grandpooba2
Sandy bridge is ok now I hope? New build help.
Apr 29, 2012 8:46 AM
I did do some searching on here and am building a new machine to work with ppcs5.5 .
This forum has the best tech guys I have ever seen so I will do my best out of respect to make my text ramblings clear lol.
I have built the Videoguys DIY 8 system http://www.videoguys.com/Guide/E/Videoguys+DIY9+Its+Time+for+Sandy+Bri dge+E/0xe9b142f408a2b03ab88144a434e88de7.aspx
I also have 5  drives at my disposal. 1= OS drive/boot, the other four still up in the air on best setup for this machine. I did look at Harms generic disk displays and might
have an idea but open to whatever advice is offered. Ok advice would be still awesome. ; )
I guess I am just making sure theis setup with the 17 2600 is a good choice for cs5.5 and 6.
I did see some negatives on the forum about it. I have one day till I must decide to keep or return lol. Ouch.
Thank you for your time guys. I mena that.
David
Replies 1 2 Previous Next
    Apr 29, 2012 9:09 AM   in reply to grandpooba2
    David, what negatives are you talking about? What other questions do you have?
    Apr 29, 2012 9:19 AM   in reply to grandpooba2
    David,
    The negatives that you read refer mainly to the limited number of available PCI-e lanes on the LGA 1155 platform. You see, LGA 1155 has only 20 total PCI-e lanes - but four of those are eaten up by the DMI 2.0 connection between the CPU and the PCH (let it be Z68, Z77, P67, etc.). And of the eight PCI-e lanes offered in the PCH, most of them are eaten up by onboard third-party controllers such as the LAN and extra USB 3.0 and SATA/eSATA controllers. That leaves fewer than four open PCI-e lanes on the PCH, forcing one to use some of the 16 available PCI-e lanes on the CPU itself. This, in turn, reduces the available number of PCI-e lanes for the primary GPU. And although the fastest current (and newest) GPUs barely take full performance advantage of even PCI-e 2.0 x8, this may change with future GPUs.
    Apr 29, 2012 9:51 AM   in reply to grandpooba2
    The question is simple, the answer is up to you.
    The 1155 platfom is the mid-level model with the limitations Randall mentioned. It is economical but not attractive if you intend to use a dedicated raid controller, a third party card like Matrox, Black Magic or AJA, because in that case you lose around 10% performance.
    The 2011 platform is the high-end option, but the price is accordingly.
    For most the 1155 platform is adequate and economical, for more demanding work the 2011 is about the only option.
    Apr 29, 2012 9:46 AM   in reply to grandpooba2
    grandpooba2 wrote:
    So would you suggest abandoning this combo of cpu/mobo for something else at this time? And thank you as well.
    That setup should be fine as long as you don't try to cram in a high-end GPU, a discrete hardware RAID controller card and a PCI-e x4 I/O card all in the same system. But if you really need all of those components in the same PC, you really should spend an extra several hundred dollars for an LGA 2011 motherboard and a hexa-core i7-39xx CPU.
    Apr 29, 2012 10:26 AM   in reply to grandpooba2
    Yes, think of comparing LGA 1155 to LGA 2011 as like comparing a Camaro with a Corvette.
    Apr 29, 2012 12:21 PM   in reply to grandpooba2
    Apr 29, 2012 5:02 PM   in reply to grandpooba2
    Speaking of the i7-3820 in one of the links: It is not all that much better (faster) than Sandy Bridge in terms of CPU performance because the i7-3820 is also only quad-core like the i7-2600K. In fact, an overclocked i7-2600K will beat an i7-3820 at its maximum Turbo frequency. As such, the i7-3820 is only recommended if you want a cheapo CPU for a high-end platform with the intention of later upgrading to a full-blown hexa- or octo-core i7 CPU in the future.
    Apr 29, 2012 5:56 PM   in reply to grandpooba2
    Against recommendations this afternoon I went out and picked up an i7-3770K ($290) which I am going to plug into my Z68 motherboard.  Should have some comments in the next couple of days.  This theoretically gives me PCIe 3.0 to go with my GTX 680
    Apr 29, 2012 7:54 PM   in reply to grandpooba2
    grandpooba2 wrote:
    If going 2011 will this be worth the upgrade Xeon E5-2620 2GHz LGA 2011 Processor
    Not worth the price: At more than $400, its price is too close to an i7-3930K for comfort. Plus, that E5-2620 is permanently locked at 2.0 GHz, and cannot be overclocked at all. By contrast, the i7-3930K runs stock at 3.2 GHz, and can be overclocked. This makes the only reason to buy an E5-2620 being if you want a cheapo dual-processor-capable CPU and a dual-CPU motherboard with the intention of upgrading to more robust (and far more expensive) octo-core CPUs some time in the future. Otherwise, that E5-2620 is best left to DP server use.
    Apr 29, 2012 11:26 PM   in reply to grandpooba2
    Intel is not my brand of choice. Their boards are often inflexible and lack features that other brands do have. I would put Asus and Gigabyte on the top of my list, and specifically the Asus P9X79 WS.
