Getting ready to build a new system (i7-2600k, 16GB memory, ASUS P8Z68-V Pro motherboard, 750W PSU). Thanks to some sales, I have a little more room in the budget for a GPU. I edit primarily DSLR footage. Which of the following is recommended?
$279.99
Ever use Zotac? How much difference does "superclocked" make? Is it better to get a 560 Ti with 2GB memory over the 560 Ti with 448 cores? My original choice was the first card on the list, but it had a price hike so I'm considering other options. My ideal price is closer to the $200 mark than $300.
My concern with the 560 Ti with 448 cores is that no one really has it yet to confirm it works with the GPU hack in CS5. It's also an extremely limited run, which has me concerned about future support and potential SLI use (assuming future versions of Premiere can make use of it).
JB
Jack,
"Superclocked" means that the GPU has been slightly overclocked at the factory. But that particular eVGA card has only an Nvidia reference cooler, so the slight overclock on the GPU would make very little if any difference whatsoever in the performance. And in my experience with a GTX 470 with the reference cooler, the fan often ramped up to maximum speed, then slowed down and sped up alternately. That indicated that the GPU started throttling down in speed (to prevent overheating) during MPEG-2 DVD from HD transcoding, making it slower than it should have been.
And the GTX 560 Ti 448 does work with the hack. After all, it is essentially a GTX 580 with two of its 16 texturing units disabled. (Likewise, the GTX 570 has one of the GTX 580's 16 texturing units disabled.)
As for the 2TB card, it isn't needed with typical DSLR or AVCHD footage with only a few layers of video in the project.
Would a superclocked card with two fans be worth it? GTX 560 Ti DS:
http://www.microcenter.com/single_product_results.phtml?product_id=036 5382
Or should I still consider the 448 version instead?
Thanks for the feedback!
Which brand/model 560 448 core did you get? I'm looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130738
I'd go for the 2GB EVGA myself. The superclocked probably won't provide any noticeable improvement. The 448 core might show some very slight improvement, a second or two. But the less than 2GB models can show serious slowdown under some conditions, forcing the rendering back onto the CPU if you run out of video memory.
No. If you're only using Premiere, the Quadro 4000 is a huge waste of money right now because its specs are actually lesser than a $180 GeForce GTX 560 (only 256 CUDA cores in the Quadro 4000 versus 336 CUDA cores in the GTX 560, and both cards with only 256-bit VRAM bus width) - but the Quadro 4000 costs a whopping $800. In fact, the closest GeForce GPU to the Quadro 4000 (specs-wise) would be the 288-core GeForce GTX 460 SE (or its OEM-only successor, the GTX 560 SE).
So, even accounting for the more robust OpenGL support in the Quadros, the Quadro 4000 would be at best only a cross-grade (performance-wise) from your current GTX 460: They both perform about equal to one another.
One caveat: The GTX 680 can be ported to a new PC although (depending on your current system's CPU, RAM and motherboard) its performance benefit in Premiere may be limited by the weakest link in that existing PC. So, if you're running only a four-year-old Core 2 Quad, even the GTX 680 would be a waste of money unless you're planning to get a new PC in a few months since its performance would still be significantly slower overall than PCs with fast i7 CPUs that are equipped with GPUs that are half as powerful as the GTX 680.
Here's the problem:
That Dell XPS Studio uses an older generation, LGA 1156 "Lynnfield" i7 CPU, either an i7-860 or an i7-870. The trouble with either CPU is that they are no faster than a low-end i7-9xx series (LGA 1366) CPU in terms of performance. Worse, Dell has locked its BIOSes so that you can't even tweak the CPU or memory at all as far as speed and voltage is concerned. Your friend's system using a Quadro seems faster - but only because he likely has a dual-CPU system. Most systems using only a single Xeon are, if anything, slower than the i7-860 because they are clocked lower than the i7-860 to begin with.
