CQ5
Querybuilder.json servlet and authorization
May 2, 2012 7:05 PM
Tags: #search #query #querybuilder
Hi all,
Does the querybuilder.json servlet acknowledges the user authorization when searching? Can I pass user credential so the Querybulider.json will only return what that user suppose to see ?  If yes, how do i pass user credential via URL ?
Any pointers would be greatly appreciated.
    May 3, 2012 12:05 AM   in reply to cqlearner
    querybuilder.json is like every other http service given by cq, authorizing only registered credentials (among which is anonymous)  and retrieving the data that associated JCR session is allowed to read.
    if you are in a secured network, or just playing with features, you can use basic auth, e.g.
    http://admin:admin@localhost:4502/...
    or through curl :
    curl -u admin:admin http://localhost:4502/...
    There are other ways of authentication (see login page code e.g.)
    May 3, 2012 7:01 AM   in reply to cqlearner
    The query builder runs in the user's session and uses the normal jcr query underneath, so all ACLs are respected. I guess your ACLs are not what you think they are.
    May 3, 2012 8:50 AM   in reply to cqlearner
    Yes a publish instance must be readable for an anonymous user, whereas an author instance isn't.
    Depending on the runmode (cf. http://www.pro-vision.de/adaptto/downloads/2011_lightning_Runmodes_and _Configs_for_Fun_and_Profit.pdf) the author runmode will redirect anonymous to the login if a resource is not readable to him, the publish runmode will just finish here (and retrieve 404).
    May 3, 2012 12:19 PM   in reply to cqlearner
    As noted, ACLs you create on the author don't get over to a publish automatically, and all activated content is readable by anonymous by default, assuming a public website.
    You probably want to look into "closed user groups" to set up ACLs and custom logins on the publish.
    http://dev.day.com/docs/en/cq/current/howto/create_apply_cug.html
  • Justin Edelson
    Nov 24, 2010
    May 3, 2012 1:09 PM   in reply to cqlearner
    by definition, you can't "run publish instance in author mode"
    CUG are the right mechanism to define an ACL on author and have it apply on publish (after replicating the page).
