My current setup:
P8P67 Pro Rev B
SSD 120 GB Windows 7/64 OS on 3 Gb/s connector
RAID 0 SATA3 (2x2TB) on Intel 6Gb/s connectors
RAID 0 SATA2 (2x1.5TB) on Intel 3 Gb/s connectors
Ports are set to 'RAID' mode in BIOS
There are four 3 Gb/s ports and two 6 Gb/s ports controlled by Intel
Two additional 6 Gb/s ports are Marvell controlled
Is it advisable to move the SSD to the Marvell 6 Gb/s port? Can I simply plug it in or will I have to reformat and set up the RAIDS?
Am I benefitting from the RAID 0 setup on the 6 Gb ports? Should I separate the drives?
I am having stability issues. Frequent lockups and crashes. Also, how do you tell the difference between a 6 gb/s cable and a 3Gb/s? I replaced the SSD cable and now have less frequent crashes, but still crashes.
It depends on your SSD, but generally it will profit from the 6Gb/s port and yes, you can simply plug it in without needing to setup your raids again.
Yes, it makes them faster. If you have covered the backups, then I see no benefit to break them out to single disks.
Now that worries me a bit. Can you tell us what you have changed from the factury defaults in the BIOS. Do you have the latest BIOS version installed? How do these lockups and crashes manifest themselves and from what application? What does the Event Viewer tell you in terms of error messages? What PSU do you have, what are the temps when you encounter such a crash or lockup? Have you checked your memory with Memtest 86+? etc.
| Log Name: | Application |
| Source: | Microsoft-Windows-RPC-Events |
| Date: | 4/29/2012 8:01:17 PM |
| Event ID: | 11 |
Task Category: None
| Level: | Warning |
| Keywords: | |
| User: | LOCAL SERVICE |
| Computer: | Wildfire |
Description:
Possible Memory Leak. Application (C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted) (PID: 136) has passed a non-NULL pointer to RPC for an [out] parameter marked [allocate(all_nodes)]. [allocate(all_nodes)] parameters are always reallocated; if the original pointer contained the address of valid memory, that memory will be leaked. The call originated on the interface with UUID ({3f31c91e-2545-4b7b-9311-9529e8bffef6}), Method number (20). User Action: Contact your application vendor for an updated version of the application.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
| <Provider Name="Microsoft-Windows-RPC-Events" Guid="{F4AED7C7-A898-4627-B053-44A7CAA12FCD}" /> | |
| <EventID>11</EventID> | |
| <Version>0</Version> | |
| <Level>3</Level> | |
| <Task>0</Task> | |
| <Opcode>0</Opcode> | |
| <Keywords>0x8000000000000000</Keywords> | |
| <TimeCreated SystemTime="2012-04-30T03:01:17.280886100Z" /> | |
| <EventRecordID>301</EventRecordID> | |
| <Correlation /> | |
| <Execution ProcessID="136" ThreadID="416" /> | |
| <Channel>Application</Channel> | |
| <Computer>Wildfire</Computer> | |
| <Security UserID="S-1-5-19" /> |
</System>
<EventData>
| <Data Name="ApplicationName">C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted</Data> | |
| <Data Name="ProcessId">136</Data> | |
| <Data Name="InterfaceId">{3F31C91E-2545-4B7B-9311-9529E8BFFEF6}</Data> | |
| <Data Name="Method">20</Data> |
</EventData>
</Event>
| Log Name: | System |
| Source: | MEIx64 |
| Date: | 4/29/2012 8:11:57 PM |
| Event ID: | 4 |
Task Category: None
| Level: | Warning |
| Keywords: | Classic |
| User: | N/A |
Description:
The Intel(R) Management Engine Interface is being disabled.
Event Xml:
<System>
| <Provider Name="MEIx64" /> | |
| <EventID Qualifiers="32775">4</EventID> | |
| <Task>0</Task> | |
| <Keywords>0x80000000000000</Keywords> | |
| <TimeCreated SystemTime="2012-04-30T03:11:57.572038500Z" /> | |
| <EventRecordID>1099</EventRecordID> | |
| <Channel>System</Channel> | |
| <Security /> |
</System>
<EventData>
| <Data> | |
| </Data> | |
| <Binary>00000000010000000000000004000780000000000000000000000000000000 000000000000000000</Binary> |
</EventData>
</Event>
| Source: | Application Hang |
| Date: | 5/2/2012 12:01:06 PM |
| Event ID: | 1002 |
Task Category: (101)
| Level: | Error |
| User: | N/A |
Description:
The program AfterFX.exe version 10.5.0.253 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: ed4
Start Time: 01cd288ab1ebb145
Termination Time: 20
Application Path: C:\Program Files\Adobe\Adobe After Effects CS5.5\Support Files\AfterFX.exe
Report Id: 2922c0e4-9489-11e1-865d-f46d042cc6bb
Event Xml:
<System>
| <Provider Name="Application Hang" /> | |
| <EventID Qualifiers="0">1002</EventID> | |
| <Level>2</Level> | |
| <Task>101</Task> | |
| <TimeCreated SystemTime="2012-05-02T19:01:06.000000000Z" /> | |
| <EventRecordID>2301</EventRecordID> | |
| <Security /> |
</System>
<EventData>
| <Data>AfterFX.exe</Data> | |
| <Data>10.5.0.253</Data> | |
| <Data>ed4</Data> | |
| <Data>01cd288ab1ebb145</Data> | |
| <Data>20</Data> | |
| <Data>C:\Program Files\Adobe\Adobe After Effects CS5.5\Support Files\AfterFX.exe</Data> | |
| <Data>2922c0e4-9489-11e1-865d-f46d042cc6bb</Data> | |
