You can tell CS6 is getting close.
Adobe has released InDesign and InCopy (and InDesign Server) version 7.5.3.333.
Release notes at http://helpx.adobe.com/indesign/release-note/release-notes-indesign-cs 5-51.html
(well, linked from http://www.adobe.com/support/documentation/en/indesign_incopy/releasen otes.html#indesignCS55753 if you want to compare InDesign and InCopy and InDesign Server).
InDesign unexpectedly quits when performing certain copy/paste operations. [3073952, 2941163]*
When opening files from a newer version of InDesign, non-meaningful errors about missing plug-ins are shown rather than a clear indication that the file is from a newer version. [2944763]*
Degradation in performance when moving objects when display is set to High Quality [3128109]*
InDesign unexpectedly quits when recovering a file on product restart. [3100953]*
White stitching line in JPEG export with certain placed images scaling percentage and JPEG export resolution [2987040]*
Redraw performance for ID CS5 is slow compared to CS3. [2910574]*
Poster: From Current Frame' option in the Media will not restore the poster from that frame after re-linking. [3097841]*
Reduced transparency support for TIFF files from Photoshop CS6 [3073238]*
In certain drag and drop scenarios, URLs are getting changed in InCopy/InDesign CS4, CS5.5 [3054805]*
Uninstall/Reinstall removes Bridge's "Place>In InDesign" menu item. [3079235]*
Wrong page number on export book to PDF [2940448]*
Tab override gets reset in INX/IDML [2827174]*
Master applied incorrectly when opening IDML file [3114965]*
Legacy versions fail to read ID CS6 files that contain files with new Pantone Plus colors. [3119501]*
Inconsistency in loading and exporting a linked image from INDD [3017929]*
Strange offset occurs between two pages on same spread [3080049]*
InDesign unexpectedly quits when exporting to PDF with text variables [2866963]*
Note inside document table with text variable causes InDesign to quit unexpectedly on export to PDF/IDML. [3089441]*
Unable to navigate document if TOC is on master page. [2907482]*
Text appears misplaced in certain cases when DataMerge is used to export [2939067]*
InDesign hangs or quits unexpectedly during certain package and preflight operations. [2982454]*
Problem copying stories via VBScript when called through an application [3059225]*
Unexpected shutdown when JavaScript is executed with InDesign followed by closing of document. [3021908]*
Using Smart Layout with Linked frames causes InDesign to unexpectedly quit in certain cases. [3085379]*
Fonts not loading from different locations. [3013562]*
InDesign quits unexpectedly with certain fonts when balancing columns [3099740]*
Fonts of the same family but different type behave unexpectedly on IDML round trip. [3114961]*
Certain documents go into infinite loop when adjusting frame size [3113902]*
Incorrect glyph selection with certain Indic fonts when using specific virama and joiner character sequences. [2849232]*
Broken spanning columns cause issues with Text Wrap & Keeps Options [2958674]*
Folio Builder and CS Review's SWFs will not render when '<' is present in doc filename [2971572]*
InDesign CS5.5 quits unexpectedly on deleting unused swatches using small view option [2987294]*
associatedXMLElement returns 'NULL' for a merged cell in table. [2946288]*
CCommandLineArgs::ProcessArgsLate will cause product to hang in certain cases when used with LogToApplicationEventLog [2988814]*
InDesign Server quits unexpectecly when running spell checker on certain documents. [2935990]*
Document installed fonts get locked on Windows. [2890001]*
Of particular note, I think, are:
Import / Export: Wrong page number on export book to PDF [2940448]*
Print/PDF: InDesign hangs or quits unexpectedly during certain package and preflight operations. [2982454]*
The first of these has been plaguing users here for quite some time, so it's very good to see it fixed.
The second one has been plaguing me personally for a long time, and I'm very happy to see a fix for it finally released!!
Hey, what about this one!
This needs to be retro-fixed for all existing versions, all the way back to InDesign 1.0!
It's unimaginable this particular issue had to persist for more than a decade, leading to frustration and bewilderment of literally thousands of users, and hundreds upon hundreds of posts in this forum alone.
