Hello to all, Does any body could help me with a dropdownmenu?
Participant ,
May 02, 2012 May 02, 2012
I have a nav bar with several buttons with dropdownmenu each one this is my code:
var navBtnGlow:GlowFilter = new GlowFilter(0x999999, 0.5, 0, 15, 1, 2, true, false);
navBar_mc.addEventListener(MouseEvent.MOUSE_OVER, navOverF);
navBar_mc.addEventListener(MouseEvent.MOUSE_OUT, navOutF);
function navOverF(event:MouseEvent):void
          event.target.filters = [navBtnGlow];
          navBar_mc.setChildIndex(event.target as MovieClip, 1);
          dropMenu_mc.gotoAndStop(navBar_mc.getChildAt(1).name);
function navOutF(event:MouseEvent):void
          event.target.filters = [];
// this is the default swf load
var Xpos:Number = 0;
var Ypos:Number = 0;
var swfWidth:Number = 450;
var swfHeight:Number = 184;
var swf:MovieClip;
var loaderSWF:Loader = new Loader();
precargador_mc.visible = false;
var defaultSWF:URLRequest = new URLRequest("swfs/inicio.swf");
loaderSWF.load(defaultSWF);
loaderSWF.x = Xpos;
loaderSWF.y = Ypos;
loaderSWF.width = swfWidth;
loaderSWF.height = swfHeight;
addChild(loaderSWF);
I want that any button load a swf, I tried with this code, buy it does not works,
// Btns Universal function
function btnClick(event:MouseEvent):void {
          removeChild(loaderSWF);
          var newSWFRequest:URLRequest = new URLRequest("swfs/" + event.target.name + ".swf");
          loaderSWF.load(newSWFRequest);
          loaderSWF.x = Xpos;
     loaderSWF.y = Ypos;
// Btn listeners
navBar_mc.inicio_mc.addEventListener(MouseEvent.CLICK, btnClick);
navBar_mc.quienes_mc.addEventListener(MouseEvent.CLICK, btnClick);
navBar_mc.presentacion_mc.addEventListener(MouseEvent.CLICK, btnClick);
navBar_mc.rests.addEventListener(MouseEvent.CLICK, btnClick);
navBar_mc.cafes.addEventListener(MouseEvent.CLICK, btnClick);
navBar_mc.servicios_mc.addEventListener(MouseEvent.CLICK, btnClick);
navBar_mc.contacto_mc.addEventListener(MouseEvent.CLICK, btnClick);
I hope it explain you my purpose, but now I was confuse cause exactly i don't remember if the names of the buttons has to the same names of the externs swfs.
and if the "inicio_mc" for axample is a movie clip and I have to create a button like "cafes" ?
thanks a lot for any help,
Joselyn.
ActionScript
860
May 03, 2012 May 03, 2012
You don't have to remember, your code tells you what your buttons' names need to be.
The way you have the swf's being targeted requires that the buttons' names match the names of the swf files.  So if you are using "inicio_mc" as the button's instance name, then your swf file name would need to be inicio_mc.swf.  Likewise, if you swf file is named "inicio.swf, your button should be named "inicio"..
Participant ,
May 06, 2012 May 06, 2012
Hi Ned, Thanks very much for your great help, I developed this dropdownmenu from an example which it works perfect but when I want that it load some file swf, it doesn't works. This dropdownmenu is composed for a movie clip called navBar_mc and inside are the"buttons" movie clips and each one has one dropdownmenu displaying simbols of buttons, some of the "buttons" like "inicio" is considered just one button however I would like to know if this movie clip can receive buttons events to call an swf file, this is my confusion.
mark out this error
TypeError: Error # 1010: A term is undefined and has no properties.
at menuDropDown_fla :: MainTimeline/frame1 ()
Error # 2044: uncontrolled ioError: text = Error # 2035: Can not find the URL. URL:
I have changed the names of the externs swfs still to match with each "button" the problem is when I down some button of the navBar_mc menu it does not load the swf extern.
Well I appreciated as always any suggestion or advice.
Lot Regards.
Joselyn
May 07, 2012 May 07, 2012
Use the trace function to find out which term is undefined.  Use the trace function to see what the url is that is not being found.
Participant ,
May 14, 2012 May 14, 2012
Hello Ned:
in others ocasions your helped was very helpful, but now, I was tried to learn of trace function, so anyway, I appreciated your help.
Joselyn
