New to DPS. First impressions are very good.
However, when adding an Indesign page to Folio Builder as an article with the format set to PDF(to enble pinch and expand on iPad), the tiff images that are included in the Indesign page are displayed in very poor quality??
When I change the format to PNG or JPEG, in the article, the same images are displayed on the iPad with excellent quality - however, I dont have the pinch and expand functionality, which is what I require!!
I would really appreciate any solutions or suggestions on how this issue can be resolved.
Indesign CS5.5, MAC OSX 10.7, iMac
Iain....
Which iPad are you viewing your test articles on? Remember that the resolution for iPad 1 & 2 is 1024px x 768 px, while the iPad 3 resolution is 2048px x 1536px. Your images need to be formatted accordingly. Also check your image scale parameters. Anything above 100% scale of the original image will reduce the image quality. You can check this in InDesign before you ever test your article on the device. Simply press Command+1 to view actual pixel size and set your Display Performance to High Quality and you should be seeing something very close to what the final result will be. Also check that your images are RGB as well. Hope this helps.
