i need to find a way to slice an image (jpeg) into 9 or 16 or more equal parts and then convert to PDF so it can be printerd and that its ends up looking like a large poster..
that can be repasted together...also would be nice if each image spliced would have guides on all 4 corners so that the repasting would line up perfectly.
Am i asking to much....
RCFMitch
here is an example of what the final product should look like..
See attachment...
you create your document to size it will be when pasted together. Then you go to View>Show Tiling so you cane see the tiling
then you go to the print dialog and a select a paper size one that divides the document evenly vertically and horizontally it should be smaller than the actually paper you will be printing it on, oh yes make certain you have adobe pdf selected as the printer.
Then you will see the tiling in the print you may have to make a custom page size in the page set up with no borders to get the tiling to work.
then turn on trim marks in the print dialog. then print to pdf and you will have end up with a multipage pdf. It does sometimes require a little adjustment as everything has to be consider the page size must divide the page evenly and no borders are probably also require to prevent the tile from displacing.
Your artboard should be the size of your finished poster - what-ever you want - and artwork created at 100%.
Go to print and select the paper size that you want to print on - say A4 - and select "tile full pages". You can then specify an overlap if you want it.
Alternatively select "tile imagable areas". That way you get no overlap and simply trim to the edge of the art (which will be your printer's imagable area for the selected paper size.
Page tilling works, also there is a free software to do that. give it a try and tell me...![]()
http://posterazor.sourceforge.net/index.php?page=screenshots&lang=engl ish
This thread is old but I'm adding this in case someone's search points them here.
It's odd that Illustrator doesn't provide cut marks when tiling, but here are the 2 viable workarounds I'm aware of:
