Batch Video Transition, Timing and Effects
May 1, 2012 8:20 AM
Is there a way to batch transitions, timing and effects on multiple video clips or still images?
It seems as if you should be able to select several clips then, when highlighted, changing a transition, effect or timing should apply to all other selected clips.
This seems like an essential aspect of video editing... especially slideshows.
Am I missing something?
    May 1, 2012 12:21 PM   in reply to BobDiN
    As it is right now, there aren't batch operations in the timeline panel
    May 1, 2012 3:36 PM   in reply to BobDiN
    For the still images, you could use actions and file automate to batch process them if you want them all to have the same effects placed on them.
    Pattie
    May 2, 2012 11:26 AM   in reply to BobDiN
    Hi Bob, I'll check into the layer selection and action stuff above and let you know what I find.
    Actions are supposed to be able to call other actions also in CS6.
    Pattie
    May 2, 2012 11:28 AM   in reply to BobDiN
    Hey Bob,
    1. It doesn't look like transitions such as cross-fade can be added to an audio track. They can be added to video tracks, so if your audio is attached to a video it can be cross-faded that way. You can adjust the fade in or fade out, or volume of the audio track by right clicking on it in the timeline panel to get the audio dialog.
    2. Yes, you can fade in and out, and adjust volume of a video track's audio by right clicking on it in the timeline, and clicking on the audio button along the top to get the audio options.
    Instead of rightclicking in both of these instances, you can click the little arrow at the end of each clip to get these same menus.
    May 2, 2012 12:29 PM   in reply to BobDiN
    Yep!
    That would be a just fine workaround.
    I had hoped to give you the tools to be able to discover a viable set of steps for what you need.
    Good on ya.
    Cheers.
    Pete
    May 2, 2012 5:02 PM   in reply to BobDiN
    Bob,
    I tried your actions and they appear to work the same in both versions. I made a simple file with 8 layers (bottom one background or layer 0)  I ran the actions step by step.  The gotcha is when you run this particular action, you are at the bottom asking to select one more below where there is nothing, so it selects the top one.
    Pattie
    1.      Select “Top” Layer                               (layer 7 in my  case)
    2.     Select “Bottom” Layer                          (layer 0)
    3.     Select the next layer Above current      (layer 1)
    4.      Select the next layer Below current      (layer 0)
    5.      Adds the layer Above to the current layer    (layer 0 is selected. it adds 1 to selection)
    6.      Adds the layer Below to the current layer    (since layer 0 is the bottom, it will wrap and select the top layer)
    If you skip step 4 then it will select layers 1,2, and zero as you might expect.
