Hi, I am trying to create a pdf book with chapter 1 titles appearing in all footers on the left page (in chapter 1), and chapter 2 titles in footers on all right pages (in chapter 2). So far I only have one master page, a two-page master with text frames on both pages. After I made this master, I dropped my text in and it autoflowed. I then made a second master page, based on A-master called B-chapter 2, with section markers on the right side instead of the left. I then applied this master to the relevant pages, and it looked fine. However, now that I've done this, I no longer have control over the text frames in chapter 2 using the master pages. What have I done wrong? I would like to have layout as described, but still be able to adjust the size of all text frames in all chapters, by using the master page text frames. Is this possible? Basically I want to alternate the side section titles appear on, but retain control of the text frames via master pages. Appreciate any thoughts.
What you describe there makes very little sense to me at all. Which makes me think that I'm not understanding what you're describing, or you haven't described it very well, or the most likely scenario is that you've done something really bizarre in your setup.
Can you please post some screen shots of the pages and what is happening - from the description it's quite hard to imagine what you've done.
Sorry about the verbiage!
I think my setup is bad. I inserted the book's content into the master page text frames, by pressing shift ctrl on page 1, then pasting into that frame. Is it better to create text frames just for the content? If so, how do I change the size of all the text frames at once?
I've now got my book's content flowing in text frames that are independent of text frames in the master pages. I'm not using any text frames in the master pages anymore, and i'm able to alternate how footers appear by using more masters. Thanks for making me realize my setup was way wrong. Now my main question is how to adjust the size of text frames on all pages. Is the best way to do this to find all of them using the find function, then apply an object style, then modify them all using the style? Anyway, you already answered my questioned by showing me where I went wrong. Much obliged. ![]()
I don't understand why you need to change text frame sizes all at once?
If you create margins on your master pages to where you want the text frame to be.
Draw a text frame on the Master Pages.
Then when you insert text into the main page you'll have a text frame within those margins on every page.
The reason I need to change text frame sizes all at once is that the size of the book may change, depending on how the content (which includes many graphics) fits as I lay it out; if the page size is reduced, the text frames will also have to be made smaller, for example. and i'm assuming object styles might be best for that, instead of doing what I was doing before, modifying the frames using masters (which i'm now only using for footers, headers etc.).