| <Binary>55006E006B006E006F0077006E0000000000</Binary> |
</EventData>
</Event>
| Source: | Application Error |
| Date: | 5/2/2012 12:00:12 PM |
| Event ID: | 1000 |
Task Category: (100)
| Level: | Error |
| User: | N/A |
Description:
Faulting application name: Adobe Premiere Pro.exe, version: 5.5.2.0, time stamp: 0x4e960e56
Faulting module name: Display.dll, version: 5.5.2.0, time stamp: 0x4e95fe31
Exception code: 0xc000041d
Fault offset: 0x0000000000039cbc
Faulting process id: 0x7f4
Faulting application start time: 0x01cd288fdc7f0e75
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Adobe Premiere Pro.exe
Faulting module path: C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Display.dll
Report Id: 0b392663-9489-11e1-865d-f46d042cc6bb
Event Xml:
<System>
| <Provider Name="Application Error" /> | |
| <EventID Qualifiers="0">1000</EventID> | |
| <Task>100</Task> | |
| <TimeCreated SystemTime="2012-05-02T19:00:12.000000000Z" /> | |
| <EventRecordID>2298</EventRecordID> | |
| <Security /> |
</System>
<EventData>
| <Data>Adobe Premiere Pro.exe</Data> | |
| <Data>5.5.2.0</Data> | |
| <Data>4e960e56</Data> | |
| <Data>Display.dll</Data> | |
| <Data>4e95fe31</Data> | |
| <Data>c000041d</Data> | |
| <Data>0000000000039cbc</Data> | |
| <Data>7f4</Data> | |
| <Data>01cd288fdc7f0e75</Data> | |
| <Data>C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Adobe Premiere Pro.exe</Data> | |
| <Data>C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Display.dll</Data> | |
| <Data>0b392663-9489-11e1-865d-f46d042cc6bb</Data> |
</EventData>
</Event>
I was having these problems before. I replaced all the RAM to 32 (4x8 sticks) Corsair Vengeance, GTX 570 card failed a couple of weeks ago, so I got a GTX 580 AMP!. The original SSD was a Kingston HyperX. Replaced it with a Patriot Wildfire 120 GB. Noothing wrong with the Kingston.
Installed the latest BIOS, reset CMOS, clean reinstalled Windows, TPU switch enabled. In BIOS, default settings at first. Tried XMP, and Manual. OC tuner, automatically overclocked to 4.4 GHz
I did stress test with Prime 95 - no issues
Memtest passed - no issues
No temperature or fan speed warnings
PSU is a Thermaltake 850W TR2 RX
Premiere or AE would just quit responding and grey out. Sometimes recovers on its own, sometimes not. Usually, only the app needs to be restarted. Other times, the computer locks up.
It happens less frequently with the new SATA cable on the SSD.
It might be your PSU: None of Thermaltake's TR2 or TR2 RX series PSUs can handle anywhere near their labeled (advertised) wattage ratings. In fact, the TR2 RX 850W barely qualifies as a 600W PSU in realistic operating conditions. The major failing is the PSU platform(s) that they are based on (the TR2 RX 850W is based on an old HEC 600W platform to begin with) - and then, the safety circuits get disabled to allow more wattage to be output at the severe expense of DC output quality. The ripple goes way out of spec, which can kill PC components much earlier than you would expect!
The graphics card short-out is likely caused by dirty output from a low-quality PSU. You see, modern high-performance components are now more picky about PSU output quality than old, low-performance, obsolete components were. That is exactly what might happen if you're asking a PSU to output more wattage than what its original OEM manufacturer (HEC/Compucase, in the case of that Thermaltake-branded TR2 RX 850W) had designed it for.
Now don't get me wrong, Thermaltake does market some good PSUs. It's just that the TR2 RX line is one of many that they market which stink.
At least at the Fry's that's closest to my home, the Corsair AX line, the NXZT HALE 90 and HALE 82 lines, and most of the models in the Antec High Current Gamer and High Current Pro lines are good to great choices. Most of those are manufactured by Seasonic (with the following exceptions: The AX 1200W is made by Flextronics; the NXZT HALE 90 line is made by Super Flower and the Antec High Current Pro line and some of the High Current Gamer models are made by Delta).
Got a Corsair AX850 at Fry's, which is probably the minimum recommended for my setup - GTX850 Amp and 5 internal drives. I still had problems with freezing after install. Come to find out, the 120 GB SSD system drive was almost maxed to capacity. Had some remnant of cache files and other stuff to delete to make room. Seems to be running smooth with about 18 GB of free space, but need to free up more.
What do you think of installing a second SSD to put programs on and keep only Windows on the system drive? I have the original SSD. Nothing wrong with it - I replaced it thinking it might be bad.
Heck, when I get my burned out GTX570 replaced by ASUS, I'll have almost enough components to build another system! Have a spare 120G SSD, 16 GB RAM, Monitor and a 85 W power supply. Al I need is a case, motherboard and processor.
