djkhalif
Queries not working in CF......
May 2, 2012 7:56 AM
Tags: #cfquery #coldfusion9 #cfc
Good morning all,
I have this query that I can run in SQL Server Management Studio but it will not run in ColdFusion. Do I need to put in a stored procedure to run the below code?
<cffunction name="itmChk" returntype="query">
    <cfargument name="searchPO" required="yes">
    <cfquery name="itemCheck" datasource="#REQUEST.datasource#">
    select ordno, itnbr, house, poisq, blcod, b_blksq, cmpdt, itdsc, engno, itcls, duedt, umord, qtyor, stkqt, staic, vndnr, vname, b_relqt, b_reldt, b_stkqt, b_staic, pitd1, pitd2, duedate
        from recvTemp t
        where t.ordno = '#arguments.searchPO#'  and not exists(select *
                                         from recvLogTest r
                                         where t.ordno = r.ordno and t.itnbr = r.itnbr)
    </cfquery>
    <cfreturn itemCheck>
    </cffunction>
Thanks for any help!!!
DJkhalif
    May 2, 2012 8:24 AM   in reply to djkhalif
    What do you mean "will not run"?
    Recommend you read this:
    http://forums.adobe.com/thread/607238
    Adam
    May 2, 2012 9:50 AM   in reply to djkhalif
    I would check to see what value is being passed to the query and even email yourself a dump of the query after it runs (which will include the actual query it is running). Then copy and paste that into SSMS and see if it returns records.
    May 4, 2012 6:28 AM   in reply to djkhalif
    You might also use SQL Profiler to view the query that is being excuted.
    "SQL Server Profiler Step by Step"
    http://www.codeproject.com/Articles/21371/SQL-Server-Profiler-Step-by- Step
    "Getting ColdFusion SQL Statements from SQL Server Trace"
    http://www.petefreitag.com/item/674.cfm
