A.kameshwaran
Bitmap Data
Apr 29, 2012 11:48 PM
     I would like to know how to copy a portion of an image in an irregular shape using bitmap data or any other function. Kindly let me know if you need further explanation in this.
Kameshwaran A.
    Apr 30, 2012 12:10 AM   in reply to A.kameshwaran
    You will get portion of an image using BitmapData class method copyPixels(), refer the syntax:
    copyPixels
    (sourceBitmapData:BitmapData, sourceRect:Rectangle, destPoint:Point, alphaBitmapData:BitmapData = null, alphaPoint:Point = null, mergeAlpha:Boolean = false)
    So in that case you have to define the portation that you expect from the image bitmapdata.
    Apr 30, 2012 12:35 AM   in reply to A.kameshwaran
    For irregular shape there are two possible way:
    1. Using mask
    2. Uing complex mathematical formulas to fill each pixel in a bitmap data.
    Apr 30, 2012 2:36 AM   in reply to A.kameshwaran
  • kglad
    Jul 21, 2002
    Apr 30, 2012 1:04 PM   in reply to A.kameshwaran
    if you can convert your irregular shape to a movieclip, you use use the beginBitmapFill() method.
  • kglad
    Jul 21, 2002
    May 1, 2012 10:51 PM   in reply to A.kameshwaran
    import flash.geom.Point;
    import flash.display.BitmapData
    var bmp:BitmapData = BitmapData.loadBitmap("bmpID");
    var img:MovieClip = createEmptyMovieClip("img",0);
    img.attachBitmap(bmp,0);
    var mc:MovieClip = this.createEmptyMovieClip("mc",1);
    var ptA:Array = [];
    img.onMouseDown = function(){
        this.onMouseUp = function(){
            //delete this.onMouseDown
            delete this.onEnterFrame;
        var pt:Point = new Point(_xmouse,_ymouse);
        ptA.push(pt);
        this.moveTo(pt.x,pt.y);
        this.onEnterFrame = function(){
            ptA.push(pt)
            with(this){
                lineStyle(1,0x000000);
                lineTo(pt.x,pt.y);
        mc.beginBitmapFill(bmp);
        mc.moveTo(ptA[0].x,ptA[0].y);
        for(var i:Number=1;i<ptA.length;i++){
            mc.lineTo(ptA[i].x,ptA[i].y);
        mc.endFill();
        ptA.length = 0;
  • kglad
    Jul 21, 2002
    May 2, 2012 6:36 AM   in reply to A.kameshwaran
    that should be a bitmap with linkage id = "bmpID"
  • kglad
    Jul 21, 2002
    May 3, 2012 5:43 AM   in reply to A.kameshwaran
    if you don't want the bitmap on-stage, use:
    //img.attachBitmap(bmp,0);
    var ptA:Array = [];
        ptA.push(pt);
            ptA.push(pt)
            with(this){
                lineTo(pt.x,pt.y);
        mc.endFill();
        ptA.length = 0;
    // here's the a file with that code:  http://www.kglad.com/Files/forums/bmpFill.fla
  • kglad
    Jul 21, 2002
    May 3, 2012 6:01 AM   in reply to A.kameshwaran
    you're welcome.
