WORKS:
<embed src="http://host.com/test.pdf#page=5"/>
FAILS:
<embed src="test.pdf#page=5"/>
Both code snippets above work when the HTML file is hosted (IIS / Apache). My web-app needs to be able to run from a USB memory stick and work with IE9. The #page param is required for a core feature of the app.
Parameters after the # are passed correctly to the Adobe Reader plugin in Firefox for offline files, eg: file:///C:/test.htm. The documentation only describes hosted examples: http://www.adobe.com/content/dam/Adobe/en/devnet/acrobat/pdfs/pdf_open _parameters.pdf
I have tried the <object> route as well with similar results, eg: http://pdfobject.com/
I have burned over 8 hours looking for a solution. I have tried any logical settings in Adobe Reader X, and with the security zones in IE. I am not very familiar with IE security zones, but I suspect it could be related to my issue. I can specify the end-user change any browser or plugin settings as an acceptable solution.
PDF is media. Your IE is doing this on local media for security reasons.
http://windows.microsoft.com/en-us/windows-vista/Change-Internet-Explo rer-Security-settings
That said, it's better if you don't embed PDF into web pages. Not everyone has the necessary plug-ins for their browser/devices. Some people (myself included), prefer to open PDFs in Acrobat Pro instead of our browsers. If you embed your PDFs in a web page, people like me will never see them.
A much safer approach is to insert a small screenshot with a direct link to the PDF file. Your site visitors can decide for themselves how to handle the file. That's how Adobe does it.
http://www.adobe.com/manufacturing/3dpdfsamples/3dsolutions/
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
I am developing a hybrid web-application that needs to work both offline (entire website) and in a hosted environment. A key part of the product is displaying PDF's with a dynamic index outside of the PDF. This allows us to use PDF's collected from hundreds of contractors, clients and manufacturers and combine them into one searchable product with a consistent interface. I can specify product requirements including IE browser settings, installed plug-ins etc. I am not trying to cater to a wide audience such as everyone online, but a specific one that is spending $5k-30k for a custom resource.
I expect the limiation is due to a wide cast net regarding security. I tried every setting in IE and essentially fully disabling all security options did not resolve it.
I found a solution, by accessing the ActiveX object directly you can use the exposed classes described here: http://livedocs.adobe.com/acrobat_sdk/9.1/Acrobat9_1_HTMLHelp/wwhelp/w whimpl/common/html/wwhelp.htm?context=Acrobat9_HTMLHelp&file=IAC_API_O LE_Objects.103.167.html
Javascript:
var pdfO = document.getElementById('pdfObj');
pdfO.setCurrentPage(pageNumber);
HTML:
<OBJECT id ="pdfObj" data="test.pdf" TYPE="application/pdf">
<a href="test.pdf">Fall-back code</a>
</OBJECT>
This actually works much faster as well, since the plugin doesn't need to be re-drawn in the DOM
