I want to have a search field that the customer puts an item code in that will then lead them to an item that cannot be accessed otherwise. I am new to Dreamweaver so I am a bit confused as to what would be the simplest way to complete this. Then, on the Spry Slideshow widget how can you get your own pics into it?
For Spry Slideshow Widget, this should help you: http://labs.adobe.com/technologies/spry/ui/docs/image_slideshow.htm
For the item code thing, its a simple PHP search function where your script will execute a 'SELECT' MySQL query to figure out if the entered product code matches anything in your DB and it returns that item as a result. It'll be something like this. Your file should be saved as .php. Change 'localhost, username, password, dbname', according to your current setup. product_name is a column in your DB. Also, I'd highly recommend a set of books that's specifically written to cater to needs of people like you. I suggest you take a look at it. http://www.sitepoint.com/books/phpmysql5/
Here's the code.
mysql_connect('localhost', 'username', 'password');
mysql_select_db('dbname');
$sql = "SELECT * FROM table WHERE product_name LIKE '%" . mysql_real_escape_string($_GET['search_query']) . "%'";
$result = mysql_query($sql) or die("Error in query $sql: " . mysql_error());
while ($row = mysql_fetch_array($result)) {
echo "Product: " . $row['product_name'] . "<br />";
}North America
