computer and graphics card is quite old but the downloaded movies/DVD playback is fine even in full screen.  It runs smoothly and audio&video is in sync so I don't think it could my the graphics card.
As I mentioned I have tried all the browsers but without any luck.  The BBC iplayer plays ok most of the time if not in full screen but as soon as you make it full screen the vidoe is more like a slide show and very jittery and audio&video gets out of sync.  Same with youtube vidoes, they play ok when not in full screen but the video in full screen does not play smoothly and audio&vidoes gets out of sync.  However the ITV player & Channel 4 content on 4OD does not even play smoothly when not in full screen and the video&audio is out of sync all the time.
It would be really helpful if anyone can suggest anything to resolve this issue as I have not been able to find anything on the internet to solve the problem and its driving me up the wall.  Although I have tried to include as much details as I could think of so please let me know if I have missed any details that could be crucial in order to identify the problem.
Thank you very much for reading this and taking the time to reply and your feedback.
Below is the DxDiag report for my laptop:
Time of this report: 4/22/2012, 00:15:58
Machine name: TIMES-LAPTOP
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
Language: English (Regional Setting: English)
System Manufacturer: TimeComputers
System Model: VT8372
BIOS: Insyde Software MobilePRO BIOS Version 4.00.01
Processor: mobile AMD Athlon(tm) XP 2000+,  MMX,  3DNow, ~1.7GHz
Memory: 1248MB RAM
Page File: 809MB used, 2790MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904) DX
Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
------------ DxDiag Notes ------------
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
-------------------- DirectX Debug Levels --------------------
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
--------------- Display Devices ---------------
Card name: S3 Graphics ProSavageDDR
Manufacturer: S3 Graphics Co., Ltd.
Chip type: S3 ProSavage DDR
DAC type: S3 SDAC
Device Key: Enum\PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00
Display Memory: 32.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Digital Flat Panel (1024x768)   Monitor Max Res:
Driver Name: s3gnb.dll
Driver Version: 6.14.0010.0025 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/2/2004 14:02:26, 402048 bytes
WHQL Logo'd: Yes   WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: s3gnbm.sys
Mini VDD Date: 3/2/2004 14:02:30, 167040 bytes
Device Identifier: {D7B75DD3-CE44-11CF-D873-7FA3A1C2CB35}
Vendor ID: 0x5333
Device ID: 0x8D04
SubSys ID: 0x83751071
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_A ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled DDraw
Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
------------- Sound Devices -------------
Description: Vinyl AC'97 Audio (WAVE)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_83751071&REV_50
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: vinyl97.sys
Driver Version: 6.14.0001.4170 (English)
WHQL Logo'd: Yes
Date and Size: 8/10/2006 07:32:14, 204672 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 48000 Static/Strm
HW Mix Bufs: 1, 0  Static/Strm
HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No  EAX(tm) 2.0
Listen/Src: No, No    I3DL2(tm)
Listen/Src: No, No Sensaura(tm)
ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
--------------------- Sound Capture Devices ---------------------
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
----------- DirectMusic -----------
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
------------------- DirectInput Devices -------------------
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
----------- USB Devices -----------
+ USB Root Hub |
Vendor/Product ID: 0x1106, 0x3038 |
Matching Device ID: usb\root_hub |
Service: usbhub |
Driver: usbhub.sys, 4/13/2008 19:45:37, 59520 bytes |
Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
