Hi All,
This is my first post in this forum.
Recently I found this shared PDF rendering bug
by both Adobe products: Illustrator CS5 and
Adobe Reader X.
Look at the attached images.
Although these screenshots are from
Adobe Reader X and Nitro PDF Reader,
these shows exactly the rendering differences
between Illustrator Cs5 and Cs4.
The same PDF file opened fine in Illustrator CS4
and 8 different PDF viewers. It does not shows
these square clipping boxes around the words
"La Tormenta".
Why Adobe changed the way its products interpret
pdf files?
If you want, you could download the pdf file:
http://dl.dropbox.com/u/3834621/La_Tormenta_for_PDF_export.pdf
(77k)
Thanks in advance!
Alejandro
I don't have Illustrator CS4 around me to test it but in CS5 I just selected all Ctrl+A and removed all clipping masks with Ctrl+Alt+7. These clipping masks don't do anything anyway but just clip the edges if the letters. Then I saved as .ai and also as PDF with and without Preserve Illustrator Editing and then opened again all files without any problems. Hopefully someone here has access to CS4 and will open your pdf to see if these clipping masks problem is there.
Hi emil,
> problem is there.
The clipping mask problem only appears in Illustrator
Cs5 and Adobe Reader X.
Just for curiosity. How do you know exactly which
clipping masks to delete?
Deleting all clipping mask in a design would
be a real problem in most cases.
Alejandro
I don't want to point fingers as I have no idea where the culprit is but often these kind of problems are caused by software that doesn't follow strictly a standard like the PDF file format standard in this case, So, it is possible that the problem could be caused by the program that created the PDF file. It is not unusual programmers to save time by simply testing their code making sure it works instead of following strictly the file format standard. In such cases everything works fine until a new version of the software is created.
Didn't see Scott's reply before I wrote my previous post, so after his report I'm inclined to believe that the problem comes from CS5 but so far limited with files created with the software that made the PDF.
Alejandro
I just tried that first and it didn't seem to cause any problems.
emil emil wrote:
I wonder what will happen if the PDF file is re-saved from CS4 or 6 as PDF and then tested again in CS5. Or even better save as .AI and then as PDF
Opened in CS6, Save as PDF (Illustrator Defaults), open in CS5 = no masks.
So you're correct. CS5 is reading some aspect fo the PDF which the other AI version are not. And upon a resave that erronious data seems to be corrected.
Note: Open PDF in Acrobat Pro X (10.1.3) save as PDF, open in CS5 = Masks still present. So Resaving via Acrobat Pro X is of no help.
Hi emil,
That would be really interesting.
If no mask appears in Cs5, after resaving
in Cs4 or Cs6, then the PDF parsing code
in Adobe Reader X and Illustrator Cs5
is looking some specific tags inside the
PDF and when it does not find them,
it changes the way to renders the pdf...
Just my educated guess...
Alejandro
Sure:
http://www11.zippyshare.com/v/69123857/file.html
Resaved via CS6 as Illustrator Defaults. Seems the primary difference is the new PDF has a clipping mask around the entire artboard. That can easily be deleted though.
http://www65.zippyshare.com/v/32189367/file.html
Resaved from CS4 as Illustrator Defaults... no masks anywhere.
If you look at the PDF info you can see that AICS6 and AICS4 (and CS5) use PDF 1.5 as the default format. The Xara export is using PDF 1.6. So it may be a bug in the PDF 1.6 format. Or a bug in how Xara is writing PDF1.6 as emil emil eluded to. Things may be entirely different if Xara is set to use PDF1.5 for the export.
Hi Scott,
Just exported the file in different PDF versions
1.3 / 1.4 / 1.5 / 1.6
Tell us which version(s) does not invoke
clipping masks in your different Illustrator's
versions:
http://dl.dropbox.com/u/3834621/La_Tormenta_for_PDF_export_v13.pdf
http://dl.dropbox.com/u/3834621/La_Tormenta_for_PDF_export_v14.pdf
http://dl.dropbox.com/u/3834621/La_Tormenta_for_PDF_export_v15.pdf
http://dl.dropbox.com/u/3834621/La_Tormenta_for_PDF_export_v16.pdf
Thanks in advance!
Alejandro
CS6 - Every file has clipping masks. Not the same masks originally, but there are masks.
CS5 - Every single file has clipping masks. Not the same original masks and not the same masks which show in CS6, but there are masks.
CS4 - no masks anywhere in any of the files.
The original PDF in the opening post of this thread was cleaner in CS6 than any of the recent PDFs.
Hi Scott,
Exporting PDF from Xara has too many options,
so probably I selected/deselected one or many
features that produced these results.
For now, I will alert Xara about this
possible bug and warn my printers to use
Cs4 or a previous version of Illustrator for
view and print my files.
Many thanks again, Scott and emil emil
for your time and interest to solve this
issue.
Alejandro
GLad to help.
I'm guessing that the issue may be the gradient changes in CS5 and CS6. CS5 allows transparency on Gradient Meshes. CS6 allows gradients on strokes (with transparency as well).
It's customary to see clipping masks when AI art is back-saved to older versions or saved to older PDF formats. The gradients get rasterized and a clipping mask is created from the shape. It would appear that the Xara export is being read the same way.
Sometimes ticking the "Compatible Gradients" option when backsaving AI files will resolve the issue. If there's some preference in the Xara export regarding gradients or meshes, you may look at those settings closer (sorry I don't really know Xara at all since it's PC-only).