    Apr 30, 2012 9:28 AM   in reply to grandpooba2
    grandpooba2 wrote
    Harm. If I stay with the p8z68-v pro/gen3 mobo 1155 would I be better to go 3770 or 2700 and would it be any performance boost to do this??
    If you have the option of waiting a day or two, I will be plugging in an i7-3770K in my Gigabyte GA-Z68XP-UD4.  Once I replace the i7-2600K and update the BIOS it will be PCIe 3.0 qualified.  It is necessary to have a 22nm chip to run PCIe 3.0 on that board.  So I am wondering if the the ASUS P6Z68 has PCIe 3.0 capabilities that require the 22nm (i7-3770) chip?  Also if you go with Harm's suggestion of the P9X79 board and were to put in an i7-2700 (32nm) chip it would sound to me like the reverse may be true, that unless you have an LGA 1155 22nm chip PCIe 3.0 will never be possible.  Also are you near a Microcenter store?  If you or a friend or a relative can walk in the store you can get the i7-3770K for $290 plus any local tax.  There probably will be very little performance difference but you will have a product lifetime
    Apr 30, 2012 9:31 AM   in reply to Bill Gehrke
    Actually, the P9X79 is a Socket 2011 board for Socket 2011 CPUs. Socket 2011 does support PCI-e 3.0, albeit unofficially since Intel does not currently certify the LGA 2011 platform for PCI-e 3.0.
    Apr 30, 2012 11:28 AM   in reply to grandpooba2
    Guess what? The higher-ranked i7-2600K systems than that 49th-ranked one, save for Bill's own overclocked 5.0GHz Z68-based system with 32GB of RAM and the GTX 580, are all running an older version of Premiere Pro - 5.0.3, which uses a different caching system. (Likewise, all of the CS5.5 systems above Bill's that ranked higher are overclocked i7-39xx or hexa-core i7-9xx systems or overclocked dual-Xeon X56xx based systems.) So, for the comparison to be valid, filter out the results on the PPBM5 results table so that only those systems running version 5.5 are included.
    And yes, I did test my own i7-2600K system (when it had a GTX 470 installed inside of it) with both 5.0.3 and 5.5, and my ranking plummeted from 35th with 5.0.3 all the way down to 171st with 5.5. This is, again, due to differences in the caching alogarithms between the two versions of Premiere Pro. In fact, 5.5 really made clear how weak my particular GTX 470 GPU really was - to the point that replacing it with a GTX 560 Ti 448 improved my ranking significantly.
    Apr 30, 2012 11:37 AM   in reply to grandpooba2
    That link doesn't work: It leads to a shopping cart whose contents can only be seen by the user who actually created the cart. Otherwise, all other users will see only an empty shopping cart.
    Apr 30, 2012 11:51 AM   in reply to grandpooba2
    The GA-X79-UD5 works just fine for me with the 3930K, but I avoid Crucial RAM, and have 32 GB of Corsair XMS3.
    You will have to upgrade the BIOS to at least F9, and preferably F10 before you start, or the system will be subject to random freezing
    Apr 30, 2012 11:57 AM   in reply to grandpooba2
    Don't mix the i7-3930K and any RAM that uses Micron ICs: The two have major compatibility issues right now.
    In addition, the i7-3930K and the i7-3820 require the use of 1.35V or lower voltage DIMMs. Unfortunately, most DIMMs on the market require 1.5V or 1.65V just to even run at all - which can create serious headaches with these SB-E CPUs.
    Apr 30, 2012 1:20 PM   in reply to RjL190365
    In regard to the stability of RAM - I've just been reading the "FEEDBACK" section on the NewEgg site, http://www.newegg.com/Product/Product.aspx?Item=N82E16820231500
    It appears many people's stability problems are being solved by Enabling XMP in BIOS.  (RipJaws 1866 1.5v sticks with P9X79 PRO at least)
    May 1, 2012 1:40 PM   in reply to grandpooba2
    David,
    This looks like a nice system you are building. You are ahead of me.
    Disk setup is a rather complicated matter, and especially with tapeless formats, since then backup really becomes an issue. From a performance POV raid0 is very nice, it is fast and cheap, it does not require a dedicated controller, it can be run from the mobo with minimal CPU overhead, but if one drive fails, all your data are irretrievably lost. That is thus the downside of raid0. Have a look at the 'featured discussion' about raid and rebuilding issues at the top of the page, it may be helpfull.
    Also have a look at http://forums.adobe.com/thread/662972?start=0&tstart=0 and similar articles.
    May 1, 2012 9:24 PM   in reply to grandpooba2
    David,
    Any parity RAID, such as RAID 5, requires the use of a discrete hardware RAID card for the best balance between redundancy and performance. And the X79 chipset does not natively support firmware-assisted RAID in its SATA controller - but the RAID support is now entirely in software using a driver that's like the one used with Intel's workstation chipsets. The problem with software-only RAID is that it misuses the CPU, and it's sluggish in performance.
1 2 Previous Next
Actions
