Branislav Milic 164 posts
Jan 12, 2010
New Viewer Builder (2.0.0) available and mandatory
May 2, 2012 10:15 AM
  • Bob Bringhurst
    May 29, 2007
    May 2, 2012 10:40 AM   in reply to Branislav Milic
    You beat me to it. The new Viewer Builder includes iPhone support. The rest of the tools should be updated in about ten hours from now. I'll post an announcement with links to new features, etc.
    May 2, 2012 1:44 PM   in reply to Bob Bringhurst
    Will this require an update to the Adobe Content Viewer? If so when will this be submitted to Apple if it hasn't already and when do you expect the update to go live?
    May 2, 2012 1:48 PM   in reply to Fuel Advertising 4
    No!
    Just don’t update the tools.
    Bob
    May 2, 2012 2:28 PM   in reply to Bob Bringhurst
    iPhone support! Great news! Thanks, Adobe!
  • Bob Bringhurst
    May 29, 2007
    May 2, 2012 2:31 PM   in reply to Romanov.a0137
    The Adobe Content Viewer has been submitted and it's in review. How long the review will take is anyone's guess.
    May 2, 2012 2:57 PM   in reply to Branislav Milic
    iPhone support is of course great, but makes me sad that support is just for multi-issue, not single-issue .
    May 2, 2012 3:31 PM   in reply to Martin Lér
    No Single Editions on the iPhone? Is this an error in the viewer builder or intended? Can you give us an explanation that we can give our clients? :-/
    —Johannes
    May 2, 2012 3:45 PM   in reply to Johannes Eckert
    To track the status of the submission of the content viewer to the various marketplaces, please see my new post: http://forums.adobe.com/thread/998106?tstart=0.
    Neil
  • Bob Bringhurst
    May 29, 2007
    May 2, 2012 3:47 PM   in reply to Neil Enns - Adobe
    Single Edition for the iPhone didn't make it into this release, but the DPS team is working on it.
    May 2, 2012 3:52 PM   in reply to Bob Bringhurst
    Please make sure you are installing viewer builder 2.0.0. In order to do this for many browsers you need to flush your cache before hitting the link in VB that fetches the new version for download. Quite often the browser will cache the older version. If you see that you are downloading version 1.9.0 instead of 2.0.0, flush your default browser cache and hit the link again.
    May 2, 2012 5:03 PM   in reply to John J Metzger
    I generated the Adobe Content Viewer for the iPhone, but I could not install it on my iPod touch (wich I have for simulating iPhone behaviour).
    Why is the Viewer Builder only asking for Horizontal Splash Screens for a new iPhone app?
    —Johannes
    May 2, 2012 5:12 PM   in reply to Johannes Eckert
    same behaviour on an iPhone 3GS. Ad-Hoc app from the server loads, installs and then disappears from the home screen.
    When syncing via iTunes, i get the error message "App XYZ cannot be installed".
    —Johannes
    May 2, 2012 6:04 PM   in reply to Branislav Milic
    I have installed ACV on my phone and it works.
    May 2, 2012 10:40 PM   in reply to tony kamberi ug
    Ha ha false Alarm.
    In the quick rush deep in the night I forgot to add the iPhone/iPad to the
    moboleprovision.
    Otherwise... one of the apps tested was an enterprise signed app. Hm.
    Still testing today.
    (mobil gesendet)
    Am 03.05.2012 03:04 schrieb "tony kamberi ug" <forums@adobe.com>:
       Re: New Viewer Builder (2.0.0) available and mandatory  created by tony
    kamberi ug <http://forums.adobe.com/people/tonykamberiug> in *Digital
    Publishing Suite* - View the full discussion<http://forums.adobe.com/message/4375707#4375707
    May 3, 2012 4:31 AM   in reply to Branislav Milic
    This seems to add another variable into the DPS equation. I thought the Builder was strictly the panel inside InDesign, and the Viewer the program used to test apps before you submit them. Now it seems there is a Builder-Viewer app that is stand-alone / not inside InDesign. Where does this fit in?
    Adobe needs to rethink this entire "ecosystem" and simplify it. No more panels that show no content / require updates at random times. Build in the functionality, have it available in ONE place, have it always visible and usable, and make the point where you compile and submit something the point at which logins and subscription payments are required. This whole setup of downloading plugins and updating panels is not user-friendly or typical of the way Adobe does things in other apps.
    May 3, 2012 4:53 AM   in reply to VanGrenade
    It is getting better but you'll need to be patient.
    With CS6 these tools will be updated the same way other patches are done, through the help>updates feature.
    Bob
    May 3, 2012 4:58 AM   in reply to Bob Levine
    Bob: where does the Builder-Viewer app fit into the design process equation? What does it do that the builder panel and viewer app that I read about in past versions, don't do?
    May 3, 2012 5:04 AM   in reply to VanGrenade
    Viewer builder is the app used to actually create the app which will be submitted to Apple. You add icons, splash screens, certificates and, in the case of single edition, the published folio.
    You can see it now by visiting digitalpublishing.acrobat.com and signing in. Note this is Mac only.
    Bob
    May 3, 2012 5:16 AM   in reply to Bob Levine
    Thank you. Sounds like it's the equivalent of iTunes Producer for DPS. Luckily I am a Mac user so I'll be able to take advantage of it if I can figure out how to get the whole system up and running first.
    May 3, 2012 5:24 AM   in reply to Branislav Milic
    Just created a custom viewer app, worked without any problems. The pdf zoom behavior is working fine, I used layouts from another folio. Allthough the iPhone has another aspect ratio, 3:2 instead of 4:3, so all layouts need to be adapted, if you want to use the same.
    One question pops up, since I don't have a iPhone 3 here to test at the moment, do we need to do the same with renditions for iPhone 3/3GS (480x320) and iPhone 4/4S (960x640)?
    May 3, 2012 5:56 AM   in reply to Branislav Milic
    Idea - we would like to see switch in Viewer Builder, which will limit supported iPhone/iPod touch devices just to those with Retina display. So that our viewer can install just users with iPhone 4/4S and iPod touch (4th generation).I belive that this i just some XML setting, so it should be not big deal..
    May 3, 2012 5:57 AM   in reply to Nortau
    Yes, you need to use renditions, and just one note, viewer is NOT supported on iPhone 3G, just 3GS (according to documentation)
