tpa_gru_flo
Iterate through selected characters
May 3, 2012 12:10 PM
Tags: #text #javascript #selection #characters #selected #jsx #characterattributes #iterate #iteration
Hi guys and girls!
Has anybody a code snippet to show me how to iterate through the selected text (not the frame!, not the words, only the selected chars) and make any change on the characterAttributes (size, color, etc.)?
Deeper into it:
In the property "app.activeDocument.selection" usually the selected objects are stored as an array. Now when I select characters in a textframe (or TextPath, whatever) there is a [Textrange] in it.
I already tried some combinations like this snippet underneath but I still get errors, that selectedChars[i] is undefined.
FYI: I'm on Illustrator CS4, Mac OS X, Javascript
var selectedChars = app.activeDocument.selection.characters;
for (i = 0; i < selectedChars.length; i++ ){
     selectedChars[i].characterAttributes.fillColor = myNewCMYKColor;
I hope I have gathered all relevant information. If not, please do not kill me and just ask back
So has anybody a smart hint for me?
Thanks a lot in advance!
    May 3, 2012 3:13 PM   in reply to tpa_gru_flo
    select some characters before running
    var myNewCMYKColor = new CMYKColor;
    myNewCMYKColor.magenta = 100;
    app.activeDocument.selection.fillColor = myNewCMYKColor;
    May 4, 2012 9:49 AM   in reply to tpa_gru_flo
    Here's a Change Size script that I found in my collection that somebody posted severat years ago. I'm sorry I don't remember who it was to give proper credit.
    #target illustrator
    // change size of paragraph text
    //$.bp();
    ChangeSize();
    function ChangeSize()
        selectedItems = selection;
        // check to make sure something is selected.
        if (selectedItems.length == 0)
            alert("Nothing is selected");
            return;
        endIndex = selectedItems.length;
        for (index = 0; index < endIndex; index++)
            pageObject = selectedItems[index];
            pageItemType = pageObject.typename;
            if (pageItemType == "TextFrame")
                // get the paragraphs from the selection.
                theTextRange = pageObject.textRange;
                paraTextRange = theTextRange.paragraphs;
                numParagraphs = paraTextRange.length;
                for (i = 0 ; i < numParagraphs ; i++)
                    aParagraph = paraTextRange[i];
                    charTextRange = aParagraph.characters;
                    charCount = charTextRange.length;
                    if (charCount > 1)
                        end = charCount;
                        fontSizeChanger = 14/end;
                        currentFontSize = 18;
                        for (j = 0 ; j < end; j++)
                            theChar = charTextRange[j];
                            theChar.size = currentFontSize;
                            currentFontSize = currentFontSize - fontSizeChanger;
    and here's the output.
    You should be able to go from there.
    May 4, 2012 10:39 AM   in reply to Larry G. Schneider
    I doesn't behave like I would expect it to here either… I have no issues when changing characters at an individual… The issue appears to be handling selection… in text… Yes I can loop the textRange… But it will NOT allow me to change at character level… I can change the whole range or loop with the characters to the same value but but can't makes changes with each… Some thing will always error undefined
    #target illustrator
    var doc = app.activeDocument;
    var sel = doc.selection;
    if ( sel.typename == 'TextRange' ) {
              var count = sel.characters.length;
              doc.selection = null;
              for ( var i = 0; i < count; i++ ) {
                        $.writeln( i );
                        var selCar = sel.characters[i]; // Is defined
                        $.writeln( selCar.contents );
                        var newSize = 24 + ( i * 3 ); // Is defined
                        $.writeln( newSize );
         //selCar.characterAttributes.size = newSIze;
                        selCar.characterAttributes.size = 30;
    The commented out line will always error here… All the figures and letters look right in console?
    May 4, 2012 11:48 AM   in reply to Muppet Mark
    Hi Mark, it might be a bug, at first, in you code selChar is a Character, and in the documentation even though it says "textRange" objects of length 1, there's really no Character Object...but anyhow, selChar does take properties like Contents, behaving like a true textRange Object...but weird it doesn't work when you set the sizes...weird.
    then I noticed the textRange Object has a textRanges property, that did it, it holds each character as a textRange.
    here's a working sample
    var sel = app.activeDocument.selection;
    var characters = sel.textRanges;
    var fontsize = sel.characterAttributes.size;
    for (i=1; i<=characters.length; i++) {
        var character = characters[i];
        var randomFontSize = randomXToY (fontsize-6, fontsize+6);
        character.characterAttributes.size = randomFontSize;
        character.fillColor = myNewCMYKColor;
        var randomMagentaColor = randomXToY (0, 100);
        myNewCMYKColor.magenta = randomMagentaColor;
    //function to get random number upto m, by Roshan Bhattarai
    function randomXToY(minVal,maxVal,floatVal)
      var randVal = minVal+(Math.random()*(maxVal-minVal));
      return typeof floatVal=='undefined'?Math.round(randVal):randVal.toFixed(floatVal);
    May 4, 2012 12:05 PM   in reply to CarlosCanto
    Prefect, Carlos, for writing your next ransom note. All we need now is to randomize the font by character.
    May 4, 2012 12:11 PM   in reply to Larry G. Schneider
    hahaha, that's right, let's have tpa_gru_flo write that as homework
    May 4, 2012 12:16 PM   in reply to CarlosCanto
    I'm trying to get this to work. I have it in ESTK and have targeted illustrator but it keeps returning "The specified text range is invalid" for the line var character = characters[i].  I have a piece of text in the file and a selection made of the text. Any words of wisdom?
    May 4, 2012 1:30 PM   in reply to CarlosCanto
    Thats a good spot Carlos… I had seen that but had NOT the time to put it to any tests ( saved me a bother ) There was also a textRange.textSelection that I wasn't sure about… Text ranges and sub ranges are a little weird at times…
    May 4, 2012 1:40 PM   in reply to Larry G. Schneider
    Hi Larry, are you getting that error running my script? or you're using that line in your own version?.....
    ...wait, I see what's happening, let me run a couple of tests.
    May 4, 2012 2:46 PM   in reply to Muppet Mark
    ok, you can safely forget all I have said previously
    Larry my previous script worked only because I randomly started my selection at the second character, just a coincidence here. I was really iterating the whole textFrame, so ended up rewriting the thing....and at the end it was like Mark's...???...that's weird, how come Marks didn't work?
    Mark, I revisited your script and it does not work cos you have a typo , you have newSIze, instead of newSize, changed that and it works beautifully...so, you still need to figure out textRanges and textSelection
    here's the new version, it still needs work to make it a real Ransom Note generator
    for (i=0; i<sel.length; i++) {
        var character = sel.characters[i]; //characters[i];
        //alert(character);
        //alert("i= " + i + "\rcharacter= " + character.contents);
    May 4, 2012 4:05 PM   in reply to CarlosCanto
    Thanks, Carlos. Works well now. I looked in my scripts and found one by James Talmadge to vary the baseline of text so may work to incorporate that as well.
    May 5, 2012 3:21 AM   in reply to CarlosCanto
    Looks like I should increase the size of my type in the ESTK I couldn't spot that… Hum a trip to spec savers or a 27" imac… I'll have a think… ( once a muppet always a… )
