Hello! I know after hours of research this has been asked quiet a few times, in different ways, but I can't find an answer for this:
How do you add more slides to this widget? I need more than 4.
I have tried to play around with the png images for the buttons (although I don't need the buttons - just the numbers. I don't really want the buttons.) I don't know if I'm just doing it wrong or what, but nothing is working.
I have looked through all sources of code, and have found nothing to help me!
If you guys could help me figure this out, it would be appreciated! Thank you!
Okay, I found the answer myself, and I wanted to post it for anyone else who is interested:
I did this earlier, and it didn't work. So I'm not sure what precisely made this work for me.
First, I went to wanderlust-brown.css. I went to
.WLBSlideShow .SSSlideLinks {
This is where I found a rule for "right" - I moved it way over to see if it would pop out (I saw something about moving this over in another forum)
I did 100px;
Then, I went back to add another article. I'll post an entire section so you guys can see EXACTLY what you need to write:
<div class="article">
<div class="photo"> <img src=
"(YOUR IMAGE LINK)" alt="Orchids" />
<div class="caption">Orchids</div>
</div>
<div class="banner">
<div class="title">CONTENT</div>
<div class="subTitle">CONTENT</div>
</div>
<div class="content">
<p>CONTENT</p>
<button type="button"><span><span><span>More!</span></span></span></button>
</div>
</div>
</div>
MAKE SURE you post this after the THIRD </div> on the 4th slider.
That did the trick for me! It kinda did something weird to my layout and added some spaces above my sidebar, but that takes about 3 seconds to fix.
I hope this helps someone!
Hey, Since u r woring with wanderlust as well, do u know how to remove the slider buttons?
I have deleted some code in the .css file to remove the png's, but then it creates buttons automatically.
so now i have a 'previous' and 'next' button plus the numbers 1 2 3 4 for each slide. but i want those links gone..
can anyone help?
