rizzledon
Having outer glow problem
May 1, 2012 7:16 AM
When I create an outer glow on a shape I'm getting unwanted glow in other areas. Any suggestions?
    May 1, 2012 7:36 AM   in reply to rizzledon
    rizzledon,
    No celestial beings up there?
    May 1, 2012 8:26 AM   in reply to rizzledon
    rizzledon,
    It looks rather strange, as if after fading the outer glow starts gathering strength again, visible at the corners of the Bounding Box of the glow effect.
    What happens if you close down Illy and  Move the folder (you may move it back to reset your preferences)?
    May 1, 2012 9:23 AM   in reply to rizzledon
    You have a conflict between the amount of glow and the Document  Raster Effects setting for Add around object as this
    See the glow effect off the page. Try adding more space around the object.
    May 1, 2012 9:50 AM   in reply to Larry G. Schneider
    Maybe mayb not there seems to be a bug of somekind look at these ssettings particularly att the one for 30 blur athen look at the others, notice that at 30 it appears and at 32 or 29 it is gone and it does not matter how much extra added space I give it 30 will produce the artifact.
    Same settings at 40
    So try changing the setting of the blur to a different number like add or subtract a pt.
    May 1, 2012 10:12 AM   in reply to rizzledon
    It is a bug that occurs in some recent versions of Illustrator.
    I think it has been introduced in AI CS 2 or CS 3.
    May 1, 2012 6:06 PM   in reply to rizzledon
    You're welcome!
