sql inserting new record error
May 2, 2012 12:01 PM
I am trying to simply insert a new record using sql.  here is my code:
$sql="INSERT INTO question(topic, message, datetime)
                    VALUES('$topic', '$message', '$datetime'";
                    $result=mysql_query($sql);
                    if($result){
                              $success = 1;
                    else {
                              $error = "There was an error posting your question.  Please try again, or contact us.";
When I try posting a new question, I get the error message.  It worked for me before.  I believe it has to do with the way that my SQL table is set up.  I have an ID field in the table, that is auto-incremented, as well as a primary key.  so not sure why it wouldn't be able to insert a new record there.  don't see anything that could really cause any conflict.  any thing else it could possibly be?
EDIT:
just noticed it had a cardinality of 3... how do i change this?
    May 2, 2012 2:16 PM   in reply to future-architect
    What has a cardinality of 3? The PK? How many rows are in the table? Do you have any other constraints on the table?
    May 2, 2012 4:21 PM   in reply to future-architect
    Dunno, possibly a problem related to a datatype mismatch. Use mysql_error() to get the details.  The cardinality is correct if you have 3 rows in that unique column.
    May 2, 2012 4:44 PM   in reply to future-architect
    Ah, I see that now. Did you use mysql_error() to find that error?
    May 2, 2012 5:58 PM   in reply to future-architect
    Looks like it used to, but no more. From the manual:
    "Errors coming back from the MySQL database backend no longer issue warnings. Instead, use mysql_error() to retrieve the error text."
