Updated CR to 7 Release Candidate, and Updater prompt updates available but produced error on update, "Camera Raw 6.6 cannot be update". Understand that Cr7 is now available, how to update to this new version from Release Candidate. Running on Window 7/32.
Hi, just managed to update to CR 6.7.0.339 with out any problem on my desktop window 7/64. The problem I described is on my laptop running on window 7/32, software is CS5. On checking I realised that the CR has been updated correctly to CR 6.7.0.339 on the laptop as well, I believe the CR release candidate was 6.7.0.319. However, it produce an error message that CR 6.6 cannot be installed' on the 7/32 machine. It's not really a problem now, as CR is performing ok, perhaps someone should check why there is an error on 6.6 when CR6.7 is installed successfully.
Paraphrasing the error message and vaguely describing when it happens isn't the best way to describe exactly what's happening.
Can you take a screenshot of your 32 bit system showing the error message and everything that's happening, save it as a JPEG, and post it here? That would be helpful for the Adobe folks looking into the issue..
-Noel
OK, my laptop now shows that CR6.7.0.339 installed
but Adobe updater still show that CR update available
however, update will fail
Note that earlier in the day, the updater prompt me to update and apparently correctly update to the latest CR 6.7.0.339 version, but show the above error messages.
Thank you
The Adobe Auto Updater or Auto Update Manger is best ignored. It has been broken for years and years, sometimes offering you updates that you already have installed (as in your case), at other times failing to show you available updates, and not uncommonly generating installation failures.
As long as "About Plug-in…" shows the correct version, you have nothing to worry about.
