using key in coding for peer to peer applications
May 1, 2012 4:34 AM
Tags: #cirrus #to #key #game #peer #multiplayer
Can someone help me understand, how come using key in coding for peer to peer applications can be safely used. For example, if generate a key for my application, then it's very easy to decompile the swf and know the key. In that case, anyone can create a similar cheat-application ( like a game) , and can enter inside.
Vishwas
    May 1, 2012 9:05 AM   in reply to Vishwas Gagrani
    by "key" i assume you mean your Codename Cirrus developer key, which you use to connect to the Cirrus servers.
    if someone were to create a cheat version of, say, your game, they wouldn't need to use your developer key. any valid developer key allows access to any peers or groups connected to the service using any other developer key. anyone can obtain a developer key. since anyone can get one and they don't restrict the peer ID or group namespaces, there's no incentive to steal an existing one out of a SWF, so we decided not to add any other layer of authentication (like a shared secret or challenge), as that would be an unneccessary complication and just make using the service harder.
    if you do want to conceal your developer key, you could use a secure channel to transmit it to your SWF, such as HTTPS after a username/password challenge (so only authorized/trusted users would be given it). of course, an authorized user could have a hacked SWF and could get the developer key out anyway. but that starts to be a lot of trouble for no reason. you can increase the technical hurdle even farther by using RTMPS to connect to a Flash Media Server, and use SWF Verification on FMS to ensure (with a high degree of confidence) that the SWF is the one you made and not a hacked one, and transmit the Cirrus developer key over the RTMPS channel only to verified SWFs.
    May 1, 2012 10:46 AM   in reply to Vishwas Gagrani
    to use the Codename Cirrus service, you must agree to its Terms of Use.
    a developer key is only given out after agreeing to the Terms of Use. a developer key is required to access the service. therefore, the developer key ensures that you (the developer) have agreed to the Terms of Use.
    May 1, 2012 11:40 PM   in reply to Vishwas Gagrani
    if someone wanted to make it look like your developer key was using more resources than you (the real developer) really was, then yes they could do that if they obtained your developer key. however, other than causing you grief, there's no incentive to do so, since anyone can get a developer key.
    there is no way to list the peer IDs that are connected to the service. the peer IDs can't be guessed (they're cryptographically pseudorandom). so even if another application was connected with a different developer key, it would still have to interact with your infrastructure to learn the peer IDs of anyone it wanted to interact with. if you only divulge peer IDs to authorized users, then only authorized users can connect to those peers.
    there is no way to list the groups that peers using your developer key are using. group specifications can be made arbitrarily hard to guess. peers don't divulge group specifications to other group members or to the Cirrus service (the groupspecs are hashed on the wire as of Flash Player 10.2, even to the server). if you make the group specifications cryptographically infeasible to guess and only give them to authorized users, then only authorized users can join those groups.
    May 2, 2012 1:25 PM   in reply to Vishwas Gagrani
    i assume app1 and app2 are using/joining the same group, and you're reporting the number of neighbors and/or members of that group. as i mentioned, the developer keys don't form a namespace subdivision for peer IDs or group names/groupspecs. both of your apps know the groupspec.
    if you want them to be separate, pick groupspecs that are different; ideally, cryptographically pseudorandomly different. and only give the groupspecs to your users who are authorized to join the group (for example, by transmitting it over HTTPS only with correct user credentials according to your application).
