The file is damaged and could not be repaired.
Jul 7, 2008 9:18 AM
Intermittently when we open a pdf in the browser in one of our main Enterprise applications, we get the error "The file is damaged and could not be repaired."
Downloading and opening always works (however for our system this is a less than acceptable workaround).
The only common denominator we can find is that this is only happening in IE6 (no matter what version of adobe reader). IE7 always opens the pdfs fine, regardless of the reader version.
I've seen this mentioned all of the place, and it often mentions that it's some sort of problem with the pdf and that reader 8 handles it better.
Any solutions yet?
    Jul 7, 2008 9:01 PM   in reply to (Robert_Lee_Anderson)
    It sounds like MISE is not completely downloading the file, but IE7 is.
    Mike
    Jul 28, 2008 11:00 PM   in reply to (Robert_Lee_Anderson)
    Anyone got a work around for this? I have the same problem here. But upgrading to IE7 sorts out this problem.
    Regards
    Jul 29, 2008 10:40 PM   in reply to (Robert_Lee_Anderson)
    Hi Robert,
    Can you please tell me what sort of update you have done on Apache? Is it a version update or any other change. Please let me know the version that you are on now.
    Aug 7, 2008 10:52 AM   in reply to (Robert_Lee_Anderson)
    Sorry, it's not IE6 alone. We have IE7 here and we get intermittent errors as well. The version of Reader or Acrobat also does not fix it.
    Aug 7, 2008 11:12 AM   in reply to (Robert_Lee_Anderson)
    What solved it for me at the USGS just now was to do the following:
    1)IE browser, Tools>Internet Options>Advanced>Security>Empty temp internet files at close=YES
    2)IE browser, Tools>Internet Options>General>BrowsingHistory-Settings>Set disk cache to max allowed.
    I figured that I may be hitting the max cache with these big pdf files, and there's no message to close my browser OR clear cache when it's maxxed out. It makes the file seem at fault.
    This is also why downloading works, because you're outside of the browser cache overflow situation.
    May 2, 2012 11:58 PM   in reply to (Robert_Lee_Anderson)
    You want something, go get something.
    I'm telling you the best solution ever according to me as I'm using it.
    Check it. It will be helpful...............
    http://www.sysinfotools.com/recovery/pdf-recovery.html
    Cheers.................
    May 3, 2012 1:32 AM   in reply to AKFilippo
    There is really no need to resurrect four year old topics!
    May 3, 2012 2:23 PM   in reply to Pat Willener
    Unless one wants to sell something? I'm not saying that such is the case, but it is a possibility.
    May 3, 2012 4:08 PM   in reply to Claudio González
    My SEO spidey sense is tingling.
    Evidently this posters excitement started here http://forums.adobe.com/message/4376037#4376037 but amazingly enough, the poster they got the link from seems to be well versed in marketspeak. Then this persons next three posts are all old threads brought back from the dead.
    Thinking they're just trying to inject links. Unfotunately for them links from this forum (and most others) are nofollowed so they don't help their website rank whatsoever.
    Jul 5, 2012 11:16 AM   in reply to (Melanie_McCalmont)
    Hi.
    Actually this is not a reply to Melanie but a tentative to start again from where some users faced troubles with damaged files.
    My case is: either opening or downloading-saving-and-opening a certain pdf file from internet (IE8) on my PC I got the attached 05-07-2012-20.03.49.jpgmsg "this file is damaged and cannot be repaired".
    I tried and retried.
    However, I had no issue when opening it and downloading it on my ipad.
    So I then copied it from my ipad to my PC but could not open it: same message.
    I checked my Adbe Reader version: 7.0.9. No update available.
    I tried to open other pdf files (on my PC) and it works, no issue to open them.
    But THAT ONE, no, no way to read it.
    Now because I can read it on ipad why making a fuss you will tell me?
    Because I need to print it and can only do it from my PC.
    Any idea?
    BR
