Submitting variables to an ASPX file WITHOUT opening new window
May 3, 2012 8:06 AM
Tags: #loadvars #sendandload
Hello,
I'm trying to submit some variables from my flash to an aspx page on a different domain which will handle them and put them in a database.  I've tried a number of options, but the only ones that have worked also result in a new window/tab being opened, and I am trying to avoid this.
For example, I tried a loadVars with the sendAndLoad() function, but it did not work because the "load" portion requires the aspx page to be on the same domain as the swf- which it is not.
the send() function does not work either, because it requires you to specify a target (_self, _blank, etc) and that causes a new tab to open, or a redirection on the current page- both unacceptable, as I am trying not to interupt the user's experience on the page the swf is featured on.  send() does succeed in submitting the variables, at least, but as I said, it opens a new tab/redirects current tab.
One solution is to enable outside domains access on the server-side, but this is not ideal.  I'm hoping for a flash solution.  Any thoughts?
here's the code:
var dataLoader = new LoadVars();
var junkLV:LoadVars = new LoadVars();
junkLV.onLoad = function(success:Boolean) {
    if (success) {
        trace("We are in business.");
        greenLight_mc._alpha = 100;
    else {
        trace("FAIL");
        redLight_mc._alpha = 100;
dataLoader.firstname = firstName;
dataLoader.lastname = lastName;
dataLoader.email = emailAddress;
dataLoader.dest = destination;
dataLoader.sendAndLoad("url.aspx", junkLV, "POST");
  • kglad
    Jul 21, 2002
    May 3, 2012 10:37 AM   in reply to DTshults
    is that pseudo-code?  if not, there should be no cross-domain issue.
    also, use "_self" in the send() method should not open a new window.
  • kglad
    Jul 21, 2002
    May 3, 2012 12:07 PM   in reply to DTshults
    the code you showed does not call a cross-domain aspx file.
  • kglad
    Jul 21, 2002
    May 3, 2012 1:31 PM   in reply to DTshults
    then you'll need to use a local domain file to call your cross-domain file or you'll need to use a cross-domain master policy and possibly policy file.
  • kglad
    Jul 21, 2002
    May 4, 2012 5:55 AM   in reply to DTshults
    you're welcome.
