Cannot open InDesign layout from Folio Builder panel after mandatory update
May 3, 2012 6:53 AM
After installing the mandatory folio builder update, I am unable to open an InDesign layout by double clicking on the layout in the Folio Builder panel. I've tested this with InDesign CS5 and 5.5 with the same result. I can manually open the InDesign Layout from the Finder (I'm using Mac OSX 10.7) without a problem. I am able to update the article from the FBP but can't open the layout. I don't know if this is affecting pushing updates though.
    May 3, 2012 7:01 AM   in reply to Chad Chelius
    What happens if you preview the article? You might need to relink the article to the source files. Or re-create the articles.
    May 3, 2012 7:12 AM   in reply to Bob Bringhurst
    I have the same problem - all my source file links are broke to the articles. It will take very long to relink everything.
    May 3, 2012 7:40 AM   in reply to Chad Chelius
    This would certainly appear to be a bug. At least it’s not a killer and just an annoyance…but it’s an annoyance just the same.
    If you have a sidecar.xml file you might want to just recreate the entire thing.
    Bob (the other one)
    May 3, 2012 7:42 AM   in reply to Chad Chelius
    Same error here, (posted before) right now we are making another folio from scratch just to test.
    May 3, 2012 7:52 AM   in reply to Bob Levine
    The better option is "do it again"...
    Right now I'm making a new folio from scratch with the same files (articles) and everything is working as usual.
  • Branislav Milic
    Jan 12, 2010
    May 3, 2012 7:59 AM   in reply to carlosgarro
    Had the same problem.
    I reimported everything with a sidecar.xml file. It took 20 minutes but it was not me clicking hundreds time.
    May 3, 2012 8:10 AM   in reply to Branislav Milic
    Thanks for letting us know about this issue. I reported the bug.
    May 3, 2012 8:44 AM   in reply to Bob Bringhurst
    Thank, you BobB!
    Same here on my machine (InDesign v7.5.3 with OSX 10.6.8).
    Adobe DPS version:
    plug-in version
    7.5.5.19
    folio format version
    1.12.0
    plist version
    1.3.0
    ExtensionBundleVersion
    12.2.2.20120427_m_686705
    Uwe
    May 3, 2012 8:49 AM   in reply to Laubender
    I guess the bug is due to an update of the "afc.db" file after installing the new Folio Builder panel.
    Uwe
  • Branislav Milic
    Jan 12, 2010
    May 3, 2012 8:51 AM   in reply to Laubender
    I don't have this problem.
    I have updated three folios.
    May 3, 2012 8:57 AM   in reply to Branislav Milic
    Maybe that bug didn’t make it Europe, yet.
    Bob
    May 3, 2012 9:50 AM   in reply to Bob Levine
    @Bob – it did.
    I did a little drilling to the "afc.db" file and found the culprit. Missing entries in:
    verticalLayoutSrcDocId
    horizontalLayoutSrcDocId
    Maybe that will help the developer team to work that out.
    I could recreate the connection between my InDesign files and the corresponding folio article by getting the right values inserted in the "afc.db" file.
    To get those, I simply made a new folio with the article, checked again the "afc.db" file and copied the entries for "verticalLayoutSrcDocId" and "horizontalLayoutSrcDocId" over to the old article represented in the db file.
    I would absolutely NOT recommend this to the "average" user. It's more on the experimental side.
    And, I guess, does only work for local folios.
    Uwe
    May 3, 2012 10:17 AM   in reply to Chad Chelius
    I remake the folio from scratch and everything is working fine
    May 3, 2012 10:23 AM   in reply to Branislav Milic
    @Branislav – just checked. YES. You are right.
    Updating single articles does the trick. The connections to the InDesign files are established again.
    No need to hack the "afc.db" file.
    Pooh…
    Uwe
