Cannot re-position image via x and y properties after dragging it with startDrag / stopDrag
May 1, 2012 3:55 PM
Tags: #as3.0 #actionscript3 #drag
Hello,
I am using AS 3 for mobile development but I believe this is related to AS in general do I'll humbly post my question here.
Here is my enviroment
Mac OS X Lion
FB 4.6
AIR 3.2
I have this problem:
In order to move an image on the screen, I use startDrag's and stopDrag's equivalents for mobile, meaning startTouchDrag and stopTouchDrag,
This works fine and smoothly, except that after the dragging stops I cannot further move the image on the screen by changing its x and y coordinates.
x and y, after the startDrag, seem to have values that are completely independent of where the image actually is on the screen. If I change them, the image's position does not change.
this is the MXML code to define the image
<s:Group id="totalGroup" width="100%" height="100%" doubleClick="resizePic(event)" >
    <s:Image id="myImage" smoothingQuality="high"  x="100" y="200" />
    <s:Button id="myButton" label="Re-position" click="myButton_Click(event)" />
</s:Group>
This is the AS3 code: at init, I link touch events (begin, end) to two functions that start and stop drag
    myImage.addEventListener(TouchEvent.TOUCH_BEGIN, onTouchBegin);
  myImage.addEventListener(TouchEvent.TOUCH_END, onTouchEnd);
  myImage.addEventListener(TouchEvent.TOUCH_MOVE, onTouchMove);
  function onTouchBegin(e:TouchEvent) {
  e.target.startTouchDrag(e.touchPointID);
  trace ("touch BEGIN X: "+myImage.x + " Y: "+myImage.y);
  function onTouchEnd(e:TouchEvent) {
  e.target.stopTouchDrag(e.touchPointID);
  trace ("touch END X: "+myImage.x + " Y: "+myImage.y);
the image moves OK, but the X and Y coordinates are not the coordinates on the screen: they're fixed and do not mirror where the image actually IS on the screen.
Then I have a button that does this:
function myButton_Click(event:MouseEvent) {
myImage.x=100;
myImage.y=200;
trace ("Correctly in here but myImage stays there");
Except that this does not do anything (albeit no exception is given) and the image stays exactly where it was when I last dragged it!
Can Anyone help?
thanks!
Riccardo
    May 1, 2012 4:50 PM   in reply to Riccardo Moschetti
    Try using e.currentTarget instead of e.target.  You might just be moving the innards of myImage and not myImage itself.
