How to get Vault plugin to report failure when the targetURL connection fails?
Apr 30, 2012 7:24 PM
Tags: #vault #targeturl
We're seeing a situation with the Vault plugin where when the call to the "targetURL" results in a server error, it reports that in the build output, but the plugin doesn't report a failure, so it looks like the build was successful. If you're not paying attention, you'll miss the Vault plugin failure.  It doesn't matter why the call to the targetURL fails, it's just a symptom on the server.  What's the issue here is that when that fails, the plugin should also fail, but it doesn't.
  • Justin Edelson
    Nov 24, 2010
    May 2, 2012 3:17 PM   in reply to david.karr
    This feature was added last year using the configuration property name failOnError. You need to change to the new content-package-maven-plugin, the successor to the maven-vault-plugin.
    For backwards-compatibility reasons, the default is false.
    Something like this should work:
    <plugin>
        <groupId>com.day.jcr.vault</groupId>
        <artifactId>content-package-maven-plugin</artifactId>
        <version>0.0.13</version>
        <configuration>
            <failOnError>true</failOnError>
        ...other config...
        </configuration>
    </plugin>
    With the exception of some fairly esoteric goals which were only used internally, the content-package-maven-plugin is entirely backwards compatible with the maven-vault-plugin.
    Justin
