This discussion is locked
cherishrose12344321
Can anyone help me?
May 2, 2012 7:05 AM
Tags: #cs4 #cs5 #cs3 #help #error #image #adobe #flash #div #html #template #dreamweaver #crash #javascript #images #links #css #menu #code #html5 #dw
MODERATOR NOTE: When you ask a question, give some details about your issue, or else no one can help you. When people that are trying to help you ask you some questions, answer them.
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8">
<title>Untitled Document</title>
</head>
<body><form name="frmFormMail" action='' method='post' enctype='multipart/form-data' onsubmit='return fmgHandler.onsubmit(this);'>
<input type='hidden' name='formmail_submit' value='Y'>
<div id='err_required' class="form_error" style='display:none;'>
    <label class='form_error_title'>Please check the required fields</label>
</div>
<ol class='phpfmg_form' >
<li class='field_block' id='field_0_div'><div class='col_label'>
<label class='form_field'>Title</label> <label class='form_required' >*</label> </div>
<div class='col_field'>
<select name='field_0' id='field_0' class='text_select'    >
<option value="Mr." >Mr.</option>
<option value="Mrs." >Mrs.</option>
<option value="Ms." >Ms.</option>
<option value="Miss" >Miss</option>
</select>
<div id='field_0_tip' class='instruction'></div>
</div>
</li>
<li class='field_block' id='field_1_div'><div class='col_label'>
<label class='form_field'>Name</label> <label class='form_required' >*</label> </div>
<input type="text" name="field_1"  id="field_1" value="" class='text_box'>
<div id='field_1_tip' class='instruction'></div>
</div>
</li>
<li class='field_block' id='field_2_div'><div class='col_label'>
<label class='form_field'>Email Address</label> <label class='form_required' > </label> </div>
<input type="text" name="field_2"  id="field_2" value="" class='text_box'>
<div id='field_2_tip' class='instruction'></div>
</div>
</li>
<li class='field_block' id='field_3_div'><div class='col_label'>
<label class='form_field'>Your message</label> <label class='form_required' >*</label> </div>
<textarea name="field_3" id="field_3" rows=4 cols=25 class='text_area'></textarea>
<div id='field_3_tip' class='instruction'></div>
</div>
</li>
<li class='field_block' id='phpfmg_captcha_div'>
  <input type='submit' value='Submit' class='form_button'>
        <span id='phpfmg_processing' style='display:none;'>
            <img id='phpfmg_processing_gif' src='admin.php?mod=image&amp;func=processing' border=0 alt='Processing...'>
            <label id='phpfmg_processing_dots '></label>
        </span>    </li>
</ol>
</form>
</body>
</html>
    May 2, 2012 3:26 AM   in reply to cherishrose12344321
    This is ridiculous, what is your question????
    If your question is related to what you asked here http://forums.adobe.com/message/4373724#4373724 then why did you not answer Sudarshan Thiagarajan when he came with a possible solution?
    Why did you not stay with your original post instead of creating a new post for the same question?
    GRUMPS!!!!
    May 2, 2012 5:28 AM   in reply to cherishrose12344321
    cherishrose12344321 wrote:
    Dont worry, i dont think i want your help thanks.
    Have some manners.
    Can you help me?
    See what I just did there?  You just brought your car into the garage and dropped it off saying "Can you help me?".  Mechanic says "Sure, what's wrong", before they can look up to get your response you leave.  Guess what happens to your car.  Well it sits at the mechanic all day and you return later to pick it up and ask "Is it fixed".  The mechanic's response is "Is what fixed?".
    Point being if you have a question ask it.
