bertholomeu_8
how do you render specific parts of timeline without rendering the whole sequence? cs5
May 2, 2012 8:55 AM
New to CS5 Premiere pro, im trying to render certain sections of my timeline without rendering the whole timeline, in Avid you would just mark in and mark out the area you wanted to render, is there something similar to that or do you always have to render the whole timeline?
    May 2, 2012 9:09 AM   in reply to bertholomeu_8
    In CS6 you can do it the way you are used to.
    In CS5 at the top of the timeline are Work Area markers that allow you to define a range to be affected by a process. You slide them to mark that area.
    May 2, 2012 9:21 AM   in reply to bertholomeu_8
    Place Work Area Bar over the part of the timeline you want to render and then hit Sequence/Render Whole Work Area.
    If you mean Export also place work area bar over section and make sure in the export settings, Source Range (bottom left) is set to Work Area.
