I am resizing the flash (.swf) file accroding to the browser window to fit on any screen resolution. But the problem I am facing now is related to animations which cross the STAGE area. Say, I have an aeroplane_mc which starts animating from x:-200 to x:1200 (my stage width=1000 & height=600), the my flash (swf) file gets shrink.
Because of this problem I cannot make any animation which moves out of stage. Please help me in resolving this problem.
The code to resize the window is as below:
var myStage:Stage=this.stage;
myStage.scaleMode=StageScaleMode.NO_SCALE;
myStage.align=StageAlign.TOP_LEFT;
function initialDisplay(event:Event):void{
var swfWidth:int=myStage.stageWidth;
var swfHeight:int=myStage.stageHeight;
Background.width=swfWidth;
Background.height=swfHeight;
TitlePage.width=swfWidth;
TitlePage.height=swfHeight;
addEventListener(Event.ENTER_FRAME,initialDisplay);
Thanks in advance for any help.
this is probably due to
do you need to use NO_SCALE try SHOW_ALL instead
Thanks for the reply. I will check as you advised the following code:
myStage.scaleMode=StageScaleMode.SHOW_ALL;
Note: I tried it, but still the same problem. The SWF shrinks.
